Paper does not feed but jams on entry
Paper does not feed but jams on one side on entry
  • 530 Answers
Friend, be sure you not have any something stuck on your printer may a pen, pencil, eraser or even paper clips. Try to see if there is something stuck on it that may cause such problem.I am giving this because that is the common happened when only other side may cause the jam. good luck friend
Posted on Jun 16, 2009
Paper jam in cannon lbp3300 printer
Unplug printer and check paper entry feed ,especially the right side,will probably be dirt or a piece of paper stuck in feed roller, use an air duster (aerosol) to blow out dust etc.
Jan 14, 2018 | Office Equipment & Supplies
Paper will not feed through printer part
cut the paper evenly with scissors before attempting to feed it into the paper entry port. If you just rip it, it will jam or fail to feed.
Nov 06, 2013 | Casio Office Equipment & Supplies
The paper will not feed correctly. The Right side is getting jam
First jam a paper on purpose then you will know where the jam is . and you will also know where to find the paper which is under the white cylinder.
Feb 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper feeds crooked
Sounds like a blocked paper path, paperclips , staples , bits of paper etc can drop into the sheet feeder entry and get stuck in the paper rollers.Look and see if you can see anything in there, if not try feeding a piece of thin card back through the printer from the front (ie in reverse of the normal paper travel) be careful and you may be lucky and drive out the obstruction, if not you will need to strip it down to investigate further
Jan 31, 2009 | Epson Stylus 880 InkJet Color Printer
Paper Jams
The printer should be on,remove the paper from the printer(if there is any),press and hold the down arrow/cancel button, release the button when the power light blinks 3 times ... The printer will rollers will automatically revolce and clear all the jams.. When the power light is green then repeat the same step 3-4 times.. To confirm the paper jam is cleared then feed 8 1/2 * 11 paper in the printer and again press the down arrow button and release the button once the power light bliks for 3 times and then release the button. If the printer feeds properly it confirms the hardware of the printer is fine.
Software issue: Go to printer and faxes in computer and check the icon. If it says.. 0 paper jam then, delete the icon and chcek in the device manager if there is an entry of usb printing support under Universal Serial Bus controller .. if the entry is there then delete it. Insert the printer cd in the computer and unplug and replug the usb cable from the printer. If the setup screen comes up then exit out of it and the printer drivers will get updated. After that tried to print another tets page from the computer. It will definately print.
Aug 06, 2008 | Canon PIXMA iP90 Mobile Printer
Printer will not feed paper correctly
there were may situation that can help with this trouble,
1- try to see if the trays are seated correctly no bend or twisted
2- try to check the quality of your paper no concave nor convex ( like U or N)
3- clean the feed roller from either side by moistened cloth, ( only on one direction evenly
4- ensure no hindrance on the paper path inside the machine
5- reset the unit once more
let me know if you need some more
Jul 25, 2008 | Office Equipment & Supplies
Trouble with paper feed
Frequent jams are because either scanner picks up more than one paper or does not pickup at all. If scanner picks up more than one paper, then paper is sticky. If the paper is thin, it can pick up two at a time. Fan the papers so that they are not sticky.
Paper at the point of entry into the scanner must be crisp. If folded or 'dog-eared' trim it. Rotate the paper if any other side is crisp, roate the image later.
Clean all the rollers thoroughly, the pickup roller, retard roller and other rollers in the scanner. One can rotate the inner rollers and clean totally, not just waht is seeable area. If the rubber is worn out, it must be replaced. TRy a single page to check if the rubber is okay. Jarring noise is because the motor is 'stopped' and cant rotate because paper is stuck. This can affect motor/inner parts, but is designed for normal use.
Feb 02, 2008 | Canon DR-7080C Flatbed Scanner
PAPER JAM
Hi, oh dear, you have a paper jam in or near the roller or very small one in carriage. Open up unit as if rplacing cartridges, get a torch if you have to and search for tiny jam. A good clue, is does the carriage return to correct positon upon opening?
Jan 16, 2008 | Lexmark X6170 All-In-One InkJet Printer
Loading printer paper
Where I was guiding the paper, after feeding the paper through the back of the machine (the slot is located on the outside of the back of the machine), the paper naturally wanted to enter underneath the black plastic plate where it would end up underneath the entire printing mechanism. As the instructions indicate, the paper does not actually feed "under the black plastic plate", it should feed through it. There are two rectangular silver tabs, one on each side of the proper paper entry slot. I cut the paper at a very slight angle and finally found the magic entry point. Also if you make an arrow with the paper by folding the sides, it will help guide it in that tiny silver slot. Because the machine is so tiny, that entry slot is almost invisible, except for those two silver tabs. After you manage to insert the end of the angled cut through the "invisible slot" be sure the entire edge of the paper actually enters the slot so that when you push the "Feed" button, the paper is grabbed and fished through evenly. Hope this helps somebody!
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; document.getElementById("ga_300x250").style.width = "370px"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //-->
Mar 19, 2007 | Canon P1-DHV Calculator
139 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
