Question about Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
Jura S9 coffee machine not drawing water - says FILL SYSTEM
When I power on my S9, it states FILL SYSTEM straight away.
I have pressed the STEAM button but does not pump like normal and no water is drawing. I have removed filter and also ensured water is flowing from tank and not blocked.
I pulled machine apart and there was a lot of heat from the water boiler as no water is going through to cool it.
Before this happened, I run 3 cups of coffee but stopped it prior allowing coffee to RUN through system (this was to clear some old beans)
Any ideas? Does it sound like the water pump is dead as it isnt pumping?
Also, can I force into programming mode to try and RESET the machine?
Thanks
  • Pacman02 Jun 17, 2009
    FIXED!
    Cleaned the bottom gate from coffee dust.
    Also powered off system for (unplug from wall for 2 hours) and reset
    All ok and working now
    Problem Solver:
  • 12 Answers
Try using the "shipping" unit button to shut everything off. Turn off the unit and then tryo to run it again.
Posted on Sep 20, 2009
    Sniper:
  • 60 Answers
I think the magnetic valve is defective. This is located on the left side (seen from behind inside the machine) and there`s connections between the thermoblock and the hot water outlet. Try to press the steambutton and check if the magnetic valve clicks, and maybe check with a voltmeter if it`s receiving power.
PS. During steamprocessing the pump just have small ticking sound, and not the same sound as during brewing. There is no way around this Fill system message, and the reset function is not activated until any System Messages has been clared.
Posted on Jul 12, 2009
How do I un glog the grinder
Don't see an un-gloger listed.
http://www.shop.partsguru.com/searchquick-submit.sc?keywords=jura+s9+grinder
Sep 15, 2014 | Jura Capresso Impressa S9 Coffee...
Hi, our Jura Impressa Xs90 keeps flashing 'fill system' & ' press steam'. There is plenty of water in it, we've tried removing the water and refilling. Doesn't work. If you press steam it just beeps...
Have you run a decal recently? This normally happens when a small particle (normally) an undesolved piece of the decal tablet is stuck in the flow meter, or sensor.
You can try and run warm water through the system and after about half a tank it should be sorted out.
May 02, 2011 | Jura Capresso Impressa X90 Espresso...
The S9 has been unused for three months and I cannot get it to get water to the brewer. It keeps telling me to fill the water and press the steam button. No such luck. Is there a way to prime this machine?
Hello
This is a common problem and there`s usually only 1 thing you can try to do yourself. Use luke warm water in the watertank and repeat the fill system procedure 4-5 times. If this doesn`t help, try to shut down the machine and try the same after 30 minutes. If nothing happens after you tried this a few times, then theres a problem with the solenoid valve for steam, and this need to be changed. That`s something you need help from a technician for.
Jun 13, 2010 | Jura Capresso Impressa S9 Coffee...
Hi, no coffee is coming out of Jura S9. The water comes out of steam exit - even in cleaning program rgds
This is a really strange error, but it makes some sense if you own a S9 One Touch model. Then there`s a problem with the squeezing valve located behind the steam/cappuccino outlet. If this is an older model, then it could be a problem with the ceramic valve, but normally this makes the water flud all over the frontpanel and inside. In both cases, i would recommend to send the machine to the nearest servicecenter.
Nov 10, 2009 | Jura Capresso Impressa S9 Coffee...
My Jura Impressa xs90 keeps stating fill system, even after filling the system several times for the last 3 days.
Empty the Water tank and fill it with warm water. Then keep trying for some time and the problem will get solved.
Oct 15, 2009 | Jura Capresso Impressa S9 Coffee...
Changed Claris Filter-now says
Fill your water tank with Warm Water and then try a few times. Keep Patient and Keep trying for some times and it will work.
May 31, 2009 | Jura Capresso Impressa S9 Coffee...
Machine says malfunction and won't froth milk
If you have a rotarywheel; Press and hold to enter the menu, turn to Maintenance, select Decalcify unit; empty tray as requested, fill up 600ml water in a container. Disolve 3 Descaling tablets in the water, and then fill it in the watertank. Press Maintenance button and you`re off.
If you don`t have a Rotary; Turn off the machine and let it cool down for a while, then push the Rinse/Maintenance button for a few seconds; then you will get the message Empty tray. Fill the solution in the watertank and press button.
It`s important that you use the right amount of water, or else the process will "never" finish.
Dec 24, 2008 | Jura Capresso Impressa S9 Coffee...
Refilling system
Run a clean cycle, might sort it out,
Sounds like it is scaled
Dec 14, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Changed Claris Filter-now says "fill system/press steam"
Probably have air in the system - it needs to be flushed, Run the tea portion hot water for a while. If not check the manual on how else to flush the system Gary
Apr 13, 2008 | Jura Capresso Impressa S9 Coffee...
Jura Capresso Impressa S9 Coffee Maker/Espresso Machine Logo
1,743 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
