Realistic MPA-35 amp by Radio Shack
I inherited one of these Realistic MPA-35 amps and I am not familiar with it. I need to know how to connect speakers to it. There seems to be no way to do it, I mean I don't know where to connect the wires to the speakers on the back, It's not like the newer amps with - and + posts. Please don't laugh, I just don't want to burn anything out......thanx
Vinny in Bedford Texas
    President:
  • 2,992 Answers
It's not that this amp isn't like "newer amps" with + and - terminals, it's that this amp is made for public-address system use. This kind of amp is used in a store, for instance, to pump background music through speakers all over the place. The terminals you connect to are determined by total impedance of the speaker configuration used.
Most single speakers, or the two- or three-way cabinets for home stereo systems, are 8 ohms. If you're connecting a single speaker you use the "common" and "8 ohm" terminals on the rear panel. With multiple speakers, you need to figure out the total impedance and use the appropriate terminal. In series, impedances add. Two 8 ohm speakers in series would total 16 ohms, so you use the common and 16 ohm terminals. In parallel, the total impedance drops. Two 8 ohm speakers in parallel total only 4 ohms. You need to figure the total impedance of the speaker configuration and connect accordingly. Too great of a mismatch will damage the amp or speakers or both.
You might be able to find the manual for this amp on Radio Shack's website. Here's a link to the manual for the model MPA-40 which should have similar output terminals. The basic information about figuring out total impedance and general use of PA amps applies to your amp as well.
Posted on Jun 16, 2009
  • 3 Answers
I have scanned the MPA-35 Manual to a PDF file. It is a high-quality scan and as a result it is 12 MB in size. If you would like the manual, send me an email (dave@dadero.com), and I will email you a temporary link on myspace.com from which you can download the manual. It is in both English and French.
Posted on Oct 02, 2009
How to hook speakers up to a realistic mpa-40
The MPA-40 is a mono public address amp. So it has one speaker output. You select the appropriate socket to suite the speaker type. The 4/8/16 Ohm outs are for various tpyes of Hi-Fi speaker. The 70 Volt is used for muzak in shopping centres, restaurants, and waiting rooms.
If you have a pair of 8 ohm Hi-Fi speakers, you can diasy chain the connections and then use the Com and the 16 Ohm connection.
Daisy chain means you take the wires from a pair of speakers. Connect together the wires going to red on one speaker and black on the other. This now leaves you with two wires going to the other red and black terminals on the speakers, but the ends in your hand are not connected to anything yet. Plug the black in to COM. Plug the red in to 16 Ohm.
The sound from the speakers won't be stereo. It will be mono because that's all the amp outputs. But both speakers will work so long as they're functioning units.
If you have two 4 Ohm home theater speakers then you can do the same trick. 4 + 4 makes an 8 Ohm load. Connect the red to the 8 Ohm output.
Don't be tempted to try to connect to multiple terminals. The amp isn't powerful enough to to run more that one speaker chain.
Hope this helps
Sep 15, 2014 | Audio Players & Recorders
Trc 481 manual
Insure that you can receive transmitting stations.
• Be sure you are pressing the talk button
all the way in
• Make sure CB/PA is set to CB.
• have a check on cable and PL259 connectors
• Insure that the antenna resonates on the same operating
frequency of your radio, that is 11 meters
To determine if you have a bad finals, only your neighbor
@ about 20 ft can hear you.
For your manual:
Realistic TRC-481 (210-1550)
Jul 26, 2012 | Radio Shack Trc-481 Cb Radio
Looking for manual Realistic MPA-40 35W
I have a realistic mpa-40 35 -watt pa amplifier owner's manual
cat, no, 32-2032A
You can conyact me @ ltlerock@aol.com
Jan 03, 2010 | Audio Players & Recorders
MPA-101 Amplifier powers on, receives source signal, the fuse is not blown inside, but no sound comes out of the amplifier. The amp is pretty new, doesn't even have dust inside the unit.
Hello, is this a Radio Shack PA amp or Jamo amp? The unit is probably in "Protect" mode. Is this a PA system or a receiver...receivers have a protection circuit that will not let the speaker relay activate if the amplifier output section is shorted and sending voltage towards the speakers...so they won't fry!!The speaker relay should activate within 3 to 5 seconds if your output section is ok.
barneyluc
Oct 13, 2008 | Audio Players & Recorders
Radio scanner not receiving
i ha ve realistic 2032 which is doing the same thing and was wondering because everything else including all the functions work fine including hearing white noise and being able to control it with the squelch could this be the end for it or is there stuff yet to do
Feb 28, 2008 | Uniden BC248CLT Base Scanner
3,047 people viewed this question
 Grubhead
Grubhead
