Question about GE 24 in. GSD4000J Built-in Dishwasher
Diswasher drainage in an island
We remodeled our kitchen and we installed the dishwasher in the island instead of by the sink(originally the diswasher was next to the sink).  Can I just run the drainage pipe from the dishwaser, under the floor and up to the sink?
  • Anonymous Mar 28, 2014
    how to install samsung dishwasher water drainage pipe
  • 709 Answers
I suggest just putting a dedicated Drain in the island next to the Dishwasher. You can hide it in side the island. Under the house, tee into the Main Sewage drain.  You should not need to vent it as the sinks vent is near enough to keep you from worrying about that.
Posted on Oct 31, 2007
I have Frigidaire FDB956RBC1 diswasher. I have to turn off the water to fix the faucet. When I turned the water back on, water did not go to the diswasher when I used it. The diswasher runs normal except...
Welcome to fixya
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
My name is Bruce
Jan 19, 2011 | Frigidaire FDB956RB Built-in Dishwasher
What is E24 on my Bosch super silence dishwasher?
Check the air gap! It may be clogged.
There is a great video explaining how to do t linked below.
My air gap was clogged, and after cleaning it the error 24 was gone...
The Diswasher Air gap how to clean it and why it important
Jan 02, 2011 | Dishwashers
Nautilus diswasher is sending water out through the "overflow"? next to the sink, flooding the kitchen.
You must have a clog in the drain line. If it is ran to your garbage disposal then that is the first place to check.
Sep 17, 2010 | GE Nautilus 24" Built-in Dishwasher
I want to buy a new GE diswasher but I do not know about water inlet, is it hot water or it could be normal?
Dishwashers are usually connected to the hot water line under your kitchen sink. Although, a dishwasher has a heating element of its own, connecting it to the hot water side minimizes the amount of time the heating element cycles on and reduces the amount of electricity consumed.
Feb 24, 2010 | Dishwashers
People periodically get shocks from the metal sink , dishwasher?
Make sure the ground wire on the dishwasher has a really good connection.
Also the ground wire in the plug in receptacle.
Feb 04, 2010 | Dishwashers
My dishwasher backed up into my kitchen sink , it was about 30 minutes into a 2 hour wash cycle--i drained the diswasher, but 1 inch stayed in it till this morning, the sink drained on its on
It sounds like an issue with the sink drain rather than the dishwasher. Many dishwashers are connected to a double sink, one bay of which contains a garbage disposal. If yours is connected in that configuration, run the disposal to clear any food debris that may still be present while running the HOT water into the disposal.
If you have no disposal or if the dishwasher is connected to the other non-disposal bay, check the sink drain again for proper drainage.
The easiest way to do this is to put a plug in the drain (both sides, one at a time), then fill the sink about half way with luke warm water. Then reach in and pull the plug from each side, watching to see how each side drains, but especially the side with the dishwasher connected. If it's slow draining, focus your efforts on clearing the drain on that particlular side of the sink. Try a plunger first before resorting to other methods to clear the sink. If you plunge the dishwasher side, get underneath the sink and pinch off the discharge line from the dishwasher if possible. A pair of vise grips works well, but don't overtighten them.
Some dishwashers have a soft disposal that can eject enough ground up particles into a sink to cause plugging up over time, especially if the dishwasher empties into the disposal side.
Jan 20, 2010 | Whirlpool 24 in. GU980SCG Built-in...
Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
Jul 05, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
The incoming hot water can be hooked up independently. The thing you should consider is the drain line. The drain hose and the pump are (obviously) below the tub of the dishwasher (DW). If you route the drain hose through the floor directly, the water in the tub will siphon out. You'll need to route the drain hose to keep this from happening. The way to do that is to route it in such a way that it forms an almost upside down "J", then down through the island. The upper portion of the "J" should be about the same height as the top of the DW.
Also consider the electrical hook up. The proper way to wire it is through a SPST switch (like a light switch) so you can turn power off in an emergency or a servicer can kill power without having to locate the breaker. Some contractors "hard wire" the DW's in (with or without a SPST switch)... others mount a wall outlet so you can plug and unplug the DW if necessary. Either way is OK, only mentioned it so you'll know how your contractor will be doing it.
Just some things to consider. Good luck with the renovation and I hope you enjoy your new Kitchen.
Oct 13, 2007 | GE 24 in. GSD4000J Built-in Dishwasher
Dishwasher intallation
the waste water piping must be on the downhill side of a drain trap. the trap prevents bad gasses from entering the house.
Oct 13, 2007 | Miele Incognito G818SCVi Built-in...
GE 24 in. GSD4000J Built-in Dishwasher Logo
228 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
