Question about Motorola Mobility RAZR V3
How to format sd memory card in motorola i 580
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Unreadable memory card!!!!motorola krzr k1
you may have to buy a memory card reader, plug it into your computer and format the memory card before it will work in your phone, or your phone may require a different format of the same card, for instance some camera's take SD cards, and some take the HD/SD card, and they are not interchangeable, the SD will not work in the HD/SD device and vice versa..........hope this helps........
Aug 22, 2009 | Motorola Mobility Car Charger For KRZR...
Memory card will not format
No. The maximum size of memory card supported by this model is 1GB microSD type only. So it wont recognize your 2 GB memory card.
Aug 09, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Motorola V360 -Memory card slot error
Hai Dud,
Are you using Micro SD transflsh memory??
Format the Card on the PC using FAT, after that use a CARDREADER and put these folders on the card: MOBILE and in the mobile folder put audio, video, kjava, picture, temp! Shutdown your Motorola, remove the backcover and plug-in the card! After that Start Your Motorola and copy a file from the mobile's memory on the CARD! It should work!
Hope it Helped You,If so give an "High Five!" [;)]
Aug 04, 2009 | Motorola Mobility V360 Cellular Phone
Motorola k1 cannot format unformatted memory card
sometimes there are sd card errors make you format failed. you may get messages like
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
Jun 04, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Memory card micro sd cannot format
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
Mar 08, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Memory card for motorola krzr k1
try formatting & inserting it again.......
it may solve ur prob
Dec 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Memory card
I was having same problem with a 4 yr old digital camera. Apparently, it only recognizes up to 512 MB, and the card needs to be partitioned into 4 parts.
Dec 25, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Sd memory for motorola L7
cause it doesnt come with sd lol it comes with 10mb built in u have to buy sd if ya want more memory
:p
Nov 21, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
