Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Pls what could be responsible for 10.1000 supply memory error in HP laserjet M1522n
FYI it isn't 10.10.00 its 10.1000 - i have a hp laser jet M1522 nf... n i just changed my cartridge... it worked for for the 1st day but the next day i started getting this error... what to do ? the cartridge is brand new and i don't want to buy a new one coz they ar nt cheap.... please help..
Posted on Jul 28, 2009
  • LCDanohkawa Feb 07, 2011
    The extra dot is added for clarification when reading the error. The second set of two numbers refers to a location/color, and the third refers to the specific error condition. the .00 means the chip is either missing altogether, or isn't communicating at all. the only problems with using this cartridge top to bottom is that you will have to press the go button every so often, usually first thing in the morning when the printer wakes up, and it will not know when the cartridge is empty. It will not affect the quality of the print until it runs out of toner. when you get light streaks through your prints, replace the toner with a new one, and you should be just fine.
  • 8 Answers
It just means that the printer can't read a tiny eeprom chip on the cartridge. 10.10.00 refers to the black cartridge, and you should be able to continue just by hitting the ok button. it should go away with the next cartridge.
Posted on Jun 16, 2009
Supply memory error
remove the right hand side end cover ( formatter acces panel) remove the bad memory ( card about 1" by 3" )- if your not sure its failed try with new memory and see if error returns
Mar 04, 2014 | HP LaserJet M1522n MultiFunction Printer
What is 10,1000 supply memory error with hp
10.1000 Supply Memory Error
A specific print cartridge has a missing elabel.
Reinstall the print cartridge.
Turn off and then turn on the product.
If the problem is not solved, replace the cartridge.
Jul 21, 2011 | HP LaserJet M1522nf Multifunction Printer...
Tengo una impresora de Modelo Hp LaserJet M1522n MFP presenta el siguiente mensaje de error. Error de memoria consum: 10.1000 pareciera ser por que el cartucho no es original, pero lo he comprado con...
It is possible. The message is caused because the printer cannot read the little chip that is on the cartridge. Usually replace the toner will fix the issue (specially if its not hp). In your case it might be the reader that is not working. Try taking the cartridge and paper out. Then reset the printer by turning it off and press and hold the down arrow and cancel. Then turn it on and wait for the message ''permanent storage init'' then release the keys and will get back to ready.
Aug 30, 2010 | HP LaserJet M1522nf Multifunction Printer...
I am getting error: 10,1000 supply memory error reinstall
You are using re manufactured toner and it has a bad chip. Replace the toner.
Jul 06, 2010 | HP Laserjet CM2320nf All-In-One Color...
I have M1522n laserjet Hp printer and keep getting error message 10.1000 supply memory error what does this mea
Hi Paul,
That simply means that their is a problem with the chip installed on the toner cartridge, try doing a nvram
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
If this doesn't work contact Hp directly, 1800-334-5144.
Al
Feb 12, 2010 | HP LaserJet M1522n MultiFunction Printer
HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Jan 07, 2010 | HP LaserJet M1522n MultiFunction Printer
Error memory 10.1000
This means that a specific cartridge has an e-label error.
The solution is to:
1. Reinstall the print cartridge.
2. Turn off and then turn on the printer.
3. If the problem is not solved, replace the cartridge.
Oct 07, 2009 | HP LaserJet M1522nf Multifunction Printer...
Hp laserjet m1522n Memory error
I think the Toner Cartridges are not well.Either they are not genuine or the Toner Cartridge is faulty. If faulty, the toner chip is mostly bad. Try replacing the Toner.
Thank you Sir, Have a nice day.
Sep 23, 2009 | Office Equipment & Supplies
Hp laserjet m1522nf 10.0000 supply memory error
Try another toner. Most likely the chip on this one is bad.
Apr 07, 2009 | HP LaserJet M1522n MultiFunction Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
1,147 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
