EasyNote GN45 - Dead!
No power light with charger plugged in (with & without battery) - lifeless. Charger is fine as I've tested with another PB laptop. Processor?
  • 157 Answers
Likely your power plug inside the laptop is corroded around the positive terminal connecting to the motherboard, it will need to be resoldered or replaced. Repair places will charge a couple hundred dollars for this simple job often requiring no parts, good luck.
Posted on Jun 16, 2009
  • 2,404 Answers
No power = bad motherboard. If you can't get any power with a known good ac adaptor in a known good outlet then its a motherboard problem at that point. it can either be bad solder joints underneath the dc jack that need to be resoldered so the points are making full contatt or the motherboard itself is totally bad and needs to be replaced.
95 lebaron short deadens battery in a day or two while parked
try this..entirely disconnect the battery and use a ten amp charger as a battery for the car by connecting the charger clamps to the battery cables..be careful to match the polarities red to the positive and black to negative..plug the charger in and listen for a buzzing or see if the guage on the charger pegs to full power..the buzz should show your faulty issue..(relay or switch stuck etc)..
Dec 23, 2013 | Cars & Trucks
Completely dead laptop.
sometimes you just need to remove the battery then power-up the unit using its charger.
Jul 05, 2013 | Toshiba satellite c660
Battery wont charge on my Mid m9100 android tablet pc
Are you sure the charger is working correctly? When you plug the charger into the tablet and into the wall, then leave it alone for half an hour, does the charger feel at all warm? Is there power to that outlet, or is it a switched outlet (like one used for a lamp)?
If the charger feels warm after half an hour, does the back of the tablet also feel warm? It may actually be charging.
If the charger is dead cold (same temperature as a table) and you're sure that it's plugged into a good outlet and correctly plugged into the tablet, then it's a good bet that the charger is dead & you need to find another.
Can you also charge that tablet with a USB cable connected to a PC? That'd be a good test. Try doing that - if that ALSO will not charge the tablet, then there may be a problem with the tablet itself.
Mar 02, 2013 | mid M9100 9" Dual Camera Android 4.0 ICSOS...
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
My computer shuts down without any warning at all. The problem has occurred 4 times this week when charger is unplugged but power icon still shows me approximately 50% battery. Sometimes computer lets me...
Check you power settings. It is possible that it is set to shut down at 50% battery power.
If it is overheating, that too will cause a shutdown. What is happening at the time of shut down? Are the vents on the laptop being blocked in any way?
Sep 04, 2011 | ASUS Computer International U35jc A1...
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Dead laptop
hi guys...can you try to remove the battery then plug the AC/Charger then see what happen..only charger no battery pack in Laptop...
thanks
Apr 05, 2009 | Acer Aspire 5920-6335 Laptop
Computers & Internet Logo
162 people viewed this question
Alun Cox
David Payne
David Payne
