Question about NEC Office Equipment & Supplies
I replaced the bulb, but projector won't turn on
I replaced the lamp after there was a steady red light but the projector still won't turn on; how can I reset the lamp usage or ''tell'' the machine that there is a new bulb?
  • pbcollege Jun 16, 2009
    Hold the HELP BUTTON (ON THE REMOTE) for 15 seconds, pointed at the projector.  Works like a charm....wish the manual had said that!!
SOURCE: reset lamp hours for new bulb
Is it a Sony VPL CS4? Try [Reset], [<-], [->], [Enter] keys
Posted on Sep 29, 2007
Sinista
  • 6 Answers
SOURCE: Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Posted on Jul 10, 2008
  • 7 Answers
SOURCE: optoma DX605 hard reset
Have you tried going to Menu>Options>Lamp Settings>Lamp Reset>Yes?
Hope this helps!!
Posted on Jul 13, 2009
SOURCE: Benq PB8220 lamp used for 375 hrs shuts projector automatically
Unplug any cables from the projector (except for power)
On the device (not the remote control) hold down exit for 3 sec
lamp status are shown
on the remote control use MENU, and then left right to reset lamp
Posted on Oct 01, 2009
SOURCE: the projector lamp does not turn on
I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
Posted on May 13, 2010
How do I fix a mitsubishi tv that shuts off and has a steasy red light
Replace your lamp. Make sure its a real Osram bulb and not some cheap knock off. These folks have Osram bulbs and a 6mo warranty. Projector Lamps and TV Lampson Sale ProjectorLamps com stocks Superior...
Sep 26, 2016 | Mitsubishi WD Televison & Video
Steady red lamp light after lamp and filter replacement. not turning on
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 09, 2015 | NEC NP17LP Projector lamp
Tv is turn on and red indicator is steady lit then after a minute the tv is turn off and red light is lit steady why,
1,Check the fans ,whether the fan is running,when you turn on the projector
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 08, 2014 | Panasonic 2 Projector Lamp
Replaced both bulbs with brand-new bulbs. Now all
Verify that the lamp doors are securely closed. The blinking red lights indicate a lamp problem. In this case, both appear to be defective. I doubt that the lamps are the problem. double chack all connections and doors for proper seating. Update this if the problem remains.
Thanks,
Dan
Apr 16, 2010 | Sharp XG-PH50X Multimedia Projector
Power light is steady orange and lamp light is red but there is a new bulb in it. NEC VT676
Mar 02, 2010 | NEC VT676 Multimedia Projector
No picture
ballast is not striking the lamp and needs replacing
Jan 10, 2009 | Sharp XR-10X Multimedia Projector
TLP-B2 projector lamp problem
my suggestion that unit is faulty and i recommend that you bring to the service center for repair that unit.
Jan 28, 2008 | Epson LCD PROJECTOR, XGA, 3500 ANSI, 1024...
344 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
