Question about Dell 924 All-in-One InkJet Printer
The ink is printing out fine, but in cartridge warning window says they are empty, and then stopped printing saying to remove cartridges. Now printer has error of 1203 and won't work. It won't shut off, and I unplugged and did no good. 1203 error still on screen. How do I fix?
  • 71 Answers
Try to remove the Ink Cartridge while printer is on then install it back after a minute. If you still getting the same error, possible the Ink Cartridge or Printer is faulty.
Posted on Jun 16, 2009
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
New ink cartridge in printer saying empty
Assuming you have a refilled or remanufactured cartridge there this is actually pretty normal. These cartridges have no means of checking for new ink in the cartridge so will continue to warn of empty. They will not however stop you from printing as a result.
If however you purchased the cartridge as a brand new cartridge, you may have been miss-sold the cartridge. In which case I would advise speaking to whoever it was purchased from.
Nov 20, 2012 | HP Photosmart C3180 All-In-One InkJet...
I need step by step instructions showing how to change an ink cartridge on and Epson NX110 printer
If the printer is out of ink in one or more cartridges (the ink light is steady), then with the printer on, lift the scanner unit and use the support to prop it up. Press the Stop button and the (first) empty cartridge will line up with the No Ink symbol on the printer. Press Stop again and the next empty cartridge will be moved to this symbol. Continue to press Stop until the cartridge carrier moves to the ink replacement position (depends on how many cartridges are empty). This is on the right side of the printer. Wait for the cartridge carrier to stop moving. Do not touch the white cable while changing the ink.
Next remove the first ink cartridge by pressing the two tabs towards the center of cartridge and pulling it straight up. (One tab is close to you and the other is closest to the printer.) Take your new cartridge for the slot and shake it four or five times. Then remove the cartridge from the package. Do not touch the green chip. Remove the yellow tape from the bottom of the cartridge. Next rotate the cartridge so that the nozzle is down and facing towards the inside of the printer. Then push it straight down into the slot until it snaps into place. Repeat these steps for the rest of the empty cartridges.
Once all of the empty cartridges have been replaced, lift the scanner unit and push the support to fold it. Close the scanner unit. Press Stop to start charging the ink system. Wait until the Power light stops flashing and remains on before turning off the printer or sending a print job to the unit.
If the Ink light continues to flash, open the scanner unit and press Stop. Press down on the cartridges to make sure that they are completely seated in the cartridge carrier.
If the ink out light is flashing or not lit, you need to use the Epson Utility to change the ink. This is part of the full software from Epson. For Windows right click on the printer icon in the taskbar (bottom right of the screen). Then select Printer Settings and click on the Maintenance tab. For a Mac, open the Applications folder and open Epson Printer Utility 3. Select your printer (if you have several Epson printers listed). Then click OK. (You will need to launch the utility before you open the scanner unit.)
The documentation for the Epson NX110 is available here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1663277658.1305218830@@@@&BV_EngineID=cceeadfdielfldicfngcfkmdhjidfmh.0&cookies=no&infoType=Doc&oid=128284&prodoid=63084353 .
I hope this helps.
May 12, 2011 | Epson Office Equipment & Supplies
How do i install new cartridges into my tx printer first time user never changed before
With the printer on but not busy (flashing light), open the scanner unit. (Lift the scanner until the bracket on the right locks.)
If the cartridges are completely expended:
Press the Stop button on the printer, the print head should move to line the expended cartridge with the empty ink mark. Press Stop again and the next empty cartridge should line up with the mark. Continue to press Stop until the print head moves to the cartridge replacement location (after noting which cartridges need to be replaced).
One cartridge at a time, shake the new cartridge 5 times before opening the package.
Remove the new cartridge from the packaging and remove the yellow tape from the cartridge. Be careful not to damage the hooks on the side of the cartridge and do not touch the green IC chip. Leave the transparent seal in place.
Squeeze the tab at the back of the cartridge you want to replace and then lift the cartridge up. Then put the new cartridge straight into that slot and press down until it clicks.
Repeat this for all empty cartridges. Then close the scanner unit and press Stop. Wait until the light stops flashing and the empty ink error light goes out. The unit will charge the ink system while the light is flashing.
If the empty ink remains flashing or is on with the print head in the home position, then a cartridge may not be properly inserted. Press Stop and then push down on the cartridges. See http://support2.epson.net/manuals/english/spc/stylustx100tx101/guide/html/ink_4.htm for pictures and images.
If the ink isn't expended, use the Ink Replacement utility in the Epson software. For Windows, this is part of Printing Preferences in the Maintenance tab. Open the Devices and Printers (slightly different name in older versions of Windows) control panel. Then right click on the printer and choose Printing Preferences.
I hope this helps.
Dec 04, 2010 | Epson TX100 Series
Cant figure out how to put in the ink cartridges
Procedure for replacing Cartridge
When FIne Cartridges run out of ink, replace them. using the following steps.
*Important
Handling Fine Cartridges
-Once the protective tape is removed, do not touch the electrical contacts or Print Head Nozzles on a FINE Cartridge. The printer may not print out properly if you touch it.
-To maintain optimal printing quality, we recommendthe use of specified Canon brand FINE Cartridges.
Refilling is not recommended.
-Once you remove a FINE Cartridge, replace it immediately. Do not leave the printer with the FINE Cartridge removed.
-Replace empty cartridges with new ones. If you insert FINE Cartidges that has been removed once, the printer may not print properly due to some reasons such as clogging of the nozzles. Furthermore, with such cartridges, tlhe Low ink warning may not be displayed properly.
-Once a FINE cartridge is installed, do not remove it from the printer and leave it out in the open. This will cause the FINE Cartridge to dry out., and the printer may not operate properly when it is reinstalled. To maintain optimal print quality, use a FINE Cartridge within 6 months of first use.
-Color ink may be consumed even when printing a black and white document or when black and white printing is specified.
Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the printer's performance.
1) Make sure that the printer is on, and then open the Front Cover.
The FINE cartridge Holder move to the left.
Cautuion : * Do not hold the FINE cartridge Holder to stop or move it.
* Do not touch the metallic parts inside the printer.
Important : If the Front Cover is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. Close and reopen the Front Cover to return the holder to the left.
2) Remove the empty FINE Cartridge.
a) Push down the FINE Cartridge.
b) Remove the FINE Cartridge.
Important: - Handle FINE Cartridge carefully to avoid staining your clothes or surrounding area.
-Discard empty FINE Cartridges according to the local laws and regulations regarding disposal of consumables.
3) Prepare the replacement cartridge.
a) Unpack a new FINE Cartridge and remove the orange protective tape. gently.
Important : - Handle FINE cartridge carefully to avoid staining your clothes or surrounding area.
- do not re-attach the protective tape once you have removed. Discard it according to the locals laws and regulations regarding disposal of consumables.
-once the protective tape is removed , to not touch the electrical contacts or Print Head Nozzles on a fine cartridge. The printer may not print out properly if you touch it.
-Be careful not to stain your clothes and hands with the ink on the removed protective tape/
4) Install the FINE Cartridges.
a) Insert a new FINE Cartridge all the way into the appropriate slot. The Black FINE Cartridge should be installed into the left slot and the Color FINE Cartrige should be into the right slot.
b) Push up the FINE Cartridges until it clicks into the place.
Important : The printer cannot be used unless both the FINE Cartridges are installed.
5) Close the Front Cover.
Hope this helps. Please rate my response.
Thanks,
Have a good day.
Nov 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Canon pixma mp210 printer - replaced ink cartridges with compatible ones - printer working fine except when printing both ink lamps come on solidly, not blinking, and status says there is no ink in...
Dear merryan,
This printer uses FINE cartridge which has memory chip inside that store ink level data. Once the cartridge is EMPTY we cannot restore this data to be FULL even though we physically refill ink until FULL. So the printer keep displays NO INK warning.
Similar with using compatible cartridge, NO INK warning still remain because ink level data has been recorded as empty. Why?. Here is the explanation. As far as I know no third party compatible cartridge produced this printer since canon protect it with the chip. Compatible cartridge that sold in the market is refurbish cartridge which repacked with another brand.
To fix this problem we need to deactivate ink level detection function by holding down STOP/RESET button for about 9 seconds or more for each cartridge. The consequence of this is ink level become UNKNOWN.
Hope this will be helpful to you
Regards,
Xanda
Nov 08, 2008 | Office Equipment & Supplies
Hp desk jet 920c ink cartridge
hi,
i think your color ink cartridge is near to empty that's why you are experiencing a pause printing..
try to replace it and try to print again..
rey...
Oct 08, 2008 | HP DeskJet 920c InkJet Printer
DELL AIO 922- All in one- Printer won't print
Remove the right ink cartridge (color). You will get an error saying the cartridge is empty, but ignore that. Hit cancel on your printer. Print your job...when your print screen comes up, under preferences check the box for print colors in black and white. Your printer should print just fine without the color cartridge. Ignore the flashing red light.
Sep 06, 2007 | Dell 922 All-In-One InkJet Printer
Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Oct 05, 2006 | Brother MFC-5440CN All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
144 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
