Question about Sony PFM-42B1 42 in. HD-Ready Plasma Television
Tv/Monitor shuts off and on by itself
My sony 42" flat panel monitor is used as a television set using ths S-video cable as a connection.  When you turn it on a few minutes later it begins shutting off and on by itself.  sometimes the picture finally comes back on and other times I shut it off for a while and it doesn't do it again.
E-MAIL: - Chicago Area -
Posted on Feb 22, 2008
  • 20 Answers
I have a complete set working all panels with a duff pdp panel - i will happliy sell you the boards please call me on 07940 025730 for details cheers.
Posted on Nov 18, 2007
Got a 19" LG LCD
To convert a LCD Monitor into a TV
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
Got a 42 sony monitor yet need a TV conversion...
You can use it as TV through Monitor device (also known as cable device) and are very commen in market also in cheap prices, which specifically designs for monitors, just plug you monitor with the device and plug your antenna with the device and enjoy it.
Thanks for using fixya.
Jul 28, 2009 | Sony Televison & Video
Where do you hook in the cable connection
There is no cable connection. This set is a monitor and you need cable or satellite.
Mar 29, 2009 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
No picture when vga cable is connected
Most tvs can only handle a couple resolutions (ie 640x480) through the pc input. Even some HD tvs can only do 480. Check that your video is turned on and setup to the acceptable resolutions.
right click your desktop
go to properties
click settings tab
click on the 2nd monitor
make sure the box is clicked at the bottom
"extend my windows desktop onto this monitor"
instructions for windows xp
Dec 16, 2008 | Televison & Video
Problem connecting cable wires for Sony PFM-42B2 42 in. Plasma TV
I have this screen and my version does not include audio - I need to connect to an external amplifier, in my case my home theater.
Nov 18, 2008 | Sony PFM-42B2 42 in. Plasma HDTV
The video out resolution through the port may not match what is supported by the TV.
Aug 26, 2008 | LG 42LC2D 42 in. LCD HDTV
Using a Sony Bravia HDTV as a monitor for a Macbook Air
Hey RHSully,
In addition to connecting your Macbook to the TV, you may also need to adjust the video output signal coming from the computer itself. Several of the TV's in Sony's Bravia model line should include a list of the optimal settings for each screen resolution within the owner's manual, but you may need to search through Sony's online support site if you can't find this list for your specific model.
Hope this helps you out.
Go Ahead. Use Us.
Jun 18, 2008 | Televison & Video
Sony PFM-42B1 42 in. HD-Ready Plasma Television Logo
125 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
