Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Part required for Craftsman Ride on Mower 38" model 917.259040
I would like to source the steering rod that connects the wheel to the front axle of a Craftsman 38" mower. The model number is 917.259040 and it has a 13.5 HP Briggs and Stratton engine. I think it is a 2002/3 build. The ball joint on the front axle and steering rod has parted so I assume I need a complete new part unless you have another idea? I am based in the UK so would need a local supplier if possible. Also if you can tell me where I can source an operators manual that would be helpful. Thanks
Gary
    Sergeant:
    Champion:
  • 226 Answers
Go to parts tree.com.put in your model#.they will probably have what you need.hope this helps
Posted on Jun 17, 2009
How to remove the front wheel on a victa NXT23/46 ride on mower
Graeme, usually you remove the rubber/plastic axle/hub cap, jack mower up and secure from falling, next remove retaing clip( C clip, cotter pin, etc), and washer, slide wheel off. Check the attached links,instruction and guides, could not find your model, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Changing Front Tire on The Craftsman
Removing Wheel from Riding Mower
http://support.mtdproducts.com/app/answers/detail/a_id/203/~/wheel-removal---riding-mower
Apr 24, 2016 | Garden
Adjusting tow in on craftsman pro riding lawn mower
You can try streightening the steering link rod. or just buy a new one. also make sure the holes on the axle brackets arent wallard out.
Jun 30, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can t turn stearing left or right takes all my strength to turn
check out the steering connecting rod. its the rod that goes from left to right front wheels. if it is not completely straight, either bend it straight or buy a new one.
Also, could be your front axle if you dont have the cast iron heavy duty axle.
Jun 24, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Greenfield ride on mower front axle/wheels
zYou are correct. there is an adjustment for the wheels. The front wheels are connected to the steering by tie rods, as in a car. This kind of adjustment is not found in a user manual, but you can do it. Inspect how the wheels are connected and inspect the tie rods. The tie rods have to be disconnected from the wheel and turned in or out depending on which direction the wheel needs to go ,in or out. One tie rod is right hand thread. The other is left hand thread. So the adjustment is making the tie rods shorter or longer. If you do a search on the web ' riding mower tie rod adjustment', you'll find plenty of info.
Good luck
May 04, 2014 | Garden
Paula
Paula, what are you calling the tension arm? What is this "arm" suppose to do? What is it that you are trying to accomplish? You may be taking the steering wheel off for nothing. I just can't visualize what you're looking to do, or what is wrong with the machine. You have a steering wheel, steering shaft ext, steering gear assy which has the steering shaft in it, a drag link, then a tie rod. I added a link to a similar type tractor for reference.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917256660/0247/1509200/10042967/00004?blt=06&prst=0&shdMod=917256660
Mar 29, 2014 | Garden
Lawn mower steering
Order new piece. Parts are pretty cheap on ebay or amazon.
Apr 24, 2013 | Craftsman Garden
Steering is loose. How to tighten it?
Joseph, Most likely it is the bronze bushing at the other end of the steering shaft. You will need to remove the mower deck to access it more easily. The steering gear could be replaced at the same time if you want, you will be right there at both the bushing and the gear, the sector shaft hopefully is ok. You can view this with a flash light before disassembly. It is on the steernig shaft that goes behind the fuel tank, down into the frame. As you or a helper turn the steernig wheel back and forth, you can see the engagment of the steering gear and the sector shaft, to determine if they need replacing too. Your dealer should have a dozen or so of those bronze bushings. Its not a bad job to do.
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 09, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Two front wheels misaligned, one is straight and the other points outward
To give you a professional soultion I really need a complete model number.
Here is what happens when steering becomes a problem on ANY brand of riding mower.
1. Tie rods get bent
2. Wheel spindle pivots get bent on one side.
3. Pivot bearings or bushings get worn
4. Linkages from the steering wheel to the tie rod pivot connection get bent.
On the basic bottom of the line Craftsman riding mowers the tie rods are fixed and not adjustable. However if you look for a mirror image left to right of the tie rods often you will note that one of them is bent in or out... or is shorter than the other one. There are after market tie rods that are adjustable. This is over 40 years of experience talking here.
THe best way to do an inspection of steering is to place the mower on tripods so that the fram is being supported and not the steering components and then set the steering wheel to the straight position and inpsect ALL of the steering and suspension components for the front end.
Without your model number this is quite generic. With a model number I can show you a parts diagram by item number of what to check.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Steering
Look under the front between the wheels at the tie rod that connects the two wheels. It is probably bent up and should be straight. If it's bent, remove it a straighten it.
Jun 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
429 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
