Question about Dell V7 (U1868 ) ( u1868 ) Tape Drive
I have a Sonic program on my computer. Have
I have a Sonic program on my computer. Have always used it but now it doesn't work I have an Windows XP computer. Any suggestions.
  • 71 Answers
Try to uninstall and reinstall the Sonic program. Be sure you have the CD before doing this step.
Posted on Jun 16, 2009
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
Mar 24, 2012 | MGI Software PhotoSuite SE V4.0
Windows 7 will not recognise vdr-m70 dvd camcorder
Panasonic supplied software for the VDR-M70 for Windows 98 through XP on the CD. Due to changes in the OS over time, the installer can't run under Windows 7. Panasonic has not updated the drivers for Windows 7 and Microsoft indicates that it is not compatible with any version of Windows 7.
There are work-arounds depending on your version of Windows 7. If you have the 32-bit OS, try using the compatibility mode. To find out which version of Win7 that you have, click Start > Control Panel > System and Security > System. If the name of the OS ends with x64, then you have the 64-bit version of the software. Otherwise, you have the 32-bit version.
For the compatibility mode, right click on the installer on the CD (browse Computer). Choose Properties and then click on the Compatibility tab. Select Always Run this program as and an older version of Windows (XP). Apply and Save your changes. Then right click again on the installer and choose Run as Administrator.
This may not work (and won't work for the 64-bit Windows 7). If it doesn't work, you need a machine with an older version of Windows. This can be a second computer, a dual boot computer or a virtual computer (if your hardware supports virtual computing). For most options, you will need a licensed copy of the older version of Windows.
If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode from Microsoft in order. Then install the software for the camcorder in XP mode as if it were your only computer. (Of course this doesn't help if your hardware doesn't support the Virtual PC.) Other virtual computer programs are VMWare and Parallels.
Note: you can not directly share files or hardware between the Win7 and the virtual computer. You have to put files on an external drive (optical, flash drive or other external hardware) to share them.
I hope this helps.
Nov 12, 2011 | Panasonic Palmcorder VDR-M70 DVD Camcorder
Added sound forge 6.0 to our new computer with windows 7 and it is not letting us access the program.
Hi m Otto ,
Apparently , the software is not built to run under Windows 7 . Try installing it on an XP computer or install a Virtual XP version with WMWarePlayer on your system to test the results .
Best regards ,
fanaudi .
Sep 27, 2011 | Sonic Foundry Sound Forge 6.0 for PC
Windows 7 will not recognize my v6upl scanner which worked in Windows XP. Problem seems to be that Device Manager sees it as an Unknown Device under the Universal Serial Bus controllers.
Unfortunately, Microtek doesn't support the V6UPL for any Windows OS beyond XP. The drivers are available here: http://support.microtek.com/downloads/bycategory.phtml?slct_tbl=1&slct_mdl=2 .
What version of Windows 7 are you running? Click Start > Control Panel > System and Security > System. If the version name ends with x64, you have the 64-bit version; otherwise you have the 32-bit version.
If you have the 32-bit version, try using the driver from the above site with the compatibility mode. Right click on the .exe file and choose Properties. Then select the compatibility tab. Set the program to always run in the compatibility mode for XP. Then right click again and choose Run as administrator. (You may need to disconnect the data cable and uninstall the Unknown device before trying to install the XP driver).
This will probably not work for Win7 x64. There are workarounds that you can use. You need to connect the scanner to a computer running an older version of Windows. This can be a physical second computer, a dual boot computer or a computer running a virtual version of the older OS. If you have Win7 Pro or Ultimate, or upgrade to one of those versions, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode (in order) from Microsoft. Then install the XP scanner driver in the XP mode program as if that is the only computer running. The only issue is that you can't share files or your printer between the virtual and real computer at the same time. You will be prompted to uninstall the printer if you try to install it on both machines. You can put files on external media to share them. Other virtual computer programs are Parallels and VMWare. However, you need a licensed version of the older Windows OS to use any of the other alternatives.
I hope this helps.
Aug 18, 2011 | Microtek ScanMaker V6UPL Flatbed Scanner
Sonic the Hedgehog CD PC version Windows 7 error. After installing the original gold colored Sonic the Hedgehog CD, and the patch for the program, Sonic CD loads the intro screen, then freezing, and a...
Hi, welcome to FixYa!
Forgive me, but I remembered that Sonic the Hedgehog a rather very old program, which is designed to be running in Windows 9x/ME. I bet that's why it's demanding an MCI driver because it's not compatible with Windows 7.
There are 2 solutions for this.
First choice is you can try to use compatibility mode to run this program. Right-click on the .EXE file of the games (or you can use also right-click on the shortcut on Desktop or Start menu), then go to Compatibility tab, check "Run this program in compatibility mode for", then choose "Windows 98 / Windows ME".
Second choice, you can use VirtualBox, install Windows 98SE or ME on it, and then install the DirectX, remember to install VirtualBox guest addition as well, configure Shared Folder so your Virtual Machine can access to your host OS, then install the game and played it inside your Virtual Machine.
I hope my solutions are working. Thanks for using FixYa!
Jul 06, 2011 | Computers & Internet
Doesn`t work all the time and makes a whirring noise, do i need to buy a new cd/dvd drive?
Before you beginTo determine if the CD or DVD drive displays on the My Computer screen, follow the steps below.
  1. Turn on the computer and remove any discs from the CD/DVD drive.
  2. In Windows 98 and Me, double-click the My Computer icon on the desktop. In Windows XP, click Start and then My Computer .
  3. A CD/DVD drive icon displays on the My Computer screen when Windows recognizes the drive. If Windows recognizes the drive, find and use a section below that pertains to the CD-writing software with the issue.
  4. If the drive does not display on the My Computer screen, go to the Microsoft support website and search for documents on missing CD DVD drive .
RecordNow by Veritas/HP/Sonic does not recognize the CDRW or DVD+RW driveIf RecordNow does not recognize the CDRW or DVD+RW drive, follow the steps below.
NOTE: Install any updates for the RecordNow engine available on the Sonic support web site (in English). Step 1: Uninstalling RecordNowTo uninstall RecordNow to reset the software and cause it to look for the CDRW or DVD+RW drive again, follow the steps below.
NOTE: The steps below pertain to Windows XP.
  1. Click Start and then Control Panel .
  2. Double-click Add or Remove Programs .
  3. Select Record Now and then click Add/Remove .
  4. Follow the on-screen instructions until the uninstaller finishes.
  5. Select DirectCD and then click Add/Remove .
  6. Follow the on-screen instructions until the uninstaller finishes.
  7. Remove any discs from the drives and restart the computer.
Step 2: Installing RecordNow using Application RecoveryAfter Windows restarts, install the RecordNow software to begin creating CDs.To install the RecordNow software, follow the steps below.
  1. Click Start , All Programs , HP Tools or Compaq Tools , and then Application Recovery .
  2. Click Application Installation and then click Next .
  3. Select HP Record Now or Sonic RecordNow! and then click Install .
  4. The installation automatically installs all files. Follow the on-screen instructions.
  5. Restart the computer after the installation completes.
The HP Record Now or Sonic RecordNow! software should now recognize the CDRW drive. Back to topRoxio (Adaptec's) Easy CD Creator does not detect the CDRW driveEasy CD Creator produces an error message when it is unable to detect the drive, such as: There are currently no supported CD Recorders available...To prevent these errors from occurring, follow the steps below.
NOTE: Windows XP is not compatible with Easy CD Creator 4 and earlier. If the HP Pavilion computer was updated to Windows XP from Windows 98 or Me, use the native CD writing ability in Windows XP or purchase and install CD writing software that is compatible. Step 1: Installing updates for Roxio (Adaptec) Recording Software If the recording software is from Roxio (formerly Adaptec), go to the Roxio software updates page (in English) to obtain any software updates that are available for Easy CD Creator (with or without CD Copier or Direct CD). If Roxio still does not detect the CDRW drive after installing the updates, continue to the next step. Step 2: Changing the CD drive letter back, if it changedUpgrading to Windows 98 or Windows Me can change the drive letter to a different letter and make the drive undetectable to Easy CD Creator. To change the drive letter back to F or another previously designated letter, follow the steps below.
  1. Right-click the My Computer icon on the desktop.
  2. Click Properties . The System Properties window opens.
  3. Click the Device Manager tab.
  4. Click the plus sign next to CD-ROM .
  5. Double-click the CD-ROM name and then click the Settings tab.
  6. Under Reserved drive letters , select M (or the previously assigned letter) from the drop-down list. Be sure that both the Start drive letter and the End drive letter are the same.
  7. Click OK , Close , and then Yes .
  8. Restart the computer. If Easy CD Creator continues to fail to recognize the CDRW drive, continue to the next step.
Step 3: Uninstalling Easy CD CreatorIf the above steps fail to make Easy CD Creator recognize the CDRW, recover Easy CD Creator by uninstalling it. Recovering Easy CD Creator resets the software and causes it to look for the CDRW drive again. Be sure that you have the last recovery disc of your Pavilion recovery disc set before continuing.uninstall Easy CD Creator, Step 4: Installing Easy CD Creator using Application Recovery
Jan 17, 2010 | HP Pavilion dv6000z Notebook
Sonic programe wont work ,cant copy disc
Nothing can be done. my advice is to format ur system and re-install xp or vista and download softwares for free from here
Mar 18, 2009 | Sonic RecordNow! Deluxe 7.3
Should i uninstall other burning programs on my computer?
Hi dbarbosa63
I would suggest uninstalling the other software. I have had more than enough instances ehare roxio and other software had conflicts. Remeber to restart after unstallinf the other software to get the drivers they may have used out of the system before installing the roxio.
Regards
Go-Tech
Dec 16, 2008 | Computers & Internet
Unable to open icon T-Sonic 610 MP3 player icon in Win - XP
T.sonic cannot operate after it was formatted in Windows
Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the
default format of the T.sonic. To retrieve the default format, you must link to
http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
Oct 26, 2007 | Transcend T.sonic 610 MP3 Player
XP does not detect player
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Nov 17, 2006 | Transcend T.sonic 610 MP3 Player
Computers & Internet Logo
408 people viewed this question
Alun Cox
