Question about Vehicle Parts & Accessories
Audi A4 ''audi a4 drivers window wont work all others are working ok'' also the lights on the instruments on the door are not iluminated.
  • 39 Answers
In the drivers door jam (Between the door and the A pillar of the car) you will see a black rubber tube with cables inside it.
This is the wiring for the drivers door.
Could be a bad connection between the plugs or even a broken wire.
If the central locking is still working on the drivers door, the chances are that it is the plug on the back of the switch panel in the door.
You may need to remove the door trim.
Watch out for hidden screws in the panels.
Posted on Jun 16, 2009
Audi problem
TRY UNLOCKING FROM PASSENGERS SIDE.IF OK CHECK CLUSTER LIGHT IF IT GOES ON WHEN U OPEN DRIVERS DOOR.IF NOT REPLACE DRIVERS DOOR LOCK.
Mar 30, 2014 | Audi A4 Cars & Trucks
I have a 2003 audi a4 my drivers door is locked and wont open with the key or central locking buttons but the other 3 doors do can u help
If it is cold enough the mechanism could be frozen. If not the actuator is gone and will need to be replaced.
Jan 07, 2018 | 2004 Audi A4
Audi A4 driver door no power
A typical problem for the newer A4's. The rubber tube that goes from the body of the car to the door will flex enough to short the wires out. If you remove the rubber boot and slide it back you can inspect which wires shorted out. I am 99 percent sure this is your problem, I have seen this in 4 other a4's. Hope this helps!
May 23, 2010 | 2004 Audi A4
Where is brightness control for instrument panel on Audi A4 -1996
no adjustment, if dim some ilumination bulbs could be blown.
May 20, 2010 | 1996 Audi A4
Audi a4 1995 1,6l no rpm in instrument and warning
If you've just had the instument changed then its probable that the connector has come loose and will have to be re-connected. It could also be that the instument has failed. Take it back to the mechanic who changed the old one. This assumes that the car drives ok and all the fluids are topped up and ok.
Nov 04, 2009 | Audi A4 Cars & Trucks
On my 2000 Audi A4. the driver information center wont light up (its blank) do i need to replace the whole instrument cluster?
it is probably a bad solder joint.pull the cluster out and look at the printed circuit board with a lense.there is a bulb that lights up the display as well.
Oct 23, 2009 | 2000 Audi A4
Audi A4 02 door wont lock.
CHECK UNDER THE RUBBER BOOT,WERE THE DOOR HINGES ARE, AND CHECK FOR BROKEN OR CUT WIRING. IT IS A PROBLEM WITH THE AUDI A4
Apr 09, 2009 | 2002 Audi A4
Audi a4 1.8t windows, interior light wing mirrors not working
Folks, Just found my problem ...... There's a flexible conduit (corrugated rubber sleeve) between the driver's door and the door arch which contains the wiring loom for the drivers door central locking/door speaker/electric windows/mirrors etc....discovered when I slipped off the sleeve that 4 cables in the wiring loom had broken due to repeated flexing when drivers door was opened/closed over the years (2001 Audi A4). Resoldered broken wires and insulated same....now working better than ever again ...ie dashboard back lighting seems brighter than it had been for some time? Also drivers door loudspeaker is back in action again (hadn't noticed that it had gone).
It's kinda difficult to reseat the rubber sleeving correctly after the repair job...will probably use some silicone sealant on the sleeve to ensure that there is no water ingress to wiring loom afterwards. I'm not too impressed with Audi design people after that, should have used cable that has a better flexibility rating (esp on drivers door!).
Paul.
Sep 24, 2008 | 2004 Audi A4
Vehicle Parts & Accessories Logo
82 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
