Question about Samsung DLP HL-P5663W 56" TV
Samsung HL-P5663W, picture goes black after some time
I have a 56" Samsung DLP TV that I bought approximately 2yrs ago.  Recently it has had a problem where after some time watching the screen will go black.  The time it takes has varied from ~10 minutes to just over an hour.  Changing the channel will usually bring the picture back for 20-30 seconds before the picture goes black again.  My original thought was the bulb, but looking at the back of the set, the lamp appears to be on while the picture is black, and I haven't noticed any dimming.  The audio works fine while the picture is out, and none of the three front LEDs indicate any issue.
  • BW13 Nov 14, 2007
    I have the same problem it's been doing it for awhile, when it goes out 3 led's flash together in an angry face, I wait 5-10min. I can turn it back on, 1/2 hr. later it flickers then blackout again. I figured it was dusty and not breathing properly. I powered it down, pulled power cord,!!!!!(I have to warn you to not do what I did)!!!!! then removed small back cover, removed dust bunnies everywhere, removed screws securing light bulb box, slid box out (it fits into grooves on each side) above small circuit board. There is an airway, there i gently swept the dust out. I then reinstalled light box,(terminal plug is on bottom), after light dust removal, replaced cover, sure to engage cover switch, replug, then power button. NOTHING!?, It tries, but nothing, green lights on boards in back, no light. I have no Idea what happened. I seemed so smooth and easy, no problems. But now I have my basesment 32" in living room now, and my beautiful 56" widescreen on the dining room table. Any help would be appreciated as everyone in household looks at me now, I say "it was going out anyway", it does not help.
  • cdcameron Jan 24, 2008
    I have the same problem with my tv---
I fixed it. Went back in after a twenty min. break, figured if it's broke I can't break it again, might as well try to fix it(out of warranty, so much time on 1st. bulb, after fixing I found out had 8463 hrs. on 1st. lamp! WOWW most i've seen on any strings out there,and I'm really cheap and inquisitive) But this is how I did it. pulled off covers. looked around pulled light box out checked connectors and resistors visually for burns, none found, then I see a clear plastic sleeve covered group of wires it was plugged up at the ballast where i was working earlier but not the other end, so i looked around for the plug to insert it, couldn't see any where. I felt on top of a silver polished panel w/holes allover, there on top, at the right side of the silver panel was a plug for it. I plugged it in by removing fan and cooling fin assembly, for room to work(and good chance to clean dust from the fins and fans. I tilted silver panel down to see the top, after some removing spring loaded screws holding cooling fins, (the screws ave very light spring tension and won't pop out, I swear, keep track of springs for reassembly later) plugged it in(only goes one way, don't force it, flip over if it doesn't fit nicely) replace all removed parts in reverse order and reinstall covers, plug up, and mine powered on almost instantly. After that and spending 2 hrs. online trying to go through all the strings everywhere about these problems. It came down to trial by fire. I hope this helps, reply if it doesn't.
Posted on Nov 15, 2007
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I cannot remove the fan
Here is the illustrate d procedure for the 61'', should be the same.
regards
Posted on Mar 22, 2008
milkburp
  • 416 Answers
SOURCE: DLP HL-P5663W 56
This is a typical well aged lamp. You should get one on order soon so that you have it for replacement. If you like, check out my tips & tricks. I have an explanation of your lamp operation and how to visually inspect is when you suspect it is failing. I hope this was helpful.
Posted on Mar 27, 2010
Samsung DLP TV HLN617W1 picture comes on then goes out after several seconds and all 3 lights flash
Ha the Lamp ever been replaced and if so how long ago? If you have never replaced the lamp then it is time to replace it 1-800-628-1118
Oct 15, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung dlp has dark picture?
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours witch is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen here is a link with the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=BP96-00608A
Sep 03, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
56" screen dlp Samsung
You can find a new Samsung replacement Lenticular screen and fresnel screen for a model # HL-P5663W from a major Samsung distributor at the following links:
Samsung HL-P5663W Replacement Part Fresnel Screen
Samsung HL-P5663W Replacement Part Lenticular Screen
Feb 12, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
2,540 people viewed this question
Jerry Greenberg
Jerry Greenberg
