Replace fuel filter first. Then test the wire connection at the fuel pump before replacing fuel pump. Had that problem on my car once and took me a couple of days to find out I had a loose wire after I spent the money on a new pump. Always good to replace filter anyway and it's fairly cheap.
If you are not getting fuel to the throttle body, there could be a few potential causes. Here are a few things to check:
Fuel Filter: Check to see if the fuel filter is clogged. If it is clogged, it could prevent fuel from getting to the throttle body.
Fuel Pump Relay: Make sure the fuel pump relay is functioning properly. If the relay is not sending power to the fuel pump, it won't run and fuel won't be delivered to the engine.
Fuel Pressure: Check the fuel pressure at the throttle body. If the pressure is low or nonexistent, it could indicate a problem with the fuel pump or a clog in the fuel lines.
Check Valve: The check valve on the fuel pump could be stuck or malfunctioning, causing a lack of fuel flow.
Vent on Tank: A clogged or faulty vent on the fuel tank can cause fuel starvation as the engine tries to suck fuel from the tank but can't due to the lack of air flow.
It's also possible that there could be an issue with the fuel injectors or the throttle body itself, but these are less common causes of a lack of fuel to the engine. It's recommended to have a mechanic diagnose the issue if you are unable to identify the problem yourself.
P1000 OBD-II Monitor Testing Incomplete<br />P1001 KOER Test Cannot Be Completed<br />P1039 Vehicle Speed Signal Missing or Improper<br />P1051 Brake Switch Signal Missing or Improper<br />P1100 Mass Air Flow Sensor Intermittent<br />P1101 Mass Air Flow Sensor out of Self-Test Range<br />P1112 Intake Air Temperature Sensor Intermittent<br />P1116 Engine Coolant Temperature Sensor is out of Self-Test Range<br />P1117 Engine Coolant Temperature Sensor Intermittent<br />P1120 Throttle Position Sensor out of range<br />P1121 Throttle Position Sensor Inconsistent with Mass Air Flow Sensor<br />P1124 Throttle Position Sensor out of Self-Test Range<br />P1125 Throttle Position Sensor Intermittent<br />P1127 Heated Oxygen Sensor Heater not on During KOER Test<br />P1128 Heated Oxygen Sensor Signals reversed<br />P1129 Heated Oxygen Sensor Signals reversed<br />P1130 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1<br />P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1<br />P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1<br />P1135 Ignition Switch Signal Missing or Improper<br />P1137 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1<br />P1138 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1<br />P1150 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2<br />P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2<br />P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2<br />P1157 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2<br />P1158 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2<br />P1220 Series Throttle Control fault<br />P1224 Throttle Position Sensor B out of Self-Test Range<br />P1230 Open Power to Fuel Pump circuit<br />P1231 High Speed Fuel Pump Relay activated<br />P1232 Low Speed Fuel Pump Primary circuit failure<br />P1233 Fuel Pump Driver Module off-line<br />P1234 Fuel Pump Driver Module off-line<br />P1235 Fuel Pump Control out of range<br />P1236 Fuel Pump Control out of range<br />P1237 Fuel Pump Secondary circuit fault<br />P1238 Fuel Pump Secondary circuit fault<br />P1250 Lack of Power to FPRC Solenoid<br />P1260 Theft Detected - Engine Disabled<br />P1270 Engine RPM or Vehicle Speed Limiter Reached<br />P1288 Cylinder Head Temperature Sensor out of Self-Test Range<br />P1289 Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range<br />P1290 Cylinder Head Temperature Sensor Signal Less Than Self-Test Range<br />P1299 Cylinder Head Temperature Sensor Detected Engine Overheating Condition<br />P1309 Misfire Detection Monitor not enabled<br />P1351 Ignition Diagnostic Monitor circuit Input fault<br />P1352 Ignition Coil A - Primary circuit fault<br />P1353 Ignition Coil B - Primary circuit fault<br />P1354 Ignition Coil C - Primary circuit fault<br />P1355 Ignition Coil D - Primary circuit fault<br />P1356 Loss of Ignition Diagnostic Module Input to PCM<br />P1358 Ignition Diagnostic Monitor Signal out of Self-Test Range<br />P1359 Spark Output circuit fault<br />P1364 Ignition Coil Primary circuit fault<br />P1380 VCT Solenoid Valve circuit Short or Open<br />P1381 Cam Timing Advance is excessive<br />P1383 Cam Timing Advance is excessive<br />P1390 Octane Adjust out of Self-Test Range<br />P1400 Differential Pressure Feedback Electronic Sensor circuit Low Voltage<br />P1401 Differential Pressure Feedback Electronic Sensor circuit High Voltage<br />P1403 Differential Pressure Feedback Electronic Sensor Hoses Reversed<br />P1405 Differential Pressure Feedback Electronic Sensor circuit Upstream Hose<br />P1406 Differential Pressure Feedback Electronic Sensor circuit Downstream Hose<br />P1407 EGR No Flow Detected<br />P1408 EGR Flow out of Self-Test Range<br />P1409? EGR Vacuum Regulator circuit malfunction<br />P1409? Electronic Vacuum Regulator Control circuit fault<br />P1410 EGR Barometric Pressure Sensor VREF Voltage<br />P1411 Secondary Air is not being diverted<br />P1413 Secondary Air Injection System Monitor circuit Low Voltage<br />P1414 Secondary Air Injection System Monitor circuit High Voltage<br />P1442 Secondary Air Injection System Monitor circuit High Voltage<br />P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault<br />P1444 Purge Flow Sensor circuit Input Low<br />P1445 Purge Flow Sensor circuit Input High<br />P1450 Inability of Evaporative Emission Control System to Bleed Fuel Tank<br />P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction<br />P1452 Inability of Evaporative Emission Control System to Bleed Fuel Tank<br />P1455 Substantial Leak or Blockage in Evaporative Emission Control System<br />P1460 Wide Open Throttle Air Conditioning Cutoff circuit malfunction<br />P1461 Air Conditioning Pressure Sensor circuit Low Input<br />P1462 Air Conditioning Pressure Sensor circuit high Input<br />P1463 Air Conditioning Pressure Sensor Insufficient Pressure change<br />P1464 ACCS to PCM High During Self-Test<br />P1469 Low Air Conditioning Cycling Period<br />P1473 Fan Secondary High with Fans Off<br />P1474 Low Fan Control Primary circuit<br />P1479 High Fan Control Primary circuit<br />P1480 Fan Secondary Low with Low Fans On<br />P1481 Fan Secondary Low with High Fans On<br />P1483 Power to Cooling Fan Exceeded Normal Draw<br />P1484 Variable Load Control Module Pin 1 Open<br />P1500 Vehicle Speed Sensor Intermittent<br />P1501 Programmable Speedometer & Odometer Module/Vehicle Speed Sensor Intermittent circuit-failure<br />P1502 Invalid or Missing Vehicle Speed Message or Brake Data<br />P1504 Intake Air Control circuit malfunction<br />P1505 Idle Air Control System at Adaptive Clip<br />P1506 Idle Air Control Over Speed Error<br />P1507 Idle Air Control Under Speed Error<br />P1512 Intake Manifold Runner Control Stuck Closed<br />P1513 Intake Manifold Runner Control Stuck Closed<br />P1516 Intake Manifold Runner Control Input Error<br />P1517 Intake Manifold Runner Control Input Error<br />P1518 Intake Manifold Runner Control fault - Stuck Open<br />P1519? Intake Manifold Runner Control Stuck Open<br />P1520? Intake Manifold Runner Control circuit fault<br />P1519? Intake Manifold Runner Control fault - Stuck Closed<br />P1520? Intake Manifold Runner Control fault<br />P1530 Open or Short to A/C Compressor Clutch circuit<br />P1537 Intake Manifold Runner Control Stuck Open<br />P1538 Intake Manifold Runner Control Stuck Open<br />P1539 Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw<br />P1549 Intake Manifold Temperature Valve Vacuum Actuator Connection<br />P1550 Power Steering Pressure Sensor out of Self-Test Range<br />P1605 PCM Keep Alive Memory Test Error<br />P1625 Voltage to Vehicle Load Control Module Fan circuit not detected<br />P1626 Voltage to Vehicle Load Control Module circuit not detected<br />P1650 Power Steering Pressure Switch out of Self-Test Range<br />P1651 Power Steering Pressure Switch Input fault<br />P1700 Transmission system problems<br />P1701 Reverse Engagement Error<br />P1702 Transmission system problems<br />P1703 Brake On/Off Switch out of Self-Test Range<br />P1704 Transmission system problems<br />P1705 Manual Lever Position Sensor out of Self-Test Range<br />P1709 Park or Neutral Position Switch out of Self-Test Range<br />P1710 Transmission system problems<br />P1711 Transmission Fluid Temperature Sensor out of Self-Test Range<br />P1713<br />thru<br />P172 Transmission system problems<br />P1729 4x4 Low Switch Error<br />P1740 Transmission system problems<br />P1741 Torque Converter Clutch Control Error<br />P1742 Torque Converter Clutch Solenoid Faulty<br />P1743 Torque Converter Clutch Solenoid Faulty<br />P1744 Torque Converter Clutch System Stuck in Off Position<br />P1745 Transmission system problems<br />P1746 Electronic Pressure Control Solenoid - Open circuit<br />P1747 Electronic Pressure Control Solenoid - Short circuit<br />P1749 Electronic Pressure Control Solenoid Failed Low<br />P1751 Shift Solenoid No. 1 Performance<br />P1754 Coast Clutch Solenoid circuit malfunction<br />P1756 Shift Solenoid No. 2 Performance<br />P1760 Transmission system problems<br />P1761 Shift Solenoid No. 3 Performance<br />P1762 Transmission system problems<br />P1767 Transmission system problems<br />P1780 Transmission Control Switch circuit is out of Self-Test Range<br />P1781 4x4 Low Switch is out of Self-Test Range<br />P1783 Transmission Over-Temperature Condition<br />P1784 Transmission system problems<br />P1785 Transmission system problems<br />P1786 Transmission system problems<br />P1787 Transmission system problems<br />P1788 Transmission system problems<br />P1789 Transmission system problems<br />P1900 Transmission system problems
problem is the main jet --probably blocked or insufficient fuel flow due to bad rubber hose from tank or corrosion in the carby
ethanol did affect rubber parts so you may have to pull and check all fuel related parts
Fuel system too lean (too much air, not enough fuel) vacuum leaks being the most common, you might want to check for a bad airflow sensor, plugged fuel filter, clogged fuel injectors, low fuel pressure, exhaust leaks, a bad PCV valve, bad oxygen sensor, stuck open purge valve. mass air flow (MAF) sensor are fairly common too. Sometimes the mass air flow sensor just gets dirty and gives false air flow readings.
P1137 is HO2S Bank 1 Sensor 2 Lean Or Low Voltage. Oxygen sensor is reading a "lean condition". This code probably is stored from the rough and low idling. So it sounds like you maybe having other issues causing this P1137 code to come up. For lean conditions read this: 1. Vacuum leaks - check for failed or loose vacuum lines, leaking intake gaskets, intake air tubes loose or any other source of un-metered air leaks (leaks after the Mass Air Flow Sensor) 2. Restricted fuel filter or bent/pinched fuel system lines 3. Incorrect input from other sensors, such as the Mass Air Flow Sensor/cam or crank sensors, which may not always drop a separate code 4. Engine misfire ? Yes I know this one may seem weird. You might think that if there is a misfire then you will have all that unburned fuel and it should read rich; right? Well the O2 sensors read only oxygen content in the exhaust, so if you have all that unburned fuel from incomplete combustion then, you guessed it, you also have all that unburned oxygen. High O2 content in exhaust equals a lean reading!
fuel pressure regulator on the fuel rail is probably it or the egr valve is stuck open allowing burnt fuel to flood the intake, im leaning towards the fuel pressure regulator because the o2sensor is probably reading rich or if its reading lean then i would choose the egr valve . good luck
