Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Belkin Wireless G Plus MIMO Security Problem
Need help!
How do I set up security for my router. When I tried it going to the router website and setting the security feature up, I could not get back on the system with my laptop wireless Belkin card and my desktop that the router (Belkin Wireless G Plus MIMO) is connected to. I had to push the small reset button on the back and get it back to normal. I called Belkin but had a hard time understanding them (India) and they took me though the small steps eventually, got the system locked back up.
Re: Belkin Wireless G Plus MIMO Security Problem - Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Routers
Thank you so much, you help me a lot.
Posted on Nov 17, 2007
    Problem Solver:
  • 20 Answers
100% free, but 100% qualfied experts to help you.
Posted on Oct 31, 2007
0 characters
3 Points
What is the network secuirty key for my belkin 54g wireless router? Help!
1. network security is setup by the user
You either have it or you will need to go through the set and establish a new network security key again via the CD that came with the router device.
Apr 15, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Where can i find the security key for my belkin router
Login to your router:
-- type into a browser's address field ""
-- type user "admin"
-- type password "(whatever you set it to)"
-- go to wireless settings and look for paraphrase, security key, WEP key, etc.
Aug 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Set up sercurity
login to the router page in that select option called security in that select wepkey in that you can type you password then save the settings and reboot your router and check it
Jun 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have belkin g plus mimo router which states connected with limited or no connectivity help please
u are typing in the wrong wireless password. acsess the router by using the IP: in the internet explorer and click security in the left side of router's set up page.
Jan 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have BELKIN G PLUS MIMO and wireless dont work,what is the problem,and i whant fixed that problem,help.
Wireless feature of the router works all the time. If it doesn't work, the router is defective. I believe you just need to configure the wireless settings of the router manually. The router has a setup page where you can change a lot of wireless settings to synchronize to your wireless computers. You can open it through using your Internet Explorer. Try to customize the channel to 11, change the Network Name and enable wireless security as well.
Oct 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Lost password into router need reset
Use the reset button near where the AC adapter plugs in. Hold it in for at least ten seconds. This should set it back to factory, allowing you to set another password.
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
May 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Security of wireless network
You can directly connect your computer to the router thorugh the routers "internet" port and then re-run setup. OR you can type the IP address of the router into your address bar (the default is tipically or and then enter the router username and password (I believe the Belkin default is username:"Admin" password:"Password") in the admin control planel look for a "wireless security" tab. You can then define your wirelss security settings there. Just remember to configre the same settings on all devices that will connect to the router.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g plus mimo router
the PS3 connects to router via a crossover cable yes?
you may need to manualy set the PS3 as a trusted acception in the routers security system, (using either its MAC address, or its set IP address if u manually gave the PS3 one)
Dec 06, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
If you really want to secure it just set a password for your PC so it can't be open by other user.. ^_^
Nov 17, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
605 people viewed this question
Top Belkin Routers Experts
 C. Dante
C. Dante
steve morris
steve morris
Are you a Belkin Router Expert? Answer questions, earn points and help others
