Question about Kenmore 24032\24036 Top Load Washer
I have a top loading washer model #4420716...it will spin but make very loud noise I am wondering if a belt or something broke...it sounds like the basket is hitting the sides of the washer.
  • 10,515 Answers
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Check and let me know.
Thanks.
Posted on Jun 16, 2009
Makes loud squeal noise when stoping to change cycles
when in spin out cycle when first comes on makin a noise like something is in the pump i check it and the pump is clear must be maybe lower bearing assembly sounds like something is lose or broke it also stops instancely at end of cycle what could this be
Jan 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Magic Chef Clothes washer model CAV2004AWW
Something locked up on the transmission then the drive belt broke. Put on a new belt and try a spin cycle, if it works but it won't agitate then the trans will need replaced.
Feb 28, 2009 | Magic Chef CAV2004A Top Load Washer
Amana dlw330 washer belt urned & broke again
Had the same problem on a machine I worked on. Changed the belt... was burnt and broken. Second time I replaced the belt, I ran it through all of the cycles and listened to it on SPIN cycle.. Although it's spinning.. it's making an extremely LOUD noise... It's the Spin bearing that is gone out. When a load is put in, and in spin cycle, the bearing is oveloaded..(being dry).. and putting extreme pressure on the motor and belt. When the drum reaches a point where the bearing just won't spin, the belt stops, and spins on the motor pulley, wearing it through.. (And smoking a great deal).. until it breaks.. again. I believe the top "Spin bearing" is about 75.00 or so.. and a BEAR to replace. Hope this helps
Feb 26, 2009 | Amana DLW330RA Top Load Washer
Grouling noise in the spin cycle
First, check the belt (located in the bottom of the unit) and if it shows signs of wear (black dust) and shiny sides on belt and black marks on the motor, transmission, and water pump pulleys - replace the belt. The motor is spring loaded and acts as the tensioner up to a point of too much wear on the belt.
You will need to tilt the washer about 45 degrees and prop it to keep it from going all the way over (just makes it more difficult to right it later). Pop the belt off by rotating it while pulling the belt off the edge of the transmission (larger) pulley. Again, the motor pulley is spring loaded and will flex appropriately. Reverse the process with installation of a new (exact replacement part number).
If this doesn't fix the problem, you may have to call the Maytag Repairman. They would have replaced the belt anyway and would probably charge $50 + for the belt and installation.
Dec 21, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Loud noise in slow down spin mode.
when it is in high spin then you stop the washer it makes a thumping noise until the basket stops sort of like a flat tire sounds to me like you need a drive block
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Spin cycle doesn't work with loud noise
yea sounds like a bad motor coupling ( this machine equivelent to a belt).
Mar 06, 2008 | Whirlpool LSR7333 Top Load Washer
Slow to spin and making a loud noise.
Control boards don't growl, the fry out and die. Sounds like a drive train problem to me. If it's a front load machine, the spindle/bearing assy. has gone to washer heaven. If it's a top load machine... could be the transmission, brake/clutch assy. or the tub bearings. In either case, if it's less than 5 years old, the drive system will be warrantied through the manufacturer. If you could provide a make and model number, I could narrow this down to a fine point.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
