Question about Samsung VP-D103i Mini DV Digital Camcorder
Recording very snowy and blurred.
When playing back recording the picture is very snowy and blurred. Please help!!!
  • doris_cerfon Jun 16, 2009
    where do i buy a mini-dv head cleaner tape
  • Samsung Master
  • 19,396 Answers
If recordings are only blurry and snowy on playback on camcorder, but are OK on a different camcorder or on computer, then the problem is a dirty magnetic head. Use a mini-dv head cleaner tape. If recordings are blurred even on pc or on a different camera, then there is a fault. Faulty CCD sensor, faulty digital board, problem with internal ribbon connector, and dirty or defective lens assembly can cause this kind of problem.
Posted on Jun 16, 2009
Snowy screen when I play a DVD
hi!!!!
try to change the cable!!!
may that helpS :)
Sep 27, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Picture rolls on playback
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
http://www.pcconnection.com/IPA/Shop/Product/Detail.htm?sku=7632166&oext=1038A&ci_src=14110944&ci_sku=7632166
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
I'm using a coax cable from symphonic vr-701 to tv and trying to record. it acts like it is recording but just shows snowy image on playback
Coax from wall to coax in on VCR and Vcr Coax out to in on set.
Whatever channel vcr is on this way it will record and pass to set.
Check first you have playback from VCR to TV alone, could have dirty or blocked video heads which in record will just record no watchable picture. Hookup or blocked video heads are most likely.
Dec 13, 2012 | Symphonic Televison & Video
My camcorder will not record.
i have a jvc GR-C1 camcorder. When i press record i can see it recording through the view finder. When i play back what i have recorded it shows what you see on an emply tape, nothing. Can anyone help me. Thanks.
Jun 11, 2009 | Panasonic Palmcorder PV-L452 Camcorder
Camcorder recording troubles
Dear elfox33
Your camcorder has dirty/clogged video head problem. Please use Video Head Cleaning Cassette Video-8 type to clean it. Hope problem will be solved.
Mar 18, 2008 | Sony Handycam DCR-TRV250E Digital...
CCD-TRV308 Recording issuses
When was the last time you "cleaned" the heads? Use a good commercial head cleaning tape. They have both "Wet" and "Dry" types. I prefer the "wet" over the dry. I think it does a better job but they are hard to find sometimes.
you can also do it manually with "foam" swabs and "methanol1.gif". Alcohol works but the methanol leaves less residue behind.
If that doesn't solve the problem the next step would be to take it to a repair shop for cleaning and re-alignment.
Jan 29, 2008 | Sony Handycam CCD-TRV308 Camcorder
My picture is really snowy
Capasitors on the power suply are failing or they have a cold solder joint. Take the back cover off and run a fan on the power suply to see if this problem stops. If it does the run smaller fans to track down the bad capasitor. There durt cheap to replace!
Jan 22, 2008 | Televison & Video
Camcorder problems
dear sir, Please check with by playing pre-recorded cassatte in the camera( that if you know the recorded picture is good. thank u. reply me.
Jan 12, 2007 | JVC GR-SX24 S-VHS-C Analog Camcorder
Playback quality problem
A couple of things could be causing the problem. When recording, your movements with the camera could have been too quick or jerky. Try putting the camera on a flat surface or on the tripod and record for 30 seconds. If the playback picture is still bad, then it's possible that the video heads are dirty or worn out. Consult your nearest RCA authorized service center for head cleaning or replacement.
Sep 06, 2005 | RCA CC-432 Camcorder
Samsung VP-D103i Mini DV Digital Camcorder Logo
298 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
