Question about ASUS Computers & Internet
I have just bought an ASUS VW246H - has slight ghosting
I have just bought an ASUS VW246H working it through a switch box between 2 PCs. I have connected it to the back of the pcs directly and still have the same problem. I get a slight (and annoying and tiring on the eyes)ghosting. Tried all sorts of resolutions and used the automatic adjustment with the ASUS. When I press this it actually goes sharp but only as it is sort of focusing but ends up same as it started.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 848 Answers
I have just bought an ASUS VW246H - has slight ghosting? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
5E 0NC02 001 4H 0NC02 A01 ASUS 5E 0NC02 001 Power Supply Backlight...
Posted on Jan 14, 2015
3 Suggested Answers
randy320sgi
  • 121 Answers
SOURCE: Ghost Image
mark165,
Are they both about the same age? Also have you recently added a device that is sitting near the monitors such a an external hard drive, printer, new speakers or power cord or cable next to or against the monitor cable? I sounds like EMI to me, shield the cable or plug of the offending devices into another outlet away from the monitors to test that theory, or having them on a separate surge protector should eliminate the noise you are reporting. Some go as far as adding UPS with line filtering (or conditioning) for the devices - you see it with home theater setups when the TV, computer, games and stereo are all plugged in the same outlets on the same home circuit.
randy320sgi
Posted on Jan 12, 2009
efs_perpends
  • 1996 Answers
SOURCE: shadows around the objects
One common cause of ghosting is an inferior monitor cable. Remove any extension cables and check again. The monitor may be getting interference from another device nearby, such as a printer, for example. Try turning off/ disconnecting other devices and see if the ghosting disappears. If so, you could buy a better shielded cable, or rearrange your components to prevent the interference.
That would be a simple fix if it works....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 24, 2009
Manual for ASU-T102H-DR-GR
https://www.asus.com/ca-en/2-in-1-PCs/ASUS_Transformer.../HelpDesk_Manual/
  1. Cached
  2. Similar
ASUS Transformer Book T100HA. Overview · Specifications · Gallery ... Description, User's Manual for Simplified Chinese Edition. File Size, 6.83 MBytesupdate ...
Manual & Document - Asus
https://www.asus.com/us/2-in-1-PCs/ASUS_Transformer.../HelpDesk_Manual/
  1. Cached
  2. Similar
There are 3 download servers available on ASUS Download Site - Global, China and P2P. Each server provides exact the same content no matter where you ...
ASUS Transformer Mini T102HA ' 2-in-1 PCs ' ASUS Global
https://www.asus.com/2-in-1-PCs/ASUS-Transformer-Mini-T102HA/
  1. Cached
The ultra-thin, feather-light, 10.1-inch ASUS Transformer Mini is two amazing devices in one! Built from magnesium-aluminum alloy, it's a less-than-800g ...
[PDF]Manuale utente (e-Manual) - Asus
dlcdnet.asus.com/.../ASUS/.../T102HA/0410_I11845_T102HA_V3... - Translate this page Jul 25, 2016 - ASUS Tablet e ASUS Mobile Dock e-Manual. INFORMAZIONI SUL ...... T102H Mobile Dock, H102H Mobile Dock,. R106H Mobile Dock.
asus transformer user manual - YouTube
https://www.youtube.com/watch?v=M33hXCvS4Vc&list=UUy74e...d4uTA...
  1. Cached
Dec 20, 2016 - asus transformer tf101 dock user manual ... asus transformer tf101 keyboard dock manual ... asus transformer pad tf300t owners manual.
Dec 30, 2016 | ASUS Tablets & eReaders
Have a asus vw246h monitor will turn on and show asus and no signel and then no screen and power light goes red
Have a asus vw246h monitor will turn on and show asus and no signel and then no screen and power light goes red? This trouble maybe power supply or inverter boards is defective.
Apr 07, 2013 | ASUS VW246H 24 inch LCD Monitor
Asus DVI and HDMI connection not working on monitor
Asus DVI and HDMI connection not working on monitor? This trouble maybe power supply or inverter boards is defective.
Dec 25, 2012 | ASUS LCD Monitor
I'm getting a "e<" error
I'm getting a "e<" error? This trouble maybe power supply or inverter boards is defective.
Sep 08, 2011 | ASUS VW246H 24 inch LCD Monitor
Asus VW246H monitor has backlight problem. I hooked VGA up to laptop and the monitor turns on but then 2 seconds later it goes very dim. how do i change the backlight settings?
how do i change the backlight settings? This trouble maybe power supply or inverter boards is defective.
Mar 29, 2011 | ASUS VW246H 24 Widescreen LCD Monitor,...
How to increase scren resolution I have bought a 21.5 inch widescreen Asus monitor & am running windows XP but do not have the resolution sugested every thing looks small & long when looking at...
read this article of microsoft about changing resolution
http://www.microsoft.com/windowsxp/using/setup/personalize/resolution.mspx
Note: you need an HDMI cable to change the resolution of your pc to 1920 x 1080
Jan 21, 2011 | ASUS VW246H 24 Widescreen LCD Monitor,...
New asus vw246H monitor. the volume only goes down. how do I bring it back up?
New asus vw246H monitor. the volume only goes down. how do I bring it back up? This trouble maybe power supply or inverter boards is defective.
Oct 30, 2010 | ASUS VK222U 22" Monitor
Input select button to switch between hdmi/dvi/vga is stuck. cant use any other buttons on the monitor except power. if pushed it continues to cycle thru the three until i pull the button out a little....
Unless there is simply some dirt or dust caught in it, I would imagine that the button has lost its 'spring' or bounce-back ability which means that either you can take the big risk of attempting to fix it or come up with some other clever way to give it bounce.
Jul 03, 2009 | ASUS LCD Monitor
Computers & Internet Logo
459 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
