York I am looking for a Diamond 90 York Gas Furnace Repair Manual. I hope you can help me find one.... Thank you. I need to determine what the blinking light means so that I can repair the problem... It doesn't want to push out heat....
I have an old York outside compressor/coil/fan unit, CDHF36-6A, that I need to replace as it is no longer repairable. What is the capacity of this unit and what Carrier unit would be a good replacement?
Posted on Jun 28, 2008
  • 1,420 Answers
You may already have the info you need. Look on the reverse side of the access panel on the unit. Typically they have a diagnostic schematic next to or combined with the wiring diagram. York is owned by Johnson Controls and you can contact then at 877-874-7378 if you don't find the diagnostic codes I refer to.
Posted on Nov 01, 2007
York diamond 90 furnace burners won't ignite ... igniter glows for a few seconds then clicks off, no burner ignition. Tried resetting the furnace by powering off and then setting thermostat to call for...
The thermocouple could be defective. If this is a high efficiency York furnace, the stack blower should start and run first. If it doesn't the blower controller may have failed.
Dec 06, 2013 | Heating & Cooling
York diamond 80 manual
where is the air filter located on a York diamond 80?
May 03, 2013 | Dayton Gas Furnace Heater
Where is the pilot on the york diamond 90 furnace
there is no standing pilot on your 90% AFUE furnace this is a hot surface ignition
Mar 05, 2011 | Heating & Cooling
I have a York Diamond 90 furnace and when i try to start it, the pilot light goes on then it shoots the flame into the furance, but will shut down a minute or so after that. It sounds like the blower is...
The furnace is not sensing the flame. Turn off the power.
There is a metal rod in front of the last burner to light. It is corroded and needs to be cleaned. Its the flame sensor .
take the 1 screw out holding it in to the bar and scrub it with some steel wool till shiny. replace and turn on furnace. all should be fine.
Mar 30, 2010 | York Furnace Draft Inducer Blower Fasco #...
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
Gas furnace
Hi check out the pressure switch clean the air filter and check out the fan control see if this is clean
Feb 16, 2010 | York Furnace Draft Inducer Blower Fasco #...
90 + gas furnace. inducer full of water
need help with gas furnace put in new presure switch and it worked for a while now i have to blow into it to get it to turn on ignitor .
Dec 05, 2009 | York Furnace Draft Inducer Blower Fasco #...
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
Owners Manual
York Corporate Headquarters
631 South Richland Ave.
York, PA 17403
Phone: (717) 771-7890
Contacting York
York International Corp.
P.O. Box 1592
York, PA 17405-1592
Phone: (877) 874-7378
York Website
York was purchased by Johnson Controls in 2005
Johnson Website.
I cannot find an actual manual online. I hope this information helps you. Good Luck.
Dec 27, 2008 | York Yankees Bedding MLB Comforter
Heating & Cooling Logo
3,102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
