Question about Crown CE2000 2-Channel Amplifier
Left speaker output makes speaker sound cracked but ive switched both speakers left to right even tried new chords
    President:
  • 2,992 Answers
It's pretty clear from your problem description that there's something wrong with the amp's left channel. You've already tried switching speakers and cords so that leaves the amp itself as the problem. This could be something simple like a dirty level control. You can try using control cleaner spray (not WD-40!!!). It might also be caused by solder connections that have developed or components that have failed, which would need professional service. Take this to a shop that has the right tools and expertise to diagnose and repair the trouble. Your local musician's store should be able to suggest a servicer if they don't have their own shop.
Posted on Jun 16, 2009
VSX-4800 receiver. Why is there no left channel audio output?
It is likely that the left channel output stage has failed but there can be problems with that A + B speaker switching. A defective switch can cut output.
Nov 08, 2015 | Pioneer Audio Players & Recorders
Left speakers do not work
As power amps are just two amps joined together all you need do is identify the left channel and compare it with the right. Ignore any parts common to both channels. The first thing to do is a visual check. If something looks broken burnt, or odd compared with the right channel then you have probably found the culprit. I suspect you could have a power output failure. It might be that the output devices are separate transistors. They might need to be replaced.
By the way just follow either the internal speaker leads or the connections to locate the right and left channels.
Nov 10, 2017 | Yamaha HTR-6130 Receiver
I have a Kenwood stereo receiver model k2 3600 , the left speaker keeps going out , the right speaker works fine. I've tried adjusting the speaker wire for the left speaker, and I always end up having...
HI,
BASED ON THE INFO YOU GAVE I HAVE SOME SUGGESTIONS BELOW..
1, switch the working right speakers cable to left output and problem left to right (from the back of receiver -not from the speakers it self..) to see if problem continues..
2.After switching them ,if it (old left new right one ) still stops left speaker cable may have short ( a tiny cable inner pieces may touching to other side ) at either at the back of receiver output or at the end ,at speaker input .
make sure you control it carefully...if the problem persist please contact to me..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Thanks
Jun 17, 2011 | Kenwood Audio Players & Recorders
I have a set of speakers: 2 speakers and one subwoofer. The problem I am encountering is when I plug in my ipod to the system, only the right one works. The left is completely silent. However, one time...
Try a different cord (not "chord") between your iPod and your speakers.
Make sure that the iPod is not "panned" (100% right audio and 0% left audio), but is "50/50".
Similarly, make sure that the computer's sound is not "panned".
Mar 26, 2010 | Kinyo SW-4109 Computer Speakers
No sounds from the left speaker even with the balance turned fully to the left. all connection are fine.
Check the speaker, switch the left and right ones and see if the left speaker still has no sound. If it works the speaker is bad, if it doesnt your left output is bad...
Dec 06, 2009 | Sony TA-FE370 2-Channel Amplifier
I don't have any instructions so i don't know how to hook up my speakers and the t.v for surround sound i have a carver avr 100
You should be able to online to the manufacturer of your products and download manuals. However, I will try to help.
Connect the sound output cables from your DVD player including, left/right(white/red) as well as the Coax output/input if your DVD and your Carver each have this feature for enhanced sound on certain DVDs, and connect to the matching DVD inputs on your Carver.
Then, connect your DVD video output either by use of your RGB(RED/GREEN/BLUE cables or an S Video cable to your the matching video inputs on your t.v.
On the back of your Carver, you will find outputs for left and right speakers, connect to the left and right speakers with proper wire. Make sure that the 2 conductor wire is connected with the same side(polarity) on all speakers for the best sound quality.
You will also find rear channel left and right outputs on your amp, connect those to your rear right and left speakers.
Connect the center channel speaker to the center channel speaker output on your amp.
If your Amp has a sub-woofer output and you have a subwoofer, make the connections on that as well.
Test all of the speakers with a feature that many amps have on the menu using your remote, simply called test. if all speakers are connected correctly you will be able to hear each one as they are individually tested by the amp. Hope this helps out.
Oct 05, 2009 | Audio Players & Recorders
Left side output
Sounds like there is a short somewhere on the left channel inside the amp. not easy to fix without seeing the unit.
Jun 16, 2009 | Crown CE2000 2-Channel Amplifier
Crown CE2000 2-Channel Amplifier Logo
184 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
