Question about JBL MR-17 Sirius-Ready AM/FM/CD Receiver Controller
Marine jbl stereo is freaking out. volume goes up all by itself
Marine jbl stereo is freaking out. volume goes up on its own, mode and channel buttons "stuck". will play a CD but you can't go up or down to songs. pressed the reset button and it resets, but continuously scrolls through FM radio stations. Mostly the volume will be set at 15, then suddenly it goes to MAX and you have to turn off radio switch to get it to stop. seems like it is really a connector problem. only had the boat for 1 year, 3 months
Benimur
  • 6966 Answers
SOURCE: jbl marine mr-17 all funtions are frozen
Initially, have you tried a full hard reset? The reset button is at the panel at the back of the faceplate, bottom left side. Of course doing so will also erase all presets and user settings & configurations.
Additionally, pls verify that the multiple contacts pins are clean, free of corrosion and makes a positive contact with its mate at the rear of the faceplate. If the unit is used in a salty environment, it may be necessary to manually scrape of whatever blue green build up develops between the connector pins and the plastic insulator. You can try using an old toothbrush and WD40.
Further to check are:
1. the red, yellow and black wire are tightly connected where they are supposed to be connected. If the unit is used onboard, it might be to your advantage to likewise check the grounding system;
2. one of the rear connector is for a remote, pls likewise check that none of the pins are shorting and no presence of any corrosion.
If problem persists, it may be necessary to seek the services of a qualified professional as this involves opening the unit up and tracing the circuitry of the logic/controller circuit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 04, 2008
jango2
  • 38 Answers
SOURCE: AM/FM radio on boat,
First thing i'd do here would be to investigate if the electromagnetic interference is coming in through the supply feed. I would bring another battery on board (Charged fully), one that isnt connected to the boats electrical system and see if the emi still afflicts reception. If it stops or reduces to a permissible level one can attack the problem with emi suppressors and filters. A good place to start would be the alternator, try suppressing the emi at source.
The second path the emi takes to pollute reception would be via air straight to the units antenna.
The solution sought here might not be a single remedy but a total of 3 or 4 tweaks, each leading to a percentage improvement. try shifting the antenna too, maybe shielding might contribute some.
Jango
Posted on May 27, 2008
  • 5 Answers
SOURCE: USA - EUrope FM band stations frequency differences
I have a car stereo purchased from the US and I can’t pick up all radio stations in Europe/UK, what can I do?
If you have purchased a car stereo from the US you will find that it will not pick up many European radio stations. This is due to the fact that US radio frequency steps are different to here in Europe.
You may be able to set the tuner to European stations by following this procedure.
Press and hold down the SRC button to power down the unit completely.
While the unit is off press button 1 & 5 together, while momentarily pressing the SRC button.
If this does not work try the following proceedure;
Press and hold buttons 1 and 5 together, while momentarily pressing the reset button.
If this does not work then the unit is not designed to pick up European frequency steps.
Posted on Sep 16, 2008
TOLhamRadio
  • 509 Answers
SOURCE: 2007 Chrysler 300 , AM radio not working , but FM works fine
Usually when you lose only AM it is an antenna issue. Check for a loose antenna plug on the back of the radio or connection to the antenna.
Posted on Aug 02, 2009
SOURCE: I have a CD / Radio in a Jacuzzi. I opened the
Hot Tub with working JBL MR4 was bought, moved to my house...wired up tub, lights all work fine buuuttt the JBL MR4 doesn't...power is to the 110 box under the radio, it has been re- connected according to the manuel and previous set up... the faceplate totally lights up in all possible configurations so you can't read the display...can read USA and countries on top, the CD area I can read and 2 sets of black increment bars areon each side of the faceplate display...only button I seem to get a response from is the power on/off as it lights up...as i turn the vol it blinks with each notch display on then off...I disconected faceplate and reset button , no effect...repowered(no battery seperate hookup as this a hot tub not a boat,red and yellow are wired together).????any ideas on whats wrong???? CD goes in and out???? austinlmiller@comcast.net
Posted on Mar 21, 2011
Radio changes stations by itself and volume goes up and down all by itself. just not working properly. whats going on?
My solution was just to buy a new wired remote on ebay for $50. That way I had the same dimensions for the cutout on my center console. Essentially the remote is a remove and replace item. I bought one in chrome and just traded out my old cover and bezel which was a grey plastic.
Jul 15, 2012 | JBL Mc19 Chrome CommanderRemote W Display
I have a jbl mr-145 in a hot tub. It keeps powering on and off???
I have the same model stereo in a brand new hot tub that was having the same issue. To fix it all u need to do is pull the front cover off to access the pump controls and in there you will find a black box where a power cable runs yo the stereo. There are two screws that open a little door in the black box. In there you will need a small flat head screwdriver to move a redswit over to the 110 volts position. Turn the radio on and it should work. That black box just controls the power to the stereo.
Oct 09, 2010 | JBL Marine Audio Wired Remote
My JBL Marine Hot tub Sterio quit working suddenly?
JBL is at best a low quality marine grade brand of stereo. It is now garbage. I have worked on hot tub stereos for many years, PolyPlannar is the only one that is any good. If it was bought 30 days ago, where's your warranty?
May 31, 2010 | JBL Am/Fm/Cd 180 Watt Marine Audio System
I have a JBL MR-17.2 Sirius Ready stereo
To get your Sirius ID number from you MR-17 JBL stereo, select the Mode button until it displays "Sirius". Then push and hold the Mode button for a couple seconds and it will chirp and display 3 blank spaces. Enter three zeros, "000" in these 3 spaces. The Zero is the loud button labeled "LD". When you do that, it will display your Sirius ID number. :)
May 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
Auxillery in question
yes you can hook up your mp3 to an aux input on a stereo not sure what you mean by converter typically it is done through a 3.5mm - 3.5mm standard audio cable. and in order to do this your reciever must have an aux input of course and if so then you can toggle the mode of input by pressing the Mode or button that switches from radio to cd etc or consult with your users manual to find out how to switch and if aux input method is supported
Feb 15, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
Very strange audio problem
You probably have the set in the SAP mode is the only explanation I can give you.
Apr 23, 2007 | Sharp 27N-S100 27" TV
Car Audio & Video Logo
249 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Morne Olivier
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
