Question about Eclipse EA3422 Car Audio Amplifier
Car speakers cut out (no sound) when volume turned up
Hi I recently purchased a new stereo consisting of...
Head Unit: Sony CDX-GT770
http://www.sony-asia.com/product/cdx-gt770
Amplifier: Sony XM-ZR602
RMS = 60W x 2
http://www.sony.com.au/product/xm-zr602
Speakers: Option Audio OA60C
RMS = 110W
http://www.optionaudio.com.au/speakers_oa60c.php
My problem is that when I turn the HU up past 25 the front speakers stop making any sound. When I turn it back down to around 5 they will kick back in though.... this problem has only started today.It appears to be only the left hand speaker that is causing the issue but it shorts both of them out.
I installed the amp using a store bought wiring package and I also bought some heavy duty speaker wire. The sensitivity on the amp is set on 2V and I have a Low Pass Filter set on 100Hz in my HU as I am also running an sub off a seperate amp. I have checked the speaker wiring for any possible earths but am unable to locate any, I couldn't find my multimeter (bugger).
Anyhow if anyone could help me with this problem I would greatly appreciate!!!!!
Thanks.
  • 39 Answers
I would check the crossovers.
If you are turning it up too loud, then the amp may be clipping (into distortion) and this is then setting the protection circuits off in the crossovers.
Posted on Jun 16, 2009
Hi I have a sony CDX-GT500U car radio. The problem is that when i turn the volume up over 20 it cuts out. What can i do to fix this problem?
Check pos and neg wires on speakers and radio they may be crossed.Does the radio have bass to it or sound like tweeter
Mar 20, 2011 | Car Audio & Video
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Sony cdx m610 resets itself at half volume
You have a shorted speaker or speaker wire. If a wire is touching metal lightly it may not have full continuity (short) and will work until more voltage (volume) is sent to the speaker and causes the short. Disconnect all speakers at the radio then turn the unit back on. Turn up the volume and see if it cuts out. If it stays on, re-connect speakers one at a time and test. Once you find the problem speaker, disconnect the wire at the speaker then test again. This will eliminate the speaker itself as the problem. Test again. If it still shorts, trace the wire from dash to speaker and look for a cut in the sheathing exposing the wire. Repair or replace the wire and you should be good to go. If the unit cuts out with all speakers disconnected, the problem is internal and will need to be serviced. Before you repair/ or replace the unit either check all the wiring and the speakers or have someone do it for you so it does not give you a repeat performance. Hope this helps.
Oct 01, 2009 | Sony CDX-M610 CD Player
Sony radio sub outputs don't work at all
you may need a new head unit. it sound like you have lost the fron rca hook ups on your unit. common prob. usually cause by a surge traveling then the rca cables. i myself have had this happen and there is nothing you can do to the unit to fix it.
Sep 26, 2009 | Sony XS-V1330 Coaxial Car Speaker
My face plate was stolen out of my truck. Thr operateing instructions say cdx-gt200 and cdx-gt20w. How do i determine the proper model without the face plate and can I order a replacement?
remove the stereo from your truck. underneath the head unit itself WILL have a model number along with serial number, wiring instructions, etc............. but be warned that Sony WILL charge top dollar for the faceplate, which in turn will have them sayin somethin like "We recommend buying a new unit as the faceplate will cost nearly the same price as a new unit". In saying that, ALL Sony car stereo wiring looms fit each other, so no need for reinstalling the wires. so if u can get a cheap one without loom, then you'll be fine
Jul 29, 2009 | Car Audio & Video
I need a color code for a Sony Xplod CDX-GT23W.
Guessing that you don't still have the owners/install manual.
On the back of the head unit there should be a group of unused/unconnected wires (with any luck they will be marked), one or more might be an amp turn-on or power antenna lead, so I suggest (with the unit turned on) testing each wire with a DC voltage tester so as to identify and separate any leads supplying 12+ volts. the remaining group will consist of speaker leads. Trial and error testing will determine the proper L & R rear speaker leads.
Good luck
Aduz
Mar 30, 2009 | Sony XPLOD CDX-GT200 CD Player
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
Sony cd changer cdx-646...no card remote commander to release security code
Hi the CDX-646 is not coded. it must be your head unit thats coded.what model is the head unit?
you can get your code @ www.carradiocode.co.uk
for 33.50 if its one of the models listed you will nedd the remote comander tho.
Mark
www.blueice-electronics.co.uk
Feb 24, 2008 | Sony CDX-646 10-Disc CD Changer
Sound only coming from one side
you should have 3 leads going into you multi changer, two rca's and one bus lead. power up the unit and remove the first rca cable if the music goes off unplug the second rca and plug the first rca where the second was plugged in, if the music comes back on then the multiloader is working fine and you need to check the radio controller and its connections
Nov 06, 2007 | Sony CDX-646 10-Disc CD Changer
Re: Stereo cutting out
try this: turn it off. spin the volume control back and forth, nearly full range of motion, very rapidly and for a long time (about 3 minutes). repeat for bass control. try stereo. any improvement? if so, what you just accomplished was to wipe the dust off the potentiometer's electrical contacts.
Jun 02, 2007 | Sony CDX-GT210 CD Player
Eclipse EA3422 Car Audio Amplifier Logo
589 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
