Question about Bosch HBN 7052 GB Stainless Steel Electric Double Oven
I am looking for a manual for a bosch HNB 7052 oven
  • 109 Answers
How to get over a problem with a quiet alarm
Just get over it, it's not important. Get a hearing aid. It's most likely your ears have aged and the alarm is just as loud as before. What?
It's also possible that the little noise maker has a hole to allow the sound out and has become clogged with dripping pizza, chicken fat, grease vapors, or because it's an electronic device in a hot box it may need replacing.
May 13, 2014 | Bosch HBN 7052 GB Stainless Steel Electric...
Its cuts electricity off
I need more inforamation , dose the top burners work, dose any of the oven work top or bottom , Make model, serial number if you can find it
Dec 07, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
Bottom oven not working only fan & light works - top oven works fine
The ovens have separate heatin elements. Sounds like your bottom oven element needs replacing
Jun 30, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
I have a Bosch HBN7053GB /05 oven which worked fine apart from the bottom oven does not heat up, the light and fan are both working just no heat. I have replaced the element but still no heat, so now im...
You changed the element does everything else work fine, stovetop elements,broiler etc.if so check your wiring going to the new element and to the switch if they are fine it may just be the temp/control switch
Mar 12, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
Is there a high failure rate on fan elements ?
It is not unknown for fan oven elements to fail quite regularly, some brands more than others, you must make sure you are fitting an element with the correct wattage, as this can make quite a difference to it's life expectancy.
Dec 01, 2010 | Bosch HBN 7052 GB Stainless Steel Electric...
I can hear the fan but there is no heat!
If the fan is working o/k, the n you need to fit a new o ven element, located at the rear of the oven compartment behind a removeable cover.
Oct 11, 2010 | Bosch HBN 7052 GB Stainless Steel Electric...
NEED TO FIT REPLACEMENT ELEMENT IN LOWER OVEN TOP SCREW BLOCKED BY FAN
To remove the fan unscrew the fixing nut clockwise as though you were tightening it, as it is a left hand thread, hold the fan blades at the same time to prevent the fan turning.
Ensure power is OFF.
Hope this helps.
Dec 11, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
A new element was fitted and now theres a vibration from the fan. how do you fix the vibration?
I'd suggest that either the fan and its associated washer are not located correctly and fully tightened or that part of the fan has been broken off, making it unbalanced.
Oct 20, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
MAIN OVEN DOESNT WORK
Hi
Pretty certain nofuse. Suspect switch. Guess would be as element blew it took out contacts on oven switch
Feb 20, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
Bosch HBN 7052 GB Stainless Steel Electric Double Oven Logo
671 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
