Question about Freezers
Same deal, Powerpoint fridge freezer. Alarm light flashing.
Have also defrosted and now looks like fridge is not working properly. Help!
How do i defrost a powerpoint freezer and what is the right temperature
Posted on Nov 28, 2010
Defy 350lt upright freezer red alarm light flashing the light start flashing and the food started defrosting
Check for proper door closure or internal light function first
Next, check temp. control settings. If all checks ok, call a tech. to fix it
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Sep 21, 2017 | Freezers
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
Fridge not getting cold
you have a defrost problem.when you open your freezer door and look at the back panel look and see if their is frost built up.if so that means you do have a defrost problem.you will need to pull panel off and defrost coils.then you can check your defrost thermostat which is round and has 2 wires that go to it.it sits at the top of coils.see if it seperated.if so that is your problem also check defrost heater see if any breaks in it.if those check out then could be defrost timer which is located in ref.side.it would help to know what brand it is.it sounds like a side by side ref,but dont know what brand.
Mar 24, 2009 | Freezers
I have a Whirlpool side by side fridge freezer (brand new only 2 days old) the alarm is going off and the two lines side by side on the freezer side are flashing?
The alarm is set off when the freezer is out of the differential range of the setpoint. In other words, the freezer is still too warm. If you press the alarm button, the sound will stop but the light will stay on. If the unit is working correctly and cooling properly, this light should go out once the cabinet temperature gets close to the setpoint temperature. Hope this helps you.
Mar 04, 2009 | Freezers
Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Feb 03, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezers Logo
708 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
