Question about HP Compaq WF1907 Monitor
OSD Randomly Displays on Monitor
The "On Screen Display" on my WF1907 monitor has recently begun to randomly display on my screen. It started with the sound OSD, and after using the menu exit button and trying to get it to exit, I now have OSD Lock-out displayed.
    Sergeant:
    Champion:
  • 233 Answers
Posted on Jun 16, 2009
On screen display appears randomly
check the buttons , probably needs replacement
Feb 19, 2014 | Samsung BX2335 23 inch Monitor
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
Volume Menu appears randomly; buttons 2-4 don't work reliably
Once you can try providing "reset" option from the menu .... This will solve most of your problems ..
Jul 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Static on Screen
Is this an LCD type of monitor or CRT? either case, there's a problem with the horizontal IC. My best solution for this case is to have the unit serviced by an authorized personnel as meddling with the internal circuits of the monitor is dangerous.. Have them estimate the price for repair, if it costs too much... better buy a new one.
For CRT type of monitors: try degaussing, this feature can be found on the OSD (On Screen Display). This can be accessed by pressing Menu on the monitor buttons.
Hope this helps!
Feb 21, 2009 | HP Compaq WF1907 Monitor
Screen displays for 1 minute then turns black
If you have an HP, you probably have a bad display. They are very bad about that very thing. Where the display hinges are, press on the left hinge just above the keyboard. I have a similar HP and mine has the same problem. I was told a shop that it is the inverter for the display. You might see if there is a shop that can look at it for a small fee.
Dec 04, 2008 | HP Pavilion dv6000z Notebook
Random Tweaking of Settings
Its sounds like Bad Solder Connections,Have you moved recently,I know this doesn't sound technical but go up and slap it on the side and see if it acts up,Then you'll know its conns ttech
Aug 01, 2007 | ViewSonic E70b 17" CRT Monitor
On Screen Display Problem
The problem is due to a faulty monitor processor,replacing the processor solves the problem
Nov 27, 2006 | Samsung SyncMaster 551 15" CRT Monitor
HP Compaq WF1907 Monitor Logo
239 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
