Question about Dahon 7 Speed Folding Bike
Problems with vitesse
I completely agree. The screw mechanism holding the levers has to be really tight, more than I can manage, and if it isn't srcewed in tightly then the handlebars wobble. I was so frightened when I took it out for the first time, (having tried at the shop last Saturday - it was OK then), that I'm thinking of leaving it at the tip with a big warning notice about its safety (or lack of it). Also the handlebars and stem slid down unbidden. It's a pity as the rack, 20" wheels, lightness, fold and comfortable seat are what attracted me in the first place. Perhaps Dahon don't want women to ride it! A waste of nearly £300.
I'm sticking to my Brompton!
Popcorn.
    President:
  • 1,138 Answers
Good bicycle shops carry extenders for just this purpose. They will be glad to help you fit your bicycle to your needs.
Posted on Jun 23, 2009
Mamiya RB67 Pro S: film counter does not advance, but the film does advance purchase another back same problem. Is there a switch that I'm missing??
If the problem is on the magazine's counter and if the spacing of frames is correct then the counter dial is loose. two screws on the outside front of the top of magazine, two screws in the film chamber hold the top cover. remove leather cover on winding lever loosen screw and remove. you can then remove the complete top housing to expose the counter mechanism.
Oct 30, 2013 | Mamiya Rb67 Pro S Medium Format Camera-...
The setscrew does not hold the door lever on. what am I doing wrong...I have tightened it as tight as it will go and it doesn't hold the lever on
take the screw out take a drill bit smaller than the set screw and drill divot into shank for set screw to counter sink into should fix your problem
Oct 20, 2013 | Kwikset Locks & Locksmithing
I have a 2000 yz125 and when I shift into 3rd gear and give it gas it kicks it back down to 2nd gear. sometimes I cant get it to shift into 2nd gear. any ideas? thanks
I am presuming you are giving the gear lever a positive shifting motion when changing gears.
If the gear lever is completely tight on the gear shift shaft and the toe of the lever does not touch the engine sidecover when changing up, you may have a worn roller shift lever or loose screws holding this mechanism in place. See the exploded view diagrams of the SHIFT CAM and SHIFT FORK with all part names and numbers on the link below.
Cheers!
http://www.cmsnl.com/yamaha-yz125m1-2000_model10887/partslist/
Mar 04, 2011 | 2003 Yamaha YZ 125
1990 electra glide wont go in neutral when running
Usually caused by the clutch being out of adjustment. Start by loosening the clutch cable at the midway adjuster. remove the derby cover, (over clutch), which will expose the clutch adjusting screw and nut. Loosen the nut, turn the screw in until you feel resistance, no slack in screw, then back the screw out 1/2 to 3/4 turn, then tighten the lock nut. Pull the clutch lever a few times to seat the clutch release mechanism. Adjust the cable at the midway adjuster, holding the cable tight away from the lever. Adjust until there is 1/16" to 1/8" free play between clutch lever mount and the end of the cable housing. Lock the adjuster with the jamb nut and slide the rubber boot back over the midway adjuster.
Nov 05, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
The flap goes down too quickly
Just a thought, you might try to get a piece of chain at a hardware store and do it yourself.....might cost $3, maybe less. There is also a screw on the top of the lever the chain and float are attached to, you can loosen or tight it to change the way the toilet flushes.
You can also check on line at:
www.howthingswork.com
Aug 01, 2009 | Ace Hardware Eljer Toilet Tank Flush Lever
I want to change brake pads on my 03 Mazda Protege SE. What is best way to release hand break cable from caliber, remove caliber? This is the first set of breaks for this vehicle, but I've replaced pads on...
Some calipers have a bolt holding the hand brake mechanism to the body of the caliper. hold the mechanism with a spnner or If yours dont simply lever the mechanism with a bar or long screw driver. Place a pair of lock pliers/ mole grips on the cable(not too tight or you'll fray/damage the cable) then remove the cable from the caliper. When you get the pads out use a screw driver or wind back tool to reset the caliper travel or you will damage the caliper or lose the hand brake altogether.
May 12, 2009 | 2003 Mazda Protege
Bobbin tension
I had the opposite problem it may be that the lower tension is too tight (mine was too loose).
To fix it you have to take the bobbin case out completely to access the tension adjustment screw. - Remove the 2 screws holding the metal plate with a nickel and remove the plastic piece over the bobbin case - there is a small metal lever on the lower left side that needs to be pressed down. You can then remove the bobbin case. There are 3 screws - the center one is the tension adjustment. It was painted green on my machine.  It appears that it is not a regular setting change, but a bad adjustment from the factory. So if you don't feel comfortable doing all that returning the machine for another will likely fix the issue.
Mar 07, 2009 | Brother XL-3510 Mechanical Sewing Machine
Bobbin case.......
A bobbin case for accommodating a bobbin which has a shaft portion and a collar portion formed on both sides of the shaft portion on which a thread is wound, the bobbin case comprises: an opening being opened on at least one side of an axial direction of the shaft portion, for detachably accommodating the bobbin; a thread take-up portion provided in the axial direction opposite to the opening, for pulling out the thread of the bobbin; and a holding member which makes contact with the bobbin and nonrotatably holds the bobbin.
Feb 27, 2008 | Brother LS-2125 Mechanical Sewing Machine
My threading is too loose?
Thank you - fixed it completely... though you have to take the bobbin case out completely to access that screw. - Remove the 2 screws holding the metal plate with a nickel and remove the plastic piece over the bobbin case - there is a small metal lever on the lower left side that needs to be pressed down. You can then remove the bobbin case. There are 3 screws - the center one is the tension adjustment. It was painted green on my machine.  It appears that it is not a regular setting change, but a bad adjustment from the factory. So if you don't feel comfortable doing all that returning the machine for another will likely fix the issue.
Oct 15, 2007 | Brother XL-3510 Mechanical Sewing Machine
Dahon 7 Speed Folding Bike Logo
342 people viewed this question
Top Dahon Cycling Experts
Michial Gueffroy
dante
ray gallant
Are you a Dahon Cycling Expert? Answer questions, earn points and help others
