Question about Bosch Dishwashers
My bosch dishwasher won t empty the water and stuck in middle of programme
  • j_cartawick Jun 17, 2009
    not sure what a spiigot is but will check for a blockage.
    Many thanks
  • Anonymous Mar 12, 2014
    My dishwasher is stuck on one programme (50) and won't let me change?? Any ideas??
  • 109 Answers
Hi, The first thing I would do is undo the drain hose from the spiggot under your sink and try and see if there is food scraps or some other kind of blockage in there. If this isn't the problem, the drain pump itself could be blocked?
Posted on Jun 16, 2009
  • Adrian Jun 18, 2009
    Hi, The spiggot is the barb or pipe fitting that the drain hose connects to under your sink, which is basically the drain.
    No problems, post if you need anymore help!
I need a user's manual for SGS5302 bosch dishwasher. Otherwise would you tell me exactly how the aquastop works? Is there any method to bridge it? What goes on the wires? Signals from or to the...
Please rate this solution if you find it helpful. Thanks!
The Aqua-Stop function is a flood protection feature. You really don't want to be "bridging it"!
It works by using a float switch to detect when the water level gets too high in the wash compartment. It over-rides any wash programme and starts the pump to empty the water out.
Also if water leaks into the bottom of the dishwasher (under the washing compartment) the float will rise with the water level and when it reaches a critical point, it will over-ride any washing programme and run the pump.
However, the pump cannot remove water from under the washing compartment, but as it over-rides the wash programme, it prevents the washer from continuing with any wash cycle, thus preventing any more water from leaking into the bottom of the washer and flooding your house.
For this reason, you should never attempt to "bridge" (whatever that means) modify or disable the aqua-stop feature. If it's been activated, you have a problem which needs to be resolved before you continue to use the washer.
Here is a direct link for downloading your manual from Bosch (free):
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Oct 16, 2010 | Dishwashers
Hi, Dishwasher problem: When a programme starts, the machine fills with water then stops and the "check water" light comes on. To empty the machine, I used the reset programme which does empty the...
You will need to check the inlet valve and the water level pressure switch. It can also be a low pressure in the pump that is giving out the signal for the control board to shut off.
So first of all check the water line throughly to confirm.
Oct 02, 2010 | Bosch 24 in. SGS43C12 Classixx...
I have a Bosch Clasixx dishwasher, it is around 6 or 7 years old. We have had no trouble until now. When we press any programme the usual noise from within begins, but it will not fill with water. We have...
The float switch might be tripping. Pull the dishwasher out (if it's under-counter) and tilt it forward gradually to about 20 degrees. If you see a pool of water on the floor, it means that water is getting into the bottom of the dishwasher underneath the washing compartment.
This can simply be caused by a loose retaining nut on the salt compartment. Unscrew the cap from the salt compartment and you will see a large plastic nut underneath. If it's loose, tighten it - you'll need a large pair of waterpump pliers or stilson for this.
Assuming this was the problem, make sure you empty all the water from the bottom before you put it back by tilting it forwards until water stops coming out.
To stop the problem returning, DON'T over-tighten the cap on the salt compartment. Make sure it's on firmly, but if you overtighten it, it will grip the nut and loosen it the next time you remove the salt cap. If the nut is loose, water can get into the bottom of the washer.
Sep 29, 2010 | Bosch 24 in. SGS43C12 Classixx...
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Bosch dishwasher S10R1B: Water not pumped out
Normally it is the impeller which is stuck. Take out the dishes and the filters and empty it for water by hand. Yes it is a dirty job. Then at the bottom there is an opening in the steel where the water is collected. Empty this too. At the bottom left there is a torx20 screw that keeps the cover for the impeller. remove the cover and check that the impeller can move. The may be object stuck
You canalso force the safety mechanism in the door with a screwdriver and try to see if the impeller moves when it is supposed to empty water.
My problem is that I did all this but it still does not move. It may be the impeller motor which is broken. To replace that one is not easy.
Jan 31, 2009 | Bosch 23 in. SHU3307UC Built-in Dishwasher
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Nov 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Problems with my bosch dishwasher
there should be no salt getting into the wash cavity. if you are sure that it is leaving salty water on the items then either the salt cap is loose/damaged or the regeration system is faulty-this is an expensive fix.
Jun 12, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
416 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
