Question about Standard (CRT) Televisions
Free TV!! Help!
Hello, I found a Phillips 26PS50 TV.  I turned it on and it worked. With no remote, I can only get channels 3 and 8, when I know I can get the free basic channels.  the picture quality if fine, because I was able to use the DVD player with it.
Do I have to have cable in order towatch this TV? Or do I need a special antanae
Re: Free TV!! Help!
Watch dvd through av leads i get white lines at top not all way along the screen i try couple differnet dvd players get the same lines i put my playstation2 on get the same lines but when i play a game it doesnt come up only when i watch dvds i play my playstaion3 on hdmi no white lines just on av leads
Posted on Jan 09, 2011
  • 4,102 Answers
Re: Free TV!! Help!
If you live in the uk you should be able to get a all in one controll to tune the channels in but if you can get those two channels you should get the rest but you will need to tune them in first this cant be done with out the controll
Posted on Oct 31, 2007
0 characters
3 Points
I have a Symphonic model ST420FF along with a Phillips Universal remote. The tv used to work oerfectly but then the channel changed (we have a charter cable box hooked up). Now when I try to change the...
Can you use the menu buttons on the TV to navigate to the control panel to automatically or manually add channels? That would be a start to make channel 3 exist again.
Sep 20, 2014 | Standard (CRT) Televisions
I have a disney tv and the phillips codes do not work. Does anyone know of different codes besides 0417 and 0115:
Follow the same steps to enter a code but instead of entering code press the channel up button repeatedly until it turns the tv channel and when it changes (dont press up again or else you will have to do it over again). When you get the remote to change channel STOP! and press the enter/ok, or similar button to lock the code in and you should be set. Good luck. If you follow the steps and it doesnt work the first couple of times dont be discouraged, Trust me all universal remotes allow you to set up you universal remote this way i guess they already know people lose the universal remotes instruction manual with all the codes in it! Hope this helps GOOD LUCK too you. Hope this works out for you!!
Jan 02, 2011 | Disney DT1350-P 13" TV
MORE channels! for CHANNEL SET UP PHILLIPS pl9127 c101/ 27f 800 7583
I need more channels. I ONLY get 13 channels, 1-13. I know im supposed to have more... Phillips Consumer electronis: manufacture no# 3210t127a
Oct 28, 2008 | Philips TS2746C TV
Help with Game Mode/Channel Switch Please!
Go to Radio Shack and get an universal remote control, i have a Phillips Universal for mine. it has a tv/vcr button that also is an "input" button to switch channels to do this.
Aug 26, 2008 | Symphonic ST420FF 20" TV
Tuning My Tv
If you've store the earlier channel, off the tv and on it again. Every should come back as normal.
Mar 02, 2008 | Standard (CRT) Televisions
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
Feb 22, 2008 | Standard (CRT) Televisions
Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Dec 08, 2007 | Standard (CRT) Televisions
Trying to get channels above 42 to 99
I had the same problem the solution is you have to get institutional remote and reset the tv from commercial mode to consumer mode and then you will have access to the full menu. go to to get the directions. I actually asked a Hotel could I borrow their master remote used it and took it back and my tv works fine. Hope this helps.
Dec 01, 2007 | Philips Magnavox 27MS343S 27" TV
Ghost in the channel selector
the problems due to the microprocessor on the remote reciever present inside the tv .i think the remote is normal working. as the only problem with your iinfra red reciever microprocessor.microcontroler circuit. Replace the IC to solve this. Check electrolytic capacitor coupled to the memory block of the micro processor. Contact service if you are not well verse doing all this rectification works. it is off high risk and caution
thank you !
Nov 17, 2007 | RCA F36650 36" TV
Standard (CRT) Televisions Logo
325 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
