Cell Phones Logo
Posted on Jun 16, 2009
I want the ringtone "hello hello is any body there to pick the phone"voice tone
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jun 16, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
4560
Points
31
Use your celfone feature: Voice Recorder then save it as your ringtone
Hello, my phone has been very wierd. when someone calls me, it will have a voice be saying, call from so and so. and i want it to be just a ringtone. please help!
Which phone are you using ? Check your applications if your have installed any software like Voice/Talking Caller Id or something similar . This software will be the reason the Caller id is a voice and not a ring-tone. Even check the settings in ring-tone if you and option to switch off Voice Caller id. Either uninstall the software or disable the software from the options within.
Jan 19, 2011 • Cell Phones
16helpful
2answers
How to change the text message tone for the samsung solstice a887
Actually, there is a way!! If you go to the menu and settings, and then sound profile...click on normal (silent, driving or outdoor)...click on the actual word (not the blue button on the right)...then you'll get some choices. Select 'voice call ringtone' and in the upper right corner, you can pick 'call, message or phone'..pick message. then, hit the 'voice call ringtone' and select your tone. if you have one downloaded, you can hit 'tones' in the bottom right corner and it brings you to your downloaded tones. hope this helps!
1helpful
Downloading
Your computer is full of potential free ringtones for your Samsung T229 (also known as Samsung SGH-t229, T-mobile t229) :
By Bluetooth:
The Samsung t229 is Bluetooth-enabled. Bluetooth is a wireless system which lets you connect your cell phone to computers, headsets, car kits, etc. If your computer is also Bluetooth-enabled, simply establish a connection between both devices and transfer your music files from your computer to your Samsung t229.
Simply record sound directly:
Since your Samsung t229 has a sound recorder (also known as "voice memo"), a very simple technique involves simply placing your phone near your computer's speakers, playing whatever music or sound you would like as a ringtone, and recording it -- you can even use your voice, your child's voice or even your cat's "meow!" Record it with your mobile and there you go! Unless that function was specifically blocked on the Samsung t229, you should be able to navigate to the ringtones section and choose your new recording as a ringtone. Of course, the quality will not be ideal but, after all, it's free!
Downloading using the phone
NOTE: MegaTones, HiFi Ringers, and Voices & Sounds are stored at Menu > Fun & Apps > Files > Sounds > Sounds. To download using the phone, perform the following steps: 1. At the main screen, select t-zones. 2. Scroll to and select Music & Sounds. 3. Scroll to and select HiFi Ringers, MegaTones, or Voices & Sounds. 4. Scroll to and select the desired category. 5. Scroll to and select the desired tone. 6. On the preview page, select ACCEPT. 7. After the tone downloads, select Play to preview the tone. 8. Select Set as. 9. Select one of the following options:
  • myFaves ringtone: To set as a myFaves® ringtone. Scroll to and select the desired myFaves contact.
  • Default ringtone: To set as the default ringtone.
  • Caller ringtone: To set as a caller ringtone. Scroll to and select the desired contact.
  • Alarm tone: To set as an alarm tone. Scroll to and select the desired alarm. Turn on the alarm and select the desired time and date.
10. Select Save.
160helpful
4answers
I want to change my ringtone on my samsung C3050, but i don't know how to.
Change your ringtone
1. In Menu mode, select Settings → Phone profiles.
2. Scroll to the phone profile you are using.
3. Press <Options> → Edit.
4. Select Voice call ringtone.
5. Select a ringtone category → a ringtone.
6. Press <Save>.
Different ring tones
To assign individual ring tones:
1) you must go to the phone book, highlight the wanted contact, click on options and then edit.
2) scroll down until you see the section "ringtone" and click on it.
3) Then choose audio, then ringtones. click on the ringtone you want, you must listen to it first, and then click on "select".
4) if you want a ringtone to be something you've recorded, click on "my voice" rather than "ringtones"
1helpful
No dial tone on receiver only on voice
make shure handset cord is Not pluged in to the Headset jack on the bottom, needs to be in the handset jack (look at the icons)
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Problem finding saved sound
Symbian OS/S60 phone: With the Voice Recorder on the screen, open Options. Select Go To Gallery. All the recordings you have saved can be accessed from the Gallery. You should see a list of recorded tunes. Highlight a recording, open Options and choose "Set as ringing tone." Windows Mobile phone: When you are still in the Voice Recorder, highlight a recording in the list and open the Menu. Select Set As Ringtone.
If your phone menu doesn't show the Set As Ringtone choice at all, you have to set it manually. Go to the Home screen, push Start, and open File Manager. You have to move the recording from the folder /Storage/My Documents/Notes to the folder /Storage/Application Data/Sounds. Then, go to the Start menu and launch Settings. Select Sounds, open Ring Tone, and pick up the recorded ring tone.
2helpful
2answers
MP3 ringtones sound 'funny' on my N73!
ur speaker must be containg dirt or water must have entered in ur speaker if ur cell is in validity period then go to nearest nokia care n tell them ur problem they will solve it surely
Nokia 3110 classic
go to setting then ringtone setting and choose ringtone for voicemail
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
