Question about Cross Infoguard Shredder SX102M
Plastic drive gear from motor broken
Teeth missing on plastic drive gear from metal gear on motor
  • Hiwale May 02, 2008
    I am looking for the plastic gear. Mine is stripped and I have looked all over the internet.
  • howru2mike May 16, 2008
    plastic gear form motor broken problem
I have a left over set of these plastic gears that I can send to you. The motor bracket on mine snapped. I took it apart to check. It looks unrepairable.
Posted on Jan 26, 2008
Please give me a call at 770-855-7595 so I can have you send me the plastic gears for Infoguard SX-102M shredder.
Posted on Nov 24, 2009
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
I have a ge monogram trash compactor the ram is stuck in down position, how can we raise the ram?
Start your investigation by removing the bottom plate. There should be a belt or chain going around 3 gears. Mine has 2 metal and one plastic. The 2 metal ones are on the ends of the rods that the ram runs up and down on. The plastic one is on top of a big speed reduction gear that is turned by the motor gear. Don't pinch your fingers but see if you can turn the big gear by hand. All gears should turn. If not check each gear for broken teeth, or bad bearing & races under the 2 rod gears.
Be sure to check t
he threaded hard plastic nut that drives the screw that powers the scissors up and down. This is the part that usually fails.
Nov 24, 2012 | GE Profile GCG1580LSS 15" Built-In Trash...
My 2004 chrysler sebring its a 2.4 liter engine when I turn it on the engine makes a weird nose like if sumthing in the engine isnt rotating right what could it be
look for loose or missing starter bolts,the starter drive pinion gear either worn or damaged or flywheel gear teeth worn or broken. noise you hear if it sound like starter grinding noise check starter mounting bolts could be loosen or 1 missing or drive pinion gear or flywheel gear teeth worn or broken.
Feb 11, 2012 | 2004 Chrysler Sebring
I have a KP26M1XPm pro series 6 qt 575 watt stand mixer bought in Feb 2006. For some time it made a "knocking" sound as it mixed large heavy jobs. It was not a grinding sound but a knock as the...
I would be inclined to replace the broken/worn gear and only any other bearings/bushes that show wear, which is probably none. I would remove any contaminated grease (it usually remains close to the failure point) and add more grease if necessary. The gear is a fuse gear and designed weaker to fail if the machine is overloaded so the gear that runs on it is unlikely to be damaged.
Mar 02, 2017 | KitchenAid ProLine 600 Stand Mixer
Peg perego gator hpx gear slippage
Look carefully at each of the gears. Take them apart and I bet some of the teeth are sheared off. Order new gearboxes should fix the problem. This happened to us.
Aug 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
Broken plastic gear tooth - Fellowes P55-C Shredder
I suggest using Belzona (metal compound). Mix it with its hardner, paste it over the broken gear (dont worry if it gets over a couple of other gears. Let Belzona sink and dry (4-5hours). Get a Dremel drill with a fine blade on it and cut accurately where the teeth are meant to be. Voila, you have fixed your gear.
Sep 13, 2008 | Office Equipment & Supplies
Broken gear
I turned the gear arround and put it on backwards
I still need a new gear since it is still missing a couple of teeth
Jul 15, 2008 | Cross Infoguard Shredder SX102M
Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Jun 21, 2007 | Royal 150MX Cross-Cut Shredder
Cross Infoguard Shredder SX102M Logo
570 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Level 1 Expert
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
