Question about Epson LX-300 Matrix Printer
Lx 300 Menu - How to save settings
I have a Lx 300 printer and I managed to enter the menu and change the settings from 19200 baud rate to 9400 or something like this but when i turn it off the settings don't save. Anybody know a way to do this? Thanks.
5 Suggested Answers
  • 24 Answers
SOURCE: change baud rate
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
    1. Enter the parameter ____ on the key board and press the Check Mark.
    1. 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    1. The screen will read Cfg param val: 26
    1. Enter in the value ____ and then press the Check Mark .
    1. 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    1. Screen will read Test -001+
    2. Press the Reset button until you get back to Ready
    Posted on Jan 22, 2008
    Ajkill
    • 2035 Answers
    SOURCE: baud rate
    # Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
    1. Press the Fax button, then press Options untill it gets to ADVANCED FAX.
    2. Press Select.
    3. Press Options untill it getsl MAX SEND SPEED appears on the LCD display.
    4. Change it to 9600 BPS using the - (left arrow) button.
    5. Press Select.
    # Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
    1. Press the Fax button, then press Option untill it gets to ADVANCED FAX.
    2. Press Select.
    3. Press Options until ERROR CORRECTION appears on the LCD display.
    4. Change the setting from On to Off using the + (right arrow) button.
    5. Press Select.
    Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes.
    Posted on Mar 16, 2008
    laxmankumar
    • 191 Answers
    SOURCE: baud rate
    Please follow the steps given below to reduce the baud rate on your printer.
    1. Turn on the HP all-in-one.
    2. From the keypad, press * and # keys simultaneously.
    3. Press 1, press 2, and then press 3. Service followed by a number will be displayed on the front panel.
    4. Press the right-arrow to select System Configuration.
    5. Press Enter on the front panel.
    6. Press the right-arrow to select R/W Parameter.
    7. Press Enter. Parameter 0 will be displayed on the front panel.
    8. Press 1, press 5,press 1 (i.e,151) and then press Enter. The display should read Value followed by a number (example, Value 60).
    9. Press 2, press 6, and then press Enter. This will display Parameter 0 on the display.
    10. Press 1, press 5,press 3 (i.e,153) and then press Enter. The display should read Value followed by a number (example, Value 60).
    11. Press 0, and then press Enter. This will display
    12. Press Cancel repeatedly, until the display reads the date and time.
    Posted on May 23, 2009
    SOURCE: HOW TO SET BAUD RATE
    HOW TO SET BAUD RATE 9600 OF EPSON LX 300...
    Posted on Dec 05, 2010
    Change baud rate on brother fax machine
    Lowering the Baud rate on Brother fax machines.
    • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
    • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
    • Press OK or Menu/Set or Set key.
    • Press Stop/Exit.
    Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
    http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
    Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
    Need to the baud rate how do you do it
    Enter Maintenance Mode:
    1. Unplug power from rear of Fax machine, hold the Menu button while plugging power back in. Continue to hold the Menu button until "Maintenance" appears in the LCD window.
    2. There are no helps for the Maintenance mode. Follow parameter change procedures to the letter.
    Changing Baud Rate from Automatic to 9600:
    1. Enter 10 (one, zero). This will bring up WSW00 on the LCD window.
    2. Change the 00 to 19. If the baud rate is set to automatic, the numbers that appear will be 11100010.
    3. Change the 11100010 to 01100010. This sets the baud rate to 9600.
    4. Press the "Set" button just below the LCD window.
    5. Press "Stop".
    6. Enter 99. This will exit Maintenance mode and make the fax ready to use again.
    Feb 15, 2011 | Brother IntelliFax-4100e Fax
    How to change boud rate from 19200 to 9600
    Here are the complete steps to change your LX-300 bit rate to 9600.
    1) Load a paper with the friction lever up.
    2) Hold the FONT button and switch on the printer. The printer must sense the loaded paper and must start printing some stuff. If not it rolls and tries to load the paper. In such case insert the paper again and press PAUSE button. Now the printer will print the stuff i.e) the current printer settings.
    3) After the printing finishes (the print matter will be around 25% of a 11inch page length), press LF/FF. You will find the current settings. Check the current bit rate which is indicated in the 10th line of the current settings table.
    4) Now press LF/FF which takes you to the Table B.
    5) Now you are in table B and the lights 1, 2 and pause must be Blinking, Off, Off conditions respectively.
    6) Now press the FONT button 9 times. After pressing FONT nine times, Light 1 = Blinking : Light 2 : Blinking : Pause light : ON.
    This means that you are in Bit rate menu now.
    7) Press PAUSE button.
    8) Note down this order of bit rate and the status of 1, 2 and Pause lights.
    --300 = ON-OFF-OFF
    --600 = OFF-ON-OFF
    --1200 = ON-ON-OFF
    --2400 = OFF-OFF-ON
    --4800 = ON-OFF-ON
    --9600 = OFF-ON-ON
    --19200 = ON-ON-ON
    From the current bit rate you are in now, press the FONT button a particular number of times accordingly.
    Suppose you are in 1200 bit rate currently, the lights status will be ON-ON-OFF. If you want to set to 9600 you have to press FONT button 3 times and the lights status change to OFF-ON-ON , which indicates 9600 bit rate.
    9) Now, press PAUSE button so that the settings get saved.
    10) Switch off the printer and turn it back on after 20 seconds.
    11) Switch it off again, Hold the FONT button and switch it in again.
    12) After printing finishes, press LF/FF and check the bit rate in the current settings that is printed.
    You can have the user manual for your reference.
    files.support.epson.com/pdf/lx300_/lx300_u1.pdf
    Thats' it. You're done!
    regards,
    Sabharish
    Sep 30, 2009 | Epson LX-300 Matrix Printer
    Serial port settings Epson LX-300+
    Make sure you have at least 10 sheets of paper loaded.
    Turn the printer off for at least 5 seconds, hold down the Tear-Off button, turn it back on, then release the button when the language menu starts printing.
    After the language menu prints, verify the left and right Font light are off and the Pause light is on (for English). If not, press the LF/FF button until the lights are lit in this order. Press the Tear-Off button to select English.
    Once the current settings print, press the Tear-Off button to enter setup. Follow the directions to change the serial port settings.
    Mar 13, 2009 | Epson LX-300 Matrix Printer
    Epson LX-300+II, the font problem
    yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
    Sep 06, 2008 | Epson LX-300+ II Matrix Printer
    Okifax 5750 baud rate
    Try the following with the machine in standby mode. (no document fed)
    Press MENU/EXIT key ONCE.
    Press RESOLUTION key TWICE.
    LCD display should indicate "Technical Prg."
    Press DOWN ARROW key ONCE
    LCD -display should indicate "2 Setup"
    Press RIGHT ARROW key ONCE
    LCD display should indicate "Setup"
    Press the DOWN ARROW key TWELVE times.
    LCD display should indicate "13>H/Modem Rate"
    Press the RIGHT ARROW key ONCE.
    *** NOTE WHAT IT IS ALREADY & DO NOT FORGET IT IN CASE YOU WANT TO UNDO ***
    Press the DOWN ARROW key repeatedly to change the setting to 4.8, 9.6, 14.4, 28.8 or 33.6K.
    For "9400" set it to "9.6" (9.6K = 9600 Baud)
    Also note that for this to fix your problems I would expect to find your machine is currently set to 14.4 or higher.
    Change it and see how it works for you. If it is no good, you can always change it back to the original setting.
    Sep 05, 2008 | OKIFAX 5750 Plain Paper Fax
    Baud rate
    it's in the printer settings menu
    May 15, 2008 | HP PSC 950 All-In-One InkJet Printer
    Epson lx300+ii with serial port to fujitsu pc
    use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
    and if you use high speed, could loose info.
    Jan 28, 2008 | Epson LX-300+ II Matrix Printer
    Epson LX-300 Matrix Printer Logo
    280 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
