Question about Apple iPod nano
Switch on the i pod - Apple iPod nano
Turn signal relay 2008 jeep location
There is no relay , controlled by integrated power module . Electronics !
Feb 12, 2016 | 2008 Jeep Grand Cherokee Laredo
When i switch my pod on the rebuild db screen appears n th pod gets frozen pls help :( i ve to reset my pod everytime but this too doesnt help me :(
Hello!
My names are humphrey franklin. 4rm nigeria, pls, i need solution to my iriver pod. I tried to add mre musics, in my pod, it will enter, but, it'll never play. Pls, what do i do about it? My e-mail, humphrey franklin@yahoo.com
Mar 03, 2011 | iRiver E30 MP3 Player
CAN'T OPEN MY I-POD
http://www.nikeexpert.com/
May 31, 2010 | Philips SA3125\02 MP3 Player
My ipod wont stay charged
This may not be the answer you are looking for but your I pod might not be fully charged, meaning that you are not plugging it in the computer/docking system long enough.( it takes much longer than 15 minutes to charge the battery. So you might want to plug it in/dock it over night) Or you may be playing a game that uses a lot of MB/GB so it kills the battery. And make sure that you press the play/pause button down for at least five seconds before switching the little switch at the top of your I pod. If you don't press the play/pause button for five seconds and just switch the switch at the top a little lock will appear on the left corner meaning you need to hold the play/pause button down for five seconds then the i pod screen goes black at that time flick the switch at the top off. -hope it helps owner of i pod nano and I pod touch.
Dec 30, 2009 | Apple Mini IPod
Ipod nano 2gb cannot be synced required disk
1. Run "c:\WINDOWS\system32\devmgmt.msc" (this is the Device Manager), this will need to be used later, but you'll need it quickly when you do.
2. Start i Tunes
3. Connect i Pod
4. Go to your i Pod Settings and select "Enable disk use"
5. A dialog box will pop up reminding you that you'll need to manually eject. Hit OK
6. Hit Apply to save changes to the i Pod
7. Quickly switch to Device Manager window and right-click on any item there and select "Scan for hardware changes"
8. Switch back to i Tunes, where you should have a nice, working i Pod!
Let me know, if problem still persists.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 27, 2009 | Apple iPod nano
Cruise control will not engage
You will see 2 cables going to the carburetor. One will be the throttle cable and the other is the cruise. Follow the cruise cable back to the vacuum pod and you should see the vacuum lines feeding the pod. You can remove the line at the pod and place another line in that sprout and **** on the hose. If the pod contracts its good, if you **** air the pod has a hole and it is defective.
If the pod is not defective remove the vacuum line feeding the pod and check for holes.
Aug 23, 2009 | 1999 Mercury Villager
I POD IS NOT WORKING
the battery is gone dead....contact transcend service center and get the battery replaced.
Jul 06, 2009 | Transcend T SONIC 630 MP3 Player
My i-pod nano wont switch on after charging
Try to do a reset. That might help.
Hold select button and upper button down at the same time until you see the apple logo.
Maybe that will work.
Jan 28, 2009 | Apple iPod nano
Corvette, 1985, lost vacuum to A/C control switch: need vacuum diagram and/or any help I can get...fan is OK, just blows out of all vents at one time.
look for a vacuum pod or tank under the hood. this is most likely where the interior vacuum controls get the vacuum. Does the pod have a line that connects to the intake manifold, or the brake booster? It should., if not find missing vacuum line and repair. Follow the other vacuum line from the pod to the interior, (it is important to find the line going to the interior, as there may be more than one at the pod) is it connected to the controls? it should be. Here is a simplified verbal schematic... vacuum from engine to pod, vacuum from pod to vacuum controlled devices. GM often color codes the interior vacuum lines and that makes them easier to follow under the dash.
Sep 21, 2008 | Chevrolet Corvette Cars & Trucks
Apple iPod nano Logo
126 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
