Question about Philips SA5125/37 MP3 Player
MP3 does not switch on, not even when plugged into computer
I have just updated some data on my MP3 player. I unplugged it from the computer, the screen said "updating MP3". Then it switched of and I cannot switch it on again. Not even when I plug it into the computer again. Nothing!
There is a small reset button on the back. You need to reset it with a needle or a toothpick and then it works again.
Posted on Jun 18, 2009
I was listening to music with my mp3 sandisk dansa 3260 (4 GB) and it just stopped playing music and turned of and when i turned it on again the screen kept going black and white black and white ......
HI, When an mp3 player malfunctions,is usually caused by VIRUS that has affected the functions of the mp3 player..To fix the problem,you might to First rest the mp3 player and after resetting the mp3 player and it stills malfunctions, youmight need to update the firmware of the mp3player...
To reset the mp3player :
Instructions
Reset via command
Push the "Power" switch downward into the "Hold" position.
Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
Push the "Power" switch upward all the way to turn it back on.
Reset via switch
Grab a steady hold around the device.
Push the "Power" upward and hold it there until it powers off.
Power the device back on by releasing the power switch and then pushing it upward again.
Force reset via power-cutting
Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
Take out the batteries from the slot and wait until the screen goes black.
Insert the batteries the same way they were mounted and attached the lid again.
Push the power switch upward to turn on the device.
Tips & Warnings
A good idea to stop Sansa devices from freezing is to always make sure that the player's firmware version is up-to-date. Download the firmware updater software from the Sansa website (see link in Resources).
To update :
Updating the firmware of your Sansa MP3 player is easy, and it will correct problems with the original software, and even add new features. Follow the instructions below to bring your device up to date. If you have any questions about the process, please consult the Sandisk website and support forums for more specific information. Links to these sites are provided at the end of this article.
things you'll need:
* A Sansa MP3 Player
* A Computer with an Internet Connection
instruction:
Automatic
Verify that the player is fully charged.
Verify the the player is unplugged from your computer.
Go to the Sandisk support site, linked below, select your player, and download the Sansa Firmware Updater software. Follow the instructions for installing it on your computer. If you need them, you may also download user manuals for your or watch how-to videos on updating the firmware.
Put the player in MSC mode. Go to the settings menu, select the USB submenu, and then select MSC. Some players with early firmwares do not have the USB options in the menu. If this is the case with your device, then there is another way to force it into MSC mode: Put the device in "hold" mode by sliding the hold switch until orange is visible. Next, press and hold the left (rewind) button until the screen changes. Go to the next step.
Plug your Sansa player into your computer and wait. The Firmware updater should launch automatically. Follow the prompts to update your player. Be certain not to unplug your player until the updater is finished. The software will tell you when it is safe to disconnect.
Tips & Warnings
If the above does not work for any reason, there is another way to update the firmware, by manually installing the necessary files. Consult the official support forum for specific instructions for your device. See the link below.
Be sure not to unplug your device while it is being updated. This could permanently ruin it.
Hope it helped...
May 16, 2011 | SanDisk Sansa e260 MP3 Player
Hi, I have unplugged my MP3 player from my computer and it does not respond to any switch. If I put it back into the computer it reads that it does not recognise the removable device . Can you help? Thanks
Initially, you can hold down the power button down for 20seconds to do a reset.
You should do the "safely remove" procedure when unplugging the MP3 player from the computer's USB port, otherwise it will get fried and damaged over time. If you have just been simply pulling the plug off all these times, then I guess that was what happened - the battery got fried. Anyway, just try to plug your MP3 player to another USB port on the computer or better yet, to other computer's usb port.
Please let me know how this goes.
May 30, 2010 | SanDisk Sansa e250 MP3 Player
My M-610 MP3 keeps saying its unplugged even when it's not?
Here are instructions for a solution to your Coby 610 problem.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
You can refer to this Coby 610 solution here.
I hope that helps.
Jan 10, 2010 | Coby MP-610 MP3 Player
IPod recognized by iTunes for about three seconds.
Use the Five Rs to restore the iPod. You will lose the data that is currently on it if you restore but you can always re-sync the data to the iPod. http://www.apple.com/support/ipod/five_rs/
-=/ Daft Tech /=-
Oct 23, 2009 | Apple iPod MA446LL/A MP3 Player
RCA OPAL M4208RD-B Goes to please wait screen and stays.
RCA M4208
Make sure the lock switch on the back is in the unlocked position. For the player to say "Loading," especially the first time you plug it into the computer, is normal - your computer is communicating with the player, installing drivers, and trying to load the Easy Rip Software. If it stays on loading past 10 minutes, however, something is not right. If you have selected to open the device automatically using Windows Media Player, you are headed for trouble, especially if you have more music and other files on your computer than the mp3 player can handle. If you have accidentally done this, disable auto-sync in Windows Media Player.
If you have checked the above, and you are still having problems, disconnect the mp3 player from the computer. Hold in the power button for 10 seconds or more to reset the mp3 player. Try plugging the mp3 player into the computer again. If it stays on loading for more than 10 minutes, unplug the mp3 player, go into the settings menu and change the mode from MSC to MTP or vice versa. If it still misbehaves when you replug the mp3 player into the computer, download the latest Easy Rip software from RCA's website and update your player's firmware - take note of the section they have on Windows Vista if you have Windows Vista. Good luck!
-Tha Mp3 Doctor
Jan 04, 2009 | RCA M4208 MP3 Player
Flash errror
I was having the same problem as the rest after hooking my RCA S2001 MP3 player up to my new computer that is running Windows Vista Home. I did the following to fix my MP3 player on my old computer which is XP Home.
I fixed my player by loading the latest firmware version (1.5 at this time and can be found at http://www.rcaaudiovideo.com/product.aspx?product=124&post=6 ). After you load this application to your computer you access the update device application from the start menu/programs/RCA digital Audio Player/Jet/Update device. One thing that I had to do that had not been mentioned yet in this forum was selecting "Format data area"
Doing this wipes your device completely clean but it allows for you to keep using the device. The update device program will give you additional information after the update and format.
This should fix your device if not contact RCA through the same website above to ask additional questions.
Jan 06, 2008 | RCA JET S2002 MP3 Player
Curtis MPS1015
I had the same problems you described and kind of stumbled my way through a solution. Hope this helps:
First you need either the driver cd or down load the drivers from the curtis website. Btw, there is also a pdf'd version of the procedures.doc that they are referring to (I too could not find after downloading the zip file wth the firmware update).
1. Hold down the on button on your MP3 player, and plug the player into your PC (via USB cable). Keep holding the on button until the found new hardware wizard comes up. (you can let go after that)
2. Check "Install from a list of specific location", click next.
3. Check "Include this location in search" and point to location of your driver files (either CD or folder that you saved them in). You only need to navigate to the "Driver" folder, and it should do the rest. Complete the rest of the New Hardware Wizard.
Here is where the document differs from my experience.
4. You will be prompted to restart your PC.
At this point it was all trial and error and I had to perform the first step again to get the MP3 player to re-connect to my pc.
5. Unplug player, hold start button down, plug back into PC.
6. Locate the firmware upgrade folder that you downloaded from the Curtis website. In this zip file, there is an app folder, open. In the app folder ther is an .exe file named "stupdaterapp.exe, double click on this .exe file.
7. The updater should pop up (Sigma Tel MSCN Firmware Download dialog box).
8. Check the "Format Data Area" box and click yes to the warning message that pops up.
It should start checking your mp3 player's firmware to compare to the updated version. If at any time the box under the format data area box says "Please connect device", unplug mp3 player and try plugging in again while holding the power button.
If the start button at the bottom of the box is NOT greyed out, then you are in good shape.
9. Click start and ensure that the MP3 player is not unplugged during this process.
This worked for me. Hope it does for you too.
Nov 12, 2007 | Curtis SMP228 MP3 Player
Creative zen v plus problem
Have you tried updating the firmware of your Zen V Plus? I've had mine for almost an year and haven't had these issues -- I updated the firmware as soon as I unpacked it.
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
Oct 11, 2007 | Creative Labs ZEN V Plus MP3 Player
Delstar mp3 player
Here's how you fix it for rca H106:
use the user maunal so you know what I'm talking about. I got the FAT error! Plz.. and I could still get the icons. This is how I fixed it. Go to settings and go to advanced press play once only. Plug into computer and it wil recognize it as a flash drive. Completely Format the drive then unplug the player from computer. It will switch back to previous setting automatically. If you need to update drivers and firmware use the auto updater from http://www.voxxsupport.com/images/downloads/autoupdater.exe
Aug 31, 2007 | Thomson H106 MP3 Player
Computer Won't Recognize My MP3 player
Try reinstalling the drivers for your mp3 player. Or maybe updating them here is a link to recent drivers to your player http://esupport.sony.com/US/perl/swu-list.pl?mdl=NWE107&UpdateType=Updates
Aug 24, 2007 | Sony NW-E107 MP3 Player
Philips SA5125/37 MP3 Player Logo
56 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
