Question about Toshiba e-Studio163 Copier
Change the current status counter value (08-400) ?5?, ?7? or ?9? to ?0? for [C44]. this is given by "didi2005". but not explained how to do it using e-studio163 panel.?
    President:
  • 1,126 Answers
Power off machine.....hold "0" and "8" while powering back on. Continue holding until display changes to service mode.
Posted on Jun 19, 2009
Toshiba e-studio 452 total counter c440 problem
Change the current status counter value (08-400) "5", "7" or "9" to "0"
Apr 09, 2016 | Toshiba Office Equipment & Supplies
E studio 520 code c447
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0." also 447
Jan 17, 2014 | Toshiba Office Equipment & Supplies
Error code c43
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jan 14, 2014 | Toshiba Office Equipment & Supplies
Call for service C 430
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Dec 31, 2013 | Toshiba estudio 255 Copier
Call service 1300887600 code C44O
Check and clean the thermistor. Replace if required. C440 occurs due over heat.
- The error occurred during warming-up: "5"
- The error occurred after the equipment has become ready: "7"
- The temperature detected by the main thermistor is 230 C or higher: "9"
- The temperature detected by the edge thermistor is 280 C or higher: "9"
Reset Procedure of C 440 is.....
(1) Turn ON the power while 0 and 8 are pressed simultaneously.
(2) Key in "400", then press START.
(3) Change the current status value to "0", then press ENTER or INTERRUPT (to cancel C 440).
(4) Turn the power OFF and then ON. Make sure that the equipment enters the normal ready state.
Oct 13, 2012 | Toshiba e-Studio 350 Copier
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jul 08, 2012 | Toshiba E Studio 207
C-440
C-440 = Fuser is abnormal after abnormality judgment
Change the current status counter value (08-400) to "0"
To do this hold down 0 and 8 then turn the machine on.
When the machine is on enter 4 0 0 then press copy start.
change the value to 0 then press enter.
Restart the machine.
Feb 17, 2011 | Toshiba e-Studio 232 Black and White...
How to solve a problem error code c44 e studio 163
C44 Abnormal fuser after abnormality judgment
1,2.3. Check the thermistors, IH control board, IH coil and LGC board
Check the above components following the procedure 1, 2 and 3 for [C41].
4. Clear the status counter
Change the current status counter value (08-400) “4” to “0” for [C43] and “5”, “7” or “9” to “0” for [C44], taking
the same procedure as that for [C41].
* The status counter value is as follows in the following cases. Change them to "0" respectively.
• The error occurred during warming-up: "4" or "5"
• The error occurred after the machine has become ready: "6"
• The temperature detected by the center thermistor is 230°C or higher: "9"
• The temperature detected by the side thermistor is 270°C or higher: "9"
Nov 23, 2009 | Toshiba e-Studio163 Copier
Toshiba estudio 2500c C-448 (445) error codes
Did u clear the status counter ?
After repairing the matter which caused the error [C448], perform the following:
(1) Turn the power ON while [0] and [8] are pressed simultaneously.
(2) Key in "400", then press the [START] button.
(3) Change the displayed current status counter value "32" to "0", then press [ENTER] or [INTER-
RUPT] (to cancel C448).
(4) Turn the power OFF and then back ON. Make sure that the equipment enters the normal status
Jul 20, 2009 | Toshiba E-Studio 161 Copier
C44 problem
First u must make memory clear for the machine
by pressing 1+3+* and power on the machine at the same time
may clear the error code .
Apr 02, 2009 | Toshiba e-Studio163 Copier
Toshiba e-Studio163 Copier Logo
116 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
