Question about Car Audio & Video
Car radio wiring
I have connected my after market car radio-i've connected all the wiring and don't have any power to the unit-what have i done wrong?
There is power somewhere because when I was connecting the wires some touched each other but I don't know which ones
  • chrisfolker Jun 16, 2009
    thanks alot will try look into the fuses and disconnect battery
  • Anonymous Mar 14, 2014
    warning check wiring then reset appears on the screen, I have done this and the wiring is fine, but the warning continues to be displayed, I have tried just connecting the power wires and still get the same result
    President:
  • 1,348 Answers
Check the fuses,they blow quick.i would not attempt installation unless you undo the battery
Posted on Jun 16, 2009
Step by step instructions
The pink wire connects the remote CD controller to the radio to enable playing of CDs through the amp via the radio. The DK GRN wire from the radio turns on the amp.
Feb 25, 2014 | GMC Yukon Cars & Trucks
Can't get audio
your wiring is wrong, get diagrams for the car radio as well as the radio you bought.--Good Luck.
Jan 28, 2013 | Pioneer DEH-1400 CD Player
Can I replace the head unit in a 2004 saab 9-3 ? I've heard you can't because to car won't accept any other radios in it . I'm looking to replace it with a touch screen head unit .
Thanks for the help ...so your saying that if I for example buy a ...pioneer stereo that is the right size then it should have no problem hooking into the car with out any fancy wire work ....I'm for iliac with normal installation ( done it before ) but I'm just a little intimidated by some of the sites saying that you can't install a after market radio into a saab because it won't exempt it and all that stuff . But any right size stereo should work your telling me ?
Nov 06, 2012 | 2004 Saab 9-3
Land rover discovery series 2 How do i plug in to the wirinng harnes from a after market stereo to the factory harnest from land rover i cant get sound from the speakers
it is a possibility that it can't be done that way, after market radios usually have to be wired into the wiring harness they don't just plug in for the simple reason vehicle manufacturers want you to use their radios & equipment NOT after market radios etc , you may have to get a auto radio installer to fit it for you otherwise if you don't know what you are doing it could be more costly in the long run......hope this helps......cheers.
Sep 14, 2011 | Land Rover Discovery Cars & Trucks
2005 chevy cavalier after market radio has no power, im installing a pioneer head unit in my car, i bought a wairing harness connected it to the wiring harness for the new radio, im getting power to the...
No, make sure the vehicle key is in the aux or on position. If this still doesn't work, recheck the wiring. Also, make sure you have a good ground.
Sep 03, 2011 | Car Audio & Video
Hello. Have just bought a 2006 tucson,battery was disconnected but have tried to recode the radio using the code on the blue card provided but no go. It times out after 3 times for an hour. Is there any...
Hello Colin. You describe a radio which doesn't sound like any Hyundai Radio I've ever worked on. It seems to me the audio unit is 'after-market' and isn't supported by Hyundai Motor America or Hyundai Service Departments. Does it have a "Hyundai Emblem" on it? If it does, you can check with any Hyundai Service/Parts Department & have them check the serial no.
Aug 28, 2011 | 2006 Hyundai Tucson
Car stereo doesnt work when its hot outside. Sometimes the lights are on, sometimes not
Interesting. I've never met a temperature tempermental radio before. But before we decide that the radio has taken decision making skills that it will NOT work in heat, let's look at the wiring.
I would look at the constant and switched power connections on the unit. This may explain the lights problem. If the unit is aftermarket, did you install it using a wiring harness or is it hard wired. The reason I ask is if it was hardwired, maybe a wrong wire was connected. When it's hot outside, you usually run your air, right? Maybe there is a circuit problem there. Just a thought. Hope this helps.
Aug 25, 2011 | JVC Car Audio & Video
My am radio doesnt work , but my fm does and my sirius does, whats wrong
May be your car has an in-glass radio antenna. Because these don't perform as well as mast antennas, there's an antenna amplifier built into the vehicle.
When installing a new head unit, it's necessary to connect the "power antenna" wire in the radio harness. This activates the antenna amplifier. If you leave this disconnected, the result is the problem you're describing.
Since the vehicle doesn't have an actual motorized antenna, many installers overlook the power antenna connection in the harness. Also, after-market adapter harnesses use a blue wire for this function, and your Radio head unit has only a blue/white output.
The answer, then, is to check the back of the radio, and make sure the blue/white wire from the Radio deck is connected to the blue wire in the adapter harness.
May 18, 2010 | Car Audio & Video
How do I connect a line output converter to my factory head unit
depending on the type of line out converter that you have you simply just take the speaker wires coming from the head unit (you must know the color codes for the wires or you can do the process of elimination by pulling off the door panels and and viewing the colors and matching them at the wire harness behind the head unit). Pull out electric fuse for radio so you dont blow it while hooking up the wires. After you have done that just connect the speaker wires coming out of the head unit to the line out converter this will pre-amp your signal. After you have done that step on the other side of the loc you will have to connect and run rca audio cables to the back of your car to hook into your amplifier. The last step is to splice the power and ground wire coming from the wire harness and connect the radio power wire and loc power wire to the main power wire and then connect the radio ground wire and the loc ground wire to the main ground wire. Test and your done with the loc.
Aug 12, 2008 | 2008 Chevrolet Impala
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
