Question about HP Officejet 5610 All-In-One InkJet Printer
How do i print a no. 10 envelope on the 5610 - HP Officejet 5610 All-In-One InkJet Printer
    President:
  • HP Master
  • 1,996 Answers
See pg 49 of the user manual, available here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 16, 2009
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Pinch the Paper Guide and slide it against the left side of the envelope.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
Trying to print on a #10 envelope from iMac 27 with Os 10.5.1 using iWork. Printer will not load paper
I am on an iMac using OSX 10.5.8 and printing on an Epson R1800. With iWork, word processing module I set up the envelope to print and under the File menu, select page setup and choose #10 Envelope with Portrait orientation. I feed the envelope into the printer in the normal horizontal, top first, print surface up. In the File menu I select Print and hit Return. Most of the time this works. Sometimes the envelope feeds through without printing, and occasionally the envelope won't feed but the printer goes through the printing cycle. The R1800 is not the ideal envelope printer. It is made to print photos on photographic paper. I use an old fashioned typewriter to address envelopes.
Jul 11, 2010 | Epson Stylus Photo R1800 InkJet Printer
Envelopes print crooked
A decent printer should print a #10 envelope without a problem. If this model won't do so, return it and get another printer. Suggest Epson or Canon -- AVOID HP printers.
Oct 10, 2017 | HP Laserjet CM2320nf All-In-One Color...
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Select Face down .
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    Envelopes won't print
    where do i insert envelope to print address?
    Apr 26, 2009 | HP Officejet 5610 All-In-One InkJet...
    Why cant i print envelopes
    Well that depends, additional info would be great.
    Here's an example:
    PRINTING ENVELOPES from Microsoft Word
    The envelope should be fed into the printer using the short side, all the way to the right, flap to the back and to the left.
    Please follow the steps below to print envelopes in Microsoft Word:
    1. Open Microsoft Word.
    2. Click on TOOLS, then ENVELOPES AND LABELS.
    3. Ensure the ENVELOPES tab is selected. Click on the OPTIONS button.
    4. Select your envelope size under ENVELOPE OPTIONS (ie: #10).
    5. Select PRINT OPTIONS.
    6. Under FEED METHOD, from the six options available select the FOURTH icon from the left. Select FACE UP.
    7. Ensure CLOCKWISE ROTATION is selected.
    8. Under ENVELOPE OPTIONS, ensure you choose the correct envelope size (ie: #10).
    9. Click OK, then PRINT.
    The envelopes should print correctly now.
    Sep 11, 2008 | Kodak Office Equipment & Supplies
    Envelope Printing on HP 5610
    Installed SR-3 from Office Word. It did the trick.
    Mar 10, 2008 | HP Officejet 5610 All-In-One InkJet...
    HP 5610 Envelope Printing Problem
    Had this same problem. Went to Microsoft Office site and downloaded Service Pack 3 for Word 2000 and Security update #KB934392 and the printer started printing on the correct side again.
    Feb 26, 2008 | HP Officejet 5610 All-In-One InkJet...
    How to print #10 Envelopes
    How to copy/print onto envelopes.
    Solution
    Konica Minolta does not recommend copying/printing onto envelopes, asthe MFPwas not designed to run envelopes. Additionally, envelopes do not meet the
    standards set for paper specifications. Their multi-layer make-up, adhesive, and odd size make it unreliable and potently damaging to the MFP.
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
    Nov 13, 2007 | Office Equipment & Supplies
    HP Officejet 5610 All-In-One InkJet Printer Logo
    81 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
