Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Fault f4 suspected heating element failure
Is it possible to replace the heating element if so where can you get the part and is it hard to install
  • 109 Answers
You will need a service technician to repair the dishwasher for your as it is not an easy repair without the knowledge. The whole drawer requires removal, turned upside down and completely pulled apart for access to the heating element.
Posted on Jun 16, 2009
My hotpoint wf860 is showing a code F-860 and will not empty or finish cycle
Are you sure 860 is the error and not the model no? Here are the common Hotpoint error codes:
F1Motor triac short
Check motor and module connections This fault is usually associated with either a failure of the electronics to "see" the motor in some way or that the motor itself is faulty and therefore the error is reported.
F2 Motor jammed or tacho off
As with the fault above this is a motor related problem and the electronics are correctly reporting that failure. If the motor is proved to be good then it is possible that a fault on the main circuit board has occurred.
F3 NTC thermistor shorted or open circuit
Check NTC thermistor, connections and module connections
The thermistor is the temperature sensor that reads the temperature of the water, in many Hotpoint and Indesit washing machines this is located either in or just beside the water heating element. The thermistor is a Negative Temperature Coefficient type so the resistance of the thermistor will fall as the temperature increases, this can be easily tested with a simple multimeter and a cup of warm water.
F4 Pressure switch jammed empty
Check pressure switch, wiring and module connections
The pressure switch is the sensor that is attached to a pipe unsurprisingly called a pressure switch hose that is very thin, about 10mm or so in diameter, that will come off either the sump hose (the one from the bottom of the washing machine tub that runs to the drain pump) or from the drain pump housing. Also check that this thing hose is clear.
F5 Pressure Switch jammed on full
Possible pump block, check pump etc. for blockage
As above for fault code F4.
Also in the first instance check the drain pump filter for any blockage or, if there isn't a drain pump filter fitted the pump will need to be removed and inspected for any blockages.
F6 Not Used
Error codes that are not used do sometimes appear and, in most cases, it will indicate some for of failure with the electronics. If you do see this fault code then it's probably not going to be good news.
F7 Heater relay stuck
Check heater wiring and module connections
This code is pointing towards some for of failure in the heating circuit, that is to say, that it could be anything on the heater circuit and you must therefore check all components with a multimeter and make sure that they are all okay. The heater will be a simple circuit that you either have or, it will be open circuit the actual resistance reading is not of any great concern.
To go any further with this you really will need some more specialised test equipment and the knowledge of how to use it, it is therefore outside the bounds of what we consider to be a reasonable DIY repair.
F8 Heater relay stuck
Check pressure connections for heater, wiring and module connections
As with fault code F7, check the heating circuit and in this instance, the pressure switch for any failure.
F9 Setup error
Incorrect or faulty EEPROM fitted, check EEPROM
This one is bad news, it basically means that the electronics either need reprogrammed or very possibly replaced, This is not a cheap repair to do and not one that is recommended for DIY repairs.
F10 Pressure switch
This error code would point towards a failure with the pressure system or a failure to read the pressure sensor correctly.
F11 Pump
Check pump connections and module connections
This is a failure to drain or to detect the presence of the drain pump in the washing machine. Check the pump for blockages or any obvious signs of damage, does the pump impeller turn freely, are the windings of the drain pump open circuit? Again if the winding coils of pump motor are open circuit then it will need to be replaced but if the circuit is complete then it should be okay and run, the actual resistance is not really required.
F12 No comms between cards
Check module connections
This is either a cable fault as indicated or a failure in one or two of the electronic control cards.
F13 High dryer temperature
Check dryer motor, dryer NTC thermistor and connections possible restricted airflow
What this is saying is, basically, that there is probably either some form of blockage in the dryer side of a washer dryer or, there is one of the components of the dryer assembly faulty.
F14 Dryer not heating
Check dryer thermostat (one-shot), element and connections to module, fan motor, valve
Again, a very ambiguous error code. Check the components indicates and ensure that they are working as they should.
F15 Dryer element relay
Also check the dryer element and thermostats for good measure.
F16 Not used
As fault code F6.
F17 Door lock
Check door lock, door and connections
This could be a simple case of the door not closing correctly as well as a door lock fault, Check that the door of the washing machine is closing and engaging correctly.
F18 Comms Error on 3 phase motor
Replace power board
May 05, 2014 | Washing Machines
No heat
Possible failure of the element, fault in the wiring harness or connector or failure of the control panel or output.
click on : element
Jan 24, 2013 | Maytag MDE9700AYW Neptune 174 Electric...
What does f4 mean
Hi.
F4 means: no increase in water temperature after given cycling time.
Possible reasons for the fault:
Defective thermostat:
test the thermostat by reading impedance. It must read zero or low impedance at room and open in hot water.
Defective element:
Test the element by reading impedance. If it reads open replace.
Wiring problem:
Check continuity.
Central control unit:
Replace when all the rest is OK.
Behind the lower drawer panel you should also find a tech sheet hidden inside the assembly. It will be something like this. The tech sheet will report the diagnostic procedure for the dishwasher.
Regards.
Ginko.
Apr 29, 2011 | Fisher and Paykel Dishwashers
F4 fault on fisher paykal dish drawer
F4 fault would inidicate the temperature sensor that senses the water temperature is faulty or the heating element is not working.
Looks like you will need a technician to visit and have a look.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 | Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
E3 The washer vibrates
hi.....
the following table provides you the all error codes and the reason causing those error codes.....
Washing Machine Failure
Code
Condition Check/Repair F1 Water supply/low water fill · Check water supply to machine
·Replace water inlet valve F2 Water level too high · Plugged/Bad water pump
· Faulty water valve F3 Pump problem Check pump trap and clean. F4 Thermistor problem · Open thermistor, replace
· Bad wiring to thermistor F5 Fault in thermal cutout or heating pause fault. Selected temperature not reached in 90 minutes · Check heating element
· Check thermostat F6 Motor fault · Check wiring to motor
· Replace motor if necessary F7 Door lock release fault · Bent pull-rod for door latch
· Bad door latch solenoid 00 00 Machine did not spin Check load for out of balance Redistribute load and restart i think my solution will be definitely will be helping you......if you are satisfied with my solution then rate for me...
thank you for using fixya....
Jul 20, 2009 | Samsung Washing Machines
F7 error code- what does this mean?
Oven Fault Codes
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
"primary master harddisk S.M.A.R.T Command failed , press F4 to resume"
American Megatrends is telling us our Pri Master Hard disk: S.M.A.R.T. is bad, backup and replace.
By questions and answers from above, is this telling us to replace hard drive?
Aug 14, 2008 | Samsung (SP0411N) 40 GB Hard Drive
When trying to pre-heat my oven, It won't until serveral attempts later (maybe 10 ). Then, after baking and stopping the oven, I get an F1 error! What's going on?
F1 is listed as "Element Relay circuit Failure".
There will be a current switching relay to the oven - which is faulty - hence why you get the error when it realises it's not working.
This should be replaced to solve future problems.
For your reference, the fault codes are -
F0 Touch pad stuck in depressed position
F1 Element relay circuit failure
F2 Oven temp exceeded the clean runaway temp (self clean) -or- runaway temp (cooking modes)
F3 Short circu!t in oven temp sensor
F4 Open circuit in oven temp sensor
F5 - N/A
F6 Failure in the EEPROM check comparison (only time of day and timer will operate)
F7 Failure of Sef-C1ean auto door latch circuit.
F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking Self-Clean mode.
If this resolves the issue, Please rate accordingly. Thank you.
Jun 26, 2008 | Dacor Kitchen Ranges
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
164 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
