Need manual do not have model number because door has been replaced Bosch Nexxt premium front load washer
SOURCE: Washer will not spin
Carbon brushes in motor have worn down clean armture and replace brushes.
SOURCE: Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
SOURCE: bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
SOURCE: Excessive vibration on spin cycle.
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
I have a copy of the WFMC6400UC repair manual which covers 4 models and am willing to send you a copy.
