Question about Homelite Mighty Lite Lawn Trimmer
I have a rhobi strimmer only 2 years old wont start
I have a rhobi strimmer only 2 years old wont stat this year
  • 27 Answers
I presume this is a petrol one. The fuel can dry in the carby and stop the unit from starting. Use fresh petrol.
I am not sure about the ryoby unit, but if there is a air filter, take it out and dip it in petrol, then try to start with the normal proceedure in the manual.
Posted on Jun 16, 2009
Why does my tablet only charge 20%?
Have you rooted the device?
If not you might still be able to reset the battery stats - just google boot into recovery and see if there's a way to rest "BATTERY STATS". Fair warning you can also reset/wipe the whole device from there.
Or drain the battery - charge 100% (or at least enough time that it should reach that point) and repeat that cycle 3-5 times and might restore the settings on its own.
Oct 04, 2015 | Tablets & eReaders
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
First time starting a/c this season, display is lit but no air is blowing. Fan outside is on. Batteries changed, still no air. System is only @ 2 years old. Stat model - TH3110D1008. Thanks.
Set the thermostat FAN setting to FAN ON to verify the fan working.
If it works in the FAN ON position the fan motor is OK and you have a bad fan relay.
If it does not work you should check the fan motor capacitor.
At 2 years old the unit is still under warranty for parts.
Apr 26, 2011 | Honeywell Heating & Cooling
I have lost my manual. What is the unleaded petrol to oil ratio mix for my Mountfield 22CX Strimmer please.
The fuel mixture ratio for any 2 stroke engine on a trimmer in the last 5 years is 50:1 (air quality standards)
More than 5 years 40:1
10 years old = 32:1
Use this AWESOME link for computing quantities:
http://www.csgnetwork.com/oilfuelcalc.html
Kelly
Apr 24, 2011 | Garden
Cabrio not heating. Its about 2 years old. Is it
It is probably your T-stat, its abotu 10 to 15 bucks at the car part store.
Nov 27, 2009 | Dryers
2 year old Kenmore side by side refrigerator is too warm
the freezer feeds the refridgerator with cold air,when you open the freezer door,do you hear the fan blowing,if not you need to change the evap fan motor,next take out the second from bottom food bin and touch back wall,if you feel snow or ice you have a defrost problem, you'll have to take off back wall,advance the timer till it clicks into defrost and see if the heater comes on,if so you have a bad timer,if not read out the t-stat and the heater,if there are plug in wires on t-stat unplug them and bypass the t-stat by plugging t-stat wire to heater if heater comes on change t-stat,leave the heater on to help you defrost the ice off of evap coil and use hair dryer to melt ice,hope that helps
Nov 02, 2009 | Kenmore Refrigerators
I have a kenmore refrig it is two years old the icebox wont cool
Ms. Harris,
If your unit is a bottom freezer and it is not freezing i.e warm, you more than likely have a sealed system issue. Check your warranty disclosure in your users manual. You may have Five years parts only on the sealed system.
Her is a tip: If you have American Express- Charge it . AMEX will mirror the manufacturers warranty.
Affordable Appliance Repair
Lake Forest, CA. 92630
Aug 21, 2009 | Refrigerators
Ryobi model RCT2800B grass strimmer will not start
close your carb adjustment screw a bunch of turns... yours may even be missing.
Apr 19, 2009 | Ryobi Garden
Dryer to hot
your dryer has 2 thermostats in it more than likely that no1 thermostat has burned out it will need replacing usually when u buy the stats they come in a pack of 2 lower and higher temperature stats
Aug 15, 2007 | Frigidaire FWT449
Homelite Mighty Lite Lawn Trimmer  Logo
567 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
