Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler..... It show it on 'preheat', but no heat.... Is it a sensor, or is it possible that both elements went out on the same day?? ( the bottom over is working fine.....)
    New Friend:
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Posted on Apr 05, 2014
  • Tracy Thackery Apr 05, 2014
    I don't think it is the elements, both going out on the same day is a bit much..... Does anyone know if there are separate control boards for the upper and lower? a week without an oven will be tough in my life... sigh..... ( but thanks for that information)
SOURCE:
Early 1960's Frigidaire 24" Double wall oven not heating
Hello Chris Hammond, thanks for your post!
Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
Nov 07, 2014 | Ovens
Clean between the glass on double wall oven
Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire FPET2785KF Professional Series...
Frigidaire oven will not get all the way hot
Good Afternoon Tasha - There could be
a number of any one of several underlying causes in why the oven is
experiencing this particular issue:
Convection
heating element
Thermal cutout
Thermal oven
sensor
EOC
(electronic oven control)
Ignitor
Bake or broil
element
All wired
connections
The parts above will need to be assessed for further
evaluation. Lastly, the oven cavity and insulation should be checked to ensure
there are no gaps or damages that will leak out the heat. At t his time, I
would recommend contacting a professional to assist you further since it is always
a good idea to get the appropriate diagnosis prior to making any unnecessary
part replacements.
Jul 11, 2013 | Frigidaire 30 in. Electric Double...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Slow to heat on convection mode, bottom element not get as hot as
Check to see that the convection element is heating. If not, ohm it out, either the element is bad or it is not getting power from the control.
Jun 25, 2010 | Frigidaire 30 in. Electric Gallery Series...
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
279 people viewed this question
Top Frigidaire Ovens Experts
Craig Butler
Craig Butler
Marvin
Marvin
Bruce Denton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
