Question about Panasonic Lands Phones
My panasonic kx tg6502b has no dial tone
My panasonic kx tg6502b cordless phone rings on incoming calls and works well but for outgoing calls I do not have a dial tone - the phone is plugged in and the phone line works with other phones
  • goneasia Jun 16, 2009
    OK, I'm repling to my own post but I got her working. The program button displays O or P, it was displaying 0, I changed it to P. Next, I would have to choose line 2 and now I have a dial tone
SOURCE: I HAVE A PANASONIC PHONE
Emeritus,
There are several things to ask yourself.
1. Do you have the manual?
2. Is there any software programming which relates to set ring?
3. Is there a manual switch for ring on/ring off?
4. Will another phone ring when plugged into the same jack?
IF NOT, the red and green wire may be reversed at the jack.
5. Lastly, has this cordless handset ever rang?
Most cordless sets have a volume control from off to loud. I hope this will help you solve your problem.
I
Posted on Feb 25, 2008
  • 12 Answers
SOURCE: i have no dial tone on one line. call my number and it rings
IT IS DUE TO NETWORK FAILURE OF THAT LINE
Posted on Jan 05, 2009
  • 64 Answers
SOURCE: no dial tone no incoming calls or outgoing calls
Have You Tried Replacing The Cable Connecting the Base To the Wall Jack? If Not Do That...
If that doesnt work there should be a channel button on the handset try that...If that doesnt work i would say the handset itself is bad.
Posted on Apr 03, 2009
SOURCE: Dial locked in panasonic KX-TGA351BX cordless phone. How to open
I've got KX-TGA351BX phone. It was in use for 2 years but due to relocation it was out of use for almost a month. One fine day I tried to re-install it and found ''Dial Lock''. Unable to make outgoing calls but can receive incoming calls. Can anyone let me know how to open the lock (I forgot the old password)?
Posted on Sep 10, 2009
SOURCE: no ring tone for one phone line
Same problem as above
Posted on Oct 20, 2009
KX-TG8421 Panasonic cordless phone
unplug the base unit for an hour. Take the batteries out of the handset for an hour. If this doesn't help, call Panasonic support.
Phone: 800-211-7262
Jan 26, 2015 | Panasonic Lands Phones
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
Panasonic cordless phone model kx tg3521 is keypad locked I can atten incomeing call but I can't do outgoing calls
panasonic cordless phone model kx tg3521 keypad locked .I can attend incoming calls but I can't do outgoing calls .its say dial is locked
Feb 25, 2010 | Panasonic Lands Phones
Phone sees call, but can't pick-up. Can't get d-tone to call out?
Just a suggestion (without knowing what troubleshooting steps from your manual you may have taken): Remove the batteries from the back of the handset and then put them back in after a few moments. My Panasonic KX-TGA8231B (DECT6.0) phones were acting up just like your Uniden is. All functions returned after this power interrupt "reset" with the batteries was done. Hope that helps. Good luck. - - -Gerry
Nov 30, 2009 | Uniden TRU9485 Cordless Phone
Panasonic kx-TG2352 can not dial ,phone works for
Believe it or not, I accidentally discovered you have to really press hard on the numbers to dial !!! I guess this happened as one is used to a light touch working on a cell etc
Nov 30, 2009 | Panasonic KX-TG2352 Cordless Phone
Phone only rings once
ring tune setup ringing not beep or ring once
Jul 18, 2009 | Panasonic KX-TG5632M Twin Cordless Phone
Panasonic cordless phone KX-TG6052
reset the dial mode if it is on tone and you have pulse it will not dial out.
Feb 08, 2008 | Panasonic KX-TG6052B Phone
Lands Phones Logo
282 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
