Question about IBM Computers & Internet
I have a IBM T43 laptop. It is charging but I have found that once it charges the battery light flashs orange. This doesn't change if I have the power cord pluged in or not. Would any one know whats going on?
Is that the original charger
Posted on Jun 16, 2009
I am having an issue with my ibm t20. i had purchased a new battery for the laptop and it would not charge. the laptop worked fine on the battery, as well as on the a/c adapter, however the battery would...
Looks like the battery is completely drained. If this is the case, it is hard to make it working without pulling apart the battery. A solution given in
Jan 16, 2011 | IBM ThinkPad T20 2647 Notebook
I have an T43 notebook, and I left it (unplugged) for about a week and a half, when I came back to it it was dead. So I plugged it back in, still nothing. I let it charge for awhile until the charge...
Try taking the battery out, and putting it back in, hold the start button till it comes on. If not, it's possible it's just un-chargeable. And you'll have to goto ibm.com to look for a replacement battery. Let me know if this helps
May 14, 2010 | IBM ThinkPad T43 Notebook
My ibm thinkpad when charging has a orange battery light. when i try to turn it on it won't go on . why is this?
battery is not charging. please try with diffrent charger still you face problem try to change battery.
May 03, 2010 | IBM ThinkPad R32 2658 Notebook
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Battery icon flashing orange
Sorry to here about your problem with the orange flashing light.
1st. You really are not giving enough information to identify your problem.
2nd. If your battery is charging when unit is turned off and you can see a blue charging light on the front left panel, that's good but should only charge for 1 or 1 1/2 hrs. max.
3rd. If your charger is getting to hot to hold while attempting to charge the battery, you may have a bad battery.
4th. If the orange light disappears after removing the battery and replacing it with a known good battery, its the battery.
This unit is an HP and HP has a recall on many battey's. ( I have worked on al least 25 HP Laptops and in two years have not found a battery to return under recall ) Thanks, HP !!!
All and All, it sounds like the battery is NFG.
Drop me a email or reply here as to what you have found.
John Ray
john@johnrraycomputer.com
Jun 22, 2009 | Dell Inspiron 6000 Notebook
T43 laptop will not charge the battery
Can you start the laptop on the mains charger? If not then either charger is faulty or dc connector on motherboard is broken
Jun 10, 2009 | IBM ThinkPad T41 Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Not charging
try to pull out the battery and run the laptop on the charger...if the laptop starts, then it's an issue with the battery....else have the charging port checked out by a certified technician.
Jan 18, 2008 | IBM ThinkPad T43 Notebook
IBM R32- battery light problem
usually when the charging light blinks and wont change to solid green it means the battery is dead.
solution is to buy a new battery
Dec 07, 2007 | IBM ThinkPad R32 2658 Notebook
Computers & Internet Logo
61 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
