Question about Microsoft Windows XP Home Edition
Long beep during starting-up the computer - Microsoft Windows XP Home Edition
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 91 Answers
During this long beep, what happens next, is there any display on the screen? is it a desktop or laptop? if it is desktop: and the long beep is it continues? one ur memory could be bad. or ur display card. remove and replays with another working once.
Posted on Jun 16, 2009
Why does the computer beep everytime during start up?
A single beep may not indicate a failure. Sometimes its because the motherboard was designed for an on-board PS/2 keyboard that is not connected (such is the case when you are using a USB keyboard).
If your computer is working, you can ignore the beep.
Multiple beeps indicate a failure or mis-configuration of your CPU, RAM or power. Check with the computer manufacturer or motherboard manufacturer for the meaning of specific beep codes.
Sep 25, 2017 | The Computers & Internet
My laptop starts but won't display. I hear loud beeps during this process, what could be the problem?
What are the beeps as they are the clue to the problem. Count the beeps.
May 12, 2016 | HP 650 Notebook PC
Dell xps 9100 constant beeps upon startup
Beep Codes
Your computer might emit a series of beeps
during start-up if the monitor cannot display
errors or problems. The following repetitive
beep codes help you troubleshoot problems
with your computer.
NOTE: To replace parts, see the Service
Manual on the Dell Support website at
support.dell.com.
One beep - BIOS ROM checksum failure;
possible motherboard failure
Contact Dell (see "Contacting Dell" on page 53).
Two beeps - No RAM detected
Remove the memory modules, reinstall
one module and restart the computer. If
the computer starts normally, reinstall anadditional module. Continue until you have
identified a faulty module or reinstalled all
modules without an error.
If available, install memory modules of the
same type in your computer.
Three beeps - Possible motherboard failure
Contact Dell (see "Contacting Dell' on page 53).
Four beeps - RAM read/write failure
Ensure that no special memory module/
memory connector placement requirements
exist (see the Service Manual on the Dell
Support website at support.dell.com).
Verify that the memory modules that you are
installing are compatible with your computer.
Five beeps - Real Time Clock failure
Replace the battery.
Six beeps - Video BIOS test failure
May 22, 2014 | Dell Studio Xps 9100 Desktop Computer
What is the mean of postcode
Post stands for Power on self test its your computer checking main systems during start up and it will give you a beep code to inform you of systems errors. if you get one short beep after start up your system is all good.
Sep 28, 2013 | Computers & Internet
6 beeps what dose it means
Dell beep codes:
If your computer beeps during start-up:
Run Dell Diagnostics to identify a more serious cause.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Contact Dell for technical assistance.
Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM read/write failure 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer failure 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3 Video Memory test failure 1-3-1 through 2-4-4 Memory not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller test failure 3-3-1 NVRAM power loss 3-3-2 Invalid NVRAM configuration 3-3-4 Video Memory test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No timer tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math-coprocessor test failure 4-4-4 Cache test failure
Aug 12, 2013 | Dell Gx620 Gx 620 Sff P4 Ht 2.8ghz 1gb...
There's a beeping sound during startup
Thank you for posting here in Fixya.com
The beeping sound is not a problem. Most computers produce a beeping sound when you start your computer up.
Thank you,
Carlo
Jan 23, 2013 | Computers & Internet
There's a sound during startup
There is no problem with your computer. It's just natural to have a beeping sound during start up. If there is, then it will show an error message in the screen.
If it's just a short beep, then it's normal.
Carlo
Jan 23, 2013 | LG X130 Netbook
I have a Dell Dimension E510 and it makes different tone beeps during and after startup. The computer works ok, but the beeps are disruptive. Seems like there are many more beeps during processing steps,...
When you first switch on your computer it checks certain things to make sure everything is OK and sends out multiple Beeps if there is a problem this is call POST. If you are getting multiple beeps then there is a problem, depending what BIOS CHIP you have and how many beeps you are getting should indicate what is at fault. If windiws is starting ok then it will be a minor problem, the first thing I would check if i was you is the memory. If you have more the one stick of memory installed and one is faulty windows will still start but with the beeping error. Start the computer and goto the control panel and click on System and check what memory that is showing and compare with what should be installed. If its the same then the fault is somewhere else and you will have to give more infomation like what is the system bios and how many beeps.
Good luck.
May 29, 2011 | Dell Dimension E510 PC Desktop
When i turn the computer on it starts then
SOS beeps are post codes the computer sends to alert you of problems detected during start up.
The beeps can mean anything from over heating to bad memory detected. Find out what your Motherboard bio is and check Here. This has a handy beep code listing for many of the common mother boards.
Hope this helps!
Nov 17, 2009 | E-Machines (BFB0505HA) Cooling Fan, Laptop...
My laptop has starting prolem ...when i am switch it on ... it is starting with contineous sound of beep....and also my touch pad mouse is not working some time properly... i had format it two times with...
Hello, hetul58519
I installed some extra memory on my PC, didn't do it quit right and recieved a series of beeps untill I fixed what I had done incorrectly during the install. The beeping is the computer way of telling you something is not right, it is trying to audibally tell you what that is. Now, it is up to you to search for the hidden meaning behind the continuose beep. Do a search for "computer beeps" or "computer audio cues". Do you recieve any warnings other then the beep? Is the computer acting funny in any other way?
Aug 13, 2009 | HP Compaq Presario CQ70-120US Laptop
Microsoft Windows XP Home Edition Logo
109 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
