Question about Whirlpool 24 in. ADG6340iX Built-in Dishwasher
Green light flashes 4 times???
ADG 6340 Green light flashes 4 times???
  • 1314 Answers
SOURCE: Dishwasher adg 6340
do you know how to use volt ohm meter your problem can only be two places either your timer is bad or your wash motor is bad un plug the wire at the motor set meter to volts take the connector after the water fills have some one turn the timer for you slowly if you get proper volts on your meter then open the door plug the connector back on the motor if the motor starts then the timer motor is bad if the wash motor doesn't run then its bad if you don't get no volts the contacts in the timer are bad now some timer motors can be replaced with out having to replace the whole timer
Posted on Apr 01, 2008
SOURCE: Whirlpool ADG 6340 Dishwasher
fault 7 is a fill fault . If you take the left side panel off you will see a white plastic tank . The sensor in the tank has failed
Posted on Jun 23, 2008
SOURCE: front light flashing
Solution to the problem:
Discovered that the dishwasher was covered by our household insurance policy. Phoned and arranged for it to be repaired or replaced (no charge). Engineer coming on Friday.
Posted on Jun 11, 2009
tbirdfan1
  • 3051 Answers
SOURCE: I have a Whirlpool Dishwasher model no. ADG 6340
Hello there and thank you for choosing fixya
This is a very common problem with these types of machines the water inlet valve has a solinoid for the hot and a solinoid for the cold that opens and closes the water on demand .
When they start to pulsate like this it is trying to close the valve but it cant this is normally due to the valve being clogged with debris or the valve is failing all together and simply needs to be replaced
So what i would do is first if you can look into the inlet valve with a flashlight and see ifit looks like it has stuff in it and if so clean it out and try it again if this doesnt work than you can assum that the valve will need to be replaced here is what the one of the valves should look like or close to it .
$50.60 Quantity:
In Stock
Posted on Jun 05, 2011
oldTech2332
  • 2341 Answers
SOURCE: whirlpool dishwasher adg 642 not working start light flashhin 4 times
Hello Faye,
The F4 error code is a drainage error and it means that the control board did not detect a drop in the water level in the tub so it thinks it didnt drain.
The things that could cause this are a clooged filter on the pump asm, a blockage in the drain pump or hose or even a defective control board if in fact all the water has seemed to drain out of the tub.This is how ya set the diagnostic test to clear the codes and see if it reoccurs
  • Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
  • Open the door and set the program to the first program. (Normally rinse).
  • Turn the power off.
  • Press and hold the start button and while holding turn the power on.
  • After a little while the start button will flash, release the button.
  • Press the start button once and close the dishwasher door.
  • The machine will now run through a diagnostic routine.
  • Diagnostic takes about 20 mins.
  • The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the program.
  • To exit diagnostics at any time just press and hold the start button till the program is cancelled.
    GENE
  • Posted on Nov 05, 2011
    Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
    reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
    Jun 02, 2014 | Whirlpool Dishwashers
    WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
    since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
    Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
    I have a Whirlpool Dishwasher model no. ADG 6340 IX.The inlet valve is pulsing and letting in water on every pulse. It just keeps filling, over fills and trips elcb
    $50.60 Quantity:
    In Stock
    Jun 05, 2011 | Whirlpool 24 in. ADG6340iX Built-in...
    Whirlpool dishwasher 1 year old model adg 7560/1 - green start light flashing and beeping - will only do rince cycle
    I have exact same problem with mine. Had Engineer out to tell me it requires new motor. The total cost would be €260. He blamed sand in water as we live near sea. By the way mine survived for 2 1/2 yrs with fairly gentle use
    Dec 19, 2010 | Dishwashers
    We have a Whirlpool ADG 7560 dishwasher which has recently started playing up. When switched on for a normal wash, after a short time the machine starts to beep. If you open the door the green programme...
    Sounds like something is becoming intermittent, but after the system warms up, the connection "holds." These are difficult to troubleshoot until the unit actually stops working. If the unit is in warranty or you have a service contract, it's definitely worth a call to your service center and schedule a home visit.
    Sep 21, 2017 | Dishwashers
    Front light flashing
    Jun 10, 2009 | Whirlpool 24 in. ADG6340 Built-in...
    What flashing are you referring to ? This could very well be a fault code.
    Jan 09, 2008 | Whirlpool 24 in. ADG6340 Built-in...
    Whirlpool 24 in. ADG6340iX Built-in Dishwasher Logo
    60 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
