Question about Kenmore Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The machine fills with h2o then stops and starts to make a slight buzzing sound. move timer by hand but nothing happens. wont agitate, wont drain or spin. Occasionally, while moving the timer the buzz gets louder, sounding like the noise you get when the washer is overloaded.
washer is a Kenmore 70 series heavy duty plus the numbers on the metal tag inside the machine are 8237 2110
  • pnags Jun 18, 2009
    so how can I test if the capaitor is bad?
  • 109 Answers
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Posted on Jun 16, 2009
  • Adrian Jun 18, 2009
    To test a capacitor you need to unplug the wires off it and use a multimeter that has a capacitance tester on it.
    The scale should show uF or nF which is what capacitance is measured in.
    The capacitor will have a number then uF next to it
    IE: 6uF
    6uF means 6 microfarad
    So if you have a 6uF capacitor and your mulimeter reads 2uF, then the capacitor is faulty and requires replacing.
    Thanks,
    Adrian.
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
Washer will not start. it makes a slight buzzing sound and then nothing.
OK buzzing sound, hmmm, need to know more than that, dos the water fill ??,,if not disconnect the water hoses at the machine and check the filter elements in the intake water side they might be plugged, if the unit fills with water then the starter capacitor at the motor might be defective. good luck
Jun 01, 2012 | Maytag Washing Machines
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Kenmore 70 Series will not load hot water
It sounds like need to make some voltage checks on this job. When you set the fill cycle to hot & start the machine do you hear the valve buzz? If you do then the valve is causing the problem.
Feb 06, 2009 | Kenmore 22422 Top Load Washer
Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Jul 05, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
1,132 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
