Question about ASUS M2NBP-VM CSM Motherboard
Turn on power light is on but pc is not start
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 91 Answers
Flush the startic from the power pack, by removing a jump on the board for Memory clearing or check the manual that comes with the board. Or your power pack the goes to the board if it is ATX power remove, take a wire and put it on the 4th hole from the left and to the 4th hole to the right also, to flush out startic power from the power pack. it will not shack your and if your can do this call a techian.
Posted on Jun 16, 2009
Hp xw6200 orange blinking power light
See the following manual:
http://h50146.www5.hp.com/lib/doc/manual/workstation/hp_workstation/c00213035.pdf
Jan 25, 2013 | HP CTO HP Workstation XW6200 Base...
Asus k50 will not start
If the light on the pc, not the power supply is orange this usually means the pc is not comming out of sleep mode. Try the obvious and restart it. If that does not work, attempt starting in safe mode and go to your control panel and turn off all power saving, screen saver, and sleep mode options.
Sep 24, 2012 | ASUS K50 Series K50IJ-G1B NoteBook Intel...
MB green light on but won't start
your power supply must be exact and both power connections to the motherboard must be connected. the green light will come on if voltage is supplied but will turn on a low voltage alarm which is a buzzing sound. or it just wont do anything
Jan 25, 2010 | E-Machines T3624 PC Desktop
When start switch pressed, PC does not turn on.
It sounds like the power supply is going bad. I would try replacing the power supply first.
Dec 02, 2009 | Compaq Presario 5000 PC Desktop
Cpu not powering press on button lights flash fans turn for a sec
It a issue with the power supply or the SMPS. Change the SMPS of same capacity and then it should work..............sodeep
Jul 30, 2009 | Compaq Presario 5000 PC Desktop
Adaptor light on. Laptop does not start when power button pressed same problem also when try too start from battery power. Son was playing a pc game and just switched off, have waited for hour still n
try to take out both battery and power adaptor. press and hold the power button for ten secods while both are not connected. then connect the power adapter only. try to turn it on. if it still does not turn on then most likely you have a problem with the hardware. you might need to have it checked out with an outside tech already.
May 25, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Computer won't turn on but power is on
Some time PC wont start when the Battery is Dead and when RAM's are loose contact. Check the battery power or replace if necessary. If battery is ok then Re-insert the RAM's. Before doing this switch off the power and remove the power cables. Again reinsert the power cables and start the pc. If it wont start check the SMPS. If possible test with another SMPS.
Hope this will be helpful
Thanks & Regards
Nanda Kishore.
Mar 31, 2009 | Toshiba Satellite A135-S4467 Notebook
HP DV2036ea i have a blank screen on the computer
Hello there
Description.
When pressing the notebook power button nothing is displayed on the screen or display. The cause of this problem may be a failed AC adapter, the memory modules (RAM) need to be reseated or a failed notebook system board component which will require an HP certified repair.
Below steps will assist in identifying the cause of the problem and suggest the best solution. Test the AC adapter Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
  1. Remove the battery and disconnect all external devices from the computer.
  2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
  3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
  4. Press the Power button to start the notebook PC.
If the notebook does not start or the display is blank then check the power indicator light or power socket LED. Check the power indicator light or power socket LED On newer models of notebook PCs, there is an LED or indicator light around the power socket on the notebook. Check to see if this light is on or off, when the notebook is plugged into AC power.The power indicator light or power socket light should turn on when the AC adapter is connected.
  • If the light does not turn on then the problem is most likely related to the AC adapter or the electrical source in your home or office. Go to the Light does not turn on section on this page.
  • If the light does turn on but the notebook does not start or the there is a blank screen then continue to the Light does turn on but the notebook does not start section on this page
The light does not turn on when the AC adapter is connected If the power indicator LED is off, the AC power adapter may need to be replaced. To determine if the AC power adapter needs to be replaced follow the steps below:
  1. Ensure that the AC adapter is plugged directly into a known working wall outlet.
    NOTE: To check the wall outlet, plug in a different known working device like a light, radio etc.
  2. Check all of the following connections:
    • The connection from the power cord to the wall outlet.
    • The connection into the power adapter from the power cord.
    • The connection from the AC adapter to the notebook power socket.
  3. Press the power button again to test the notebook PC.
If the power indicator light still does not turn on, then the AC Adapter needs to be replaced. Contact HP Service and Support for further assistance. Power socket LED or power indicator light is on but the notebook does not start If notebook power indicator light (LED) is on, the AC adapter is working correctly. The problem is a result of a hardware failure in the notebook itself. In some cases, reseating the memory module (RAM) may solve the problem.
Feb 02, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
ASUS M2NBP-VM CSM Motherboard Logo
145 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
