Question about NetGear DG834G Router
Netgear router have lost my install disk for my router need to install again can i download from anywhere i have netgear router
  • 854 Answers
Here are some troubleshooting steps that I suggest you try: 1. Check physical connections. a. Connect the modem to the Internet port of the router. The Internet ?i? LED on the front of the router should light up. b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up. 2. Access the router's web-based utility. a. Please open any web browser like Internet Explorer or Netscape Navigator. b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password". Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default. To reset the router: a. Please push the reset button at the back of the router and release after 30 seconds. b. Unplug the power adapter for 10 seconds and then plug it back in. 3. Configure the router. If your Internet Service Provider is using a cable connection, please follow the steps below: a. Click on Basic Settings under Setup tab. b. Select No for Does Your Internet Connection Require A Login?. c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button. If your Internet Service Provider is using a DSL connection, please follow the steps below: a. Click on Basic Settings. b. Select Yes for Does Your Internet Connection Require A Login?. c. Select Other on the Internet Service Provider drop down box. d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply. 4. Configure the wireless settings. a. Click on the Wireless Settings under Setup. b. Change the SSID to any unique name. c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy). d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit". e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number. Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection. f. Click Apply button to save the changes. g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle. 5. Power cycle. a. Power off the modem, router and computers. b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking. c. Power back the router and the computers. Check if it will be able to get online. If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below: 6. Connect wireless computer to the router. If you are using Windows XP with Service Pack 1, please follow the steps below: a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Advanced tab. d. Please delete all the preferred networks then click on OK. e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key. f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router. g. Make sure not to enable IEEE and then click on Connect. If you are using Windows XP with Service Pack 2, please follow the steps below: a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Change Advanced Settings. d. Click on the Wireless Networks tab remove all the preferred networks then click on OK. e. Right click on the Wireless icon then click on View Available Wireless Networks. f. Select your network and click on Connect. g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router. If you are using Windows Vista, please follow the steps below: a. Click Start then select Connect To. b. Connect to a network window will show up. c. Select your wireless network and click Connect. d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect. From the above configuration, please check if you can now access the Internet.
Posted on Jun 16, 2009
Got a new PC and lost my resource disk for my NETGEAR 624 v3 router.......need it to install on new pc do youhave a download version?
have you tryied to log in to the config page
  1. Launch your web browser. Enter "http://192.168.1.1" into the address bar and press the Enter or Return key.
Dec 03, 2010 | NetGear WGT624 Wireless Router
Lost install disk
You don't even need the installation disk! Just do these easy steps:
Plug in your PC directly to your router. And make sure it is turned on. Also plug in your MODEM into the routers modem port.
On your computer open up Internet Explorer. Then in the address box type in: routerlogin,net
User: admin Pass: password
if password for the password does not work then just leave the box blank. Then just complete the steps.
If this works or if you need help then PLEASE email me:
pmt47@comcast.net
email me wither it works or not!
Feb 23, 2010 | NetGear WNR2000 Wireless Router
Lost setup disk
Unless it asks for the disk, then contact the company that you're with but normally, you don't need a setup disk, the only thing that most discs that come with routers are used for is to show you how to connect it, but if you already know, you don't need it, but once you have the router connected you should have internet connectivity.
Jan 18, 2010 | NetGear WGR614 54Mbps Wireless Router...
Lost disk
You'll need to connect your computer directly to the DSL or cable connection, then go to the Netgear website and download the software to install the router. Once downloaded, install the software and go from there :)
Sep 26, 2008 | NetGear DG834G Router
Lost disk
Hello, Here is the link for a D-Link DI-514 wireless router .
http://support.dlink.com/products/revision.asp?productId=DI-514
Hope this helps. Please verify the model number for the Netgear wireless card. I'll see if I can find the driver/software for it also. Thanks...
Mar 25, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
New computer lost install disk!
Hello, Here is a link for the firmware and drivers for your router. Hope this helps.
http://kbserver.netgear.com/products/wgr614v6.asp
Mar 23, 2008 | NetGear WGR614 Router
NetGear DG834G Router Logo
96 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
