Question about Kenmore 15529 Built-in Dishwasher
Water will not come on.
I have loaded my dishes and tried to turn the dishwasher on to wash. The problem I'm having is the water will not come on and after a few min's you smell a burning odor. What could be the problem. Thank's so much.
Laura
  • 1 more comment
  • policeman Nov 01, 2007
    Do you feel this could have anything to do with the pump going out or could it be the water valve? thanks
  • robskiy2k Apr 21, 2009
    The dishwasher attempts to start the wash cycle but appears spray arm never rotates and assembly that erects to shoot water to top rack does not extend up. You can hear a humming sound but not the usual osculating sound of the rotating spray arms. The soap in the dispenser is still present or slightly wet smeared down along the interior of the door. Something is preventing the proper rotation of the cleaning arms. There are no obstructions, spray arm can be rotated 360.
  • Anonymous Apr 24, 2009
    dishwasher is on but water does not enter dishwasher
  • 640 Answers
Look inside the tank for a float or probes.clean them real good and see if this helps.
Posted on Oct 31, 2007
  • anthony james
    anthony james Nov 02, 2007
    from the symptom you described with the heater turning on the float turns the heater and water solenoid valve on and off.the dishwasher thinks theres water in it and its turning on the heater.make sure any water valves are turned on.also check the water hose for obstructions some hoses have a screen in them.
Dishwasher leaves white film on plastic dishes and stainless steel . Salt is full and rinse aid is full.
If your dishes or plastic dishes appear with a white filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Sep 03, 2010 | Miele Dishwashers
My dishwasher leaves a white film on the dishes even though I put in a rinsing agent. what can I do?
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Aug 22, 2010 | Frigidaire 18 in. FDR252RB Built-in...
ALL OF MY DISHES ARE COVERED IN A WHITE FILM. i'VE USED CLR, RUN BLEECH THROUGH THE SYSTEM. ...HAND WASHED ALL DISHES BEFORE PLACIING INTHE DISHWASHER. I USE CASCADE ONLY. SMALL AMOUNTS...
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Please rate the solution if you feel I've helped you
Aug 22, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaves a film of soap on dishes. what needs to be cleaned inside as far as mechanics or is this dishwasher done?
Aug 05, 2010 | GE 24 in. GSD1000G Built-in Dishwasher
Dishs are duty and glasses have white film & dirty
Jun 10, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Film on glasses
May 07, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
White film on all dishes and silverware
Apr 27, 2010 | Kenmore 24 in. 16019 Built-in Dishwasher
Dishwasher not cleaning the dishes anymore, leaves a film on
Apr 10, 2010 | Kenmore 24 in. 16299 Built-in Dishwasher
We have an Admiral Dishwasher that won't clean all the dishes properly. It leaves white film residue on some of the dishes and silverware. Have tried different products to clear this up with nothing...
Apr 04, 2009 | Admiral 24 in. DDB1501AWW Free-Standing...
White residue on dishes after wash
check if the residue are soap or not. residue could be from water tank or water itself.
Nov 01, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Open Questions:
Kenmore 15529 Built-in Dishwasher Logo
108 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
