Rinnai 2001 button pushed too far down and stuck.
Rinnai 2001heater. I turned and pushed the knob too far down and it is now stuck well below where it should be under the rim of the top of the heater.
5 Suggested Answers
SOURCE: Rinnai 2001 space heater: stuck dial
mine did a similar thing, when in off position, it would only turn to pilot/ignite, but would not move past this point. I took off bottom cover to locate regulator. where the slector knob shaft meets the regulator, try spraying wd40 in the top of regulator where square shaft goes into reg. There is a saftey lock mech in there, and in my case it was stuck in the locked position. I then worked the knob back and fourth applying alot of pressure, but not enough to break the knob. it worked after a few tries, and lights and functions normally, locking again if pilot goes out. good luck.
Posted on Jun 28, 2008
  • 148 Answers
SOURCE: we have a Rinnai 2001 heater, pilot and gas are
could be the the bearings starting to dry up see if you can oil it
Posted on Jun 25, 2009
gasman44
  • 83 Answers
SOURCE: Rinnai gas heater - to
This sounds like you have a faulty 'thermocouple' (this is a safety device which the pilot heats up).
I wouldn't recommend you do it yourself, as you may invalidate your house insurance should something happen.
Ideally you should get a gas engineer in to change it, i know it's more expensive but at least you get piece of mind and a guarantee.
The part will cost no more than £25
I hope this helps
Steve :)
Posted on Jul 16, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: When the temp drops below 10degrees our Rinnai
rinnai has a technical bulletin out on this condition #28. It instructs the technician to adjust the gas pressure. You can get a copy of this bulletin by contacting rinnai at 800-621-9419 (US). or at rinnai.us
Posted on Feb 02, 2010
How do you light the rinnai glo-ray heater
Without pushing in the knob, turn knob to "IGN" position, THEN press and hold in knob while in that position, repeatedly press "Ignitor" button. (If it's the first time you've lit it, it may take up to 5 minutes of doing this to get the gas line supply full enough to light the pilot.) After the pilot is lit, continue to hold in "IGN" button for 10 seconds, then release, then you should be good to go.
Nov 22, 2010 | Rinnai Heating & Cooling
How to set clock
go in to the menu by holding the button down for a second. find the clock adjust, put in the correct time. if you make a mistake repeat steps till you get it correct.
Sep 19, 2010 | Kenwood KDC-MP235 CD Player
Unable to adjust clock...attempting to adjust clock in standby mode. cannot get the clock display to blink
try pressing either the seek up or down button for a few seconds. then use the am/fm and seek up and down switches to adjust the time.
Aug 10, 2010 | Kenwood KDC-MP235 CD Player
Need to set my clock alpine cde9852
You need to push and hold the title button till it flashes the hour. Then turn the volume knob to set the hour. Next push the mode button and the minutes will flash. Again turn the volume knob to set.
The title button is to the far right and the mode button is below the volume knob. That should do it!
Dec 01, 2008 | Alpine CDE-9852 CD Player
Have an old Rinnai Gas Heater (approximately 30 years old) still working well, but we had to turn off the gas, and now cannot turn it on again. We have two buttons, one below the other, one is red and...
You are half-way right, to light the pilot, light it and push down the red button and hold it for at ----least2-minutes-- till the flame heats up the pin (thermocouple- which fire-thermocouple metal makes electricity which sends it to the gas valve and says ,OK GAS VALVE,I'VE GOT A PILOT FLAME SO OPEN UP THE MAIN GAS VALVE! See where I'm going with this?
Sep 03, 2008 | Rinnai Heating & Cooling
Jun 05, 2008 | Heating & Cooling
Cooktop controls are in too far and so won't let the knobs to be pushed far enough to turn to turn on the burner and Idon"t know how to raise the cooktop to see if there is an adjustment
easiest fix is to insert a small folded piece of paper into the hole of each knob untill you build the knob up enough for pushing down to turn the switch and it is free
May 17, 2008 | Whirlpool Kitchen Ranges
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
